Yannvanh Samba Member
Joined: November 07, 2020 Posts: 143 Location: Belgium
Posted: Tue Sep 07, 2021 10:10 am Post subject: Re: 1966 11 window |
Right side doglegg install!
farnhamassoc Samba Member
Joined: February 16, 2010 Posts: 122 Location: Riverside ca
Posted: Thu Sep 09, 2021 9:48 am Post subject: Re: 1966 11 window |
Looks easy compared to this build.....
_________________ Owned Countless VWs over the last 35 years.
Restored near 100 vws.
80 Rabbit diesel 1.9 TDI turbo 45mpg
06 Jetta TDI 45mpg
Restored several 11 window kombi and standard
Current inventory 66 delux hard top, so23
60 ragtop and 61 hard top bugs 54 hardtop bug
67 tin top so42 62 SO10 ruthmann bucket truck |
Posted: Tue Sep 06, 2022 1:39 am Post subject: Re: 1966 11 window |
Some more progress on the bus!
Didn't had time to post pics but i am almost done with the body..
Pics are coming! |
andybla Samba Member
Posted: Tue Sep 06, 2022 2:54 am Post subject: Re: 1966 11 window |
keep it up! |
Posted: Tue Sep 06, 2022 1:41 pm Post subject: Re: 1966 11 window |
Some more pics!
Posted: Tue Sep 06, 2022 1:48 pm Post subject: Re: 1966 11 window |
Long panel removed and welded new stucture.. old one was bend due an accident in the past..
More updates/pics to come! |
Posted: Thu Sep 08, 2022 11:11 am Post subject: Re: 1966 11 window |
Long panel with panel bond and left rear corner welded in!
Slowly getting there!
Posted: Mon Sep 12, 2022 12:52 pm Post subject: Re: 1966 11 window |
Finished cargo floor!
Need to flatten down the welds en throw in some primer!
Posted: Sun Sep 18, 2022 3:26 pm Post subject: Re: 1966 11 window |
Some metal work done!
Made a seat belt mount , old one was pretty beat up!
Don66bus Samba Member
Posted: Sun Sep 18, 2022 5:30 pm Post subject: Re: 1966 11 window |
Pretty extensive repairs. It looks like you are replacing more than you are keeping. |
oakman Samba Member
Joined: February 05, 2014 Posts: 1715 Location: Edge of the Desert, Ca
Posted: Sun Sep 18, 2022 8:06 pm Post subject: Re: 1966 11 window |
Great work, keep it up _________________ Brandon |
Posted: Mon Sep 19, 2022 3:07 pm Post subject: Re: 1966 11 window |
Don66bus wrote: |
Yeah, no need to keep rusted metal when you're doin a full resto |
LAGrunthaner Samba Member
Joined: March 18, 2007 Posts: 5509 Location: 1st Coast
Posted: Wed Sep 21, 2022 3:18 am Post subject: Re: 1966 11 window |
Looks great, when completed can you please post the update of the last image as I would like to know how you tackle the upper right hand corner gap.
Keep up this hard work.
_________________ American Red Cross Safe And Well:
Maui Roadsters
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote: |
Posted: Tue Sep 27, 2022 12:34 am Post subject: Re: 1966 11 window |
LAGrunthaner wrote: |
Don't know what you mean by: upper richt hand corner gap? But i will take pictures if i know |
Posted: Tue Sep 27, 2022 5:39 am Post subject: Re: 1966 11 window |
Time for some sandblasting and primer to prevent from further rust while im tackeling the underbody!
Posted: Fri Oct 07, 2022 5:57 pm Post subject: Re: 1966 11 window |
Wasn't happy with how the doglegg and a-pillar came together sondid a little metal work! Now its perfect.
Posted: Wed Oct 12, 2022 11:31 am Post subject: Re: 1966 11 window |
Some more metal work done!
Posted: Wed Oct 19, 2022 11:34 pm Post subject: Re: 1966 11 window |
Time to do the bottom!
Needs welding in some spots, place heater tube and cable guides
Then sanblasting, epoxy, seam seal everything, another 1 or 2 coats epoxy and paint!
Posted: Fri Nov 25, 2022 10:19 am Post subject: Re: 1966 11 window |
Some more welding and started blasting and wire wheeling all the rust off!
Posted: Sat Nov 26, 2022 2:48 pm Post subject: Re: 1966 11 window |
Epoxy primer it is!!
