Longmont1302 Samba Member
Joined: October 01, 2015 Posts: 324 Location: Longmont, CO
Posted: Wed Nov 11, 2020 5:41 pm Post subject: Replacing the Speedometer Cable in '71 Super Beetle |
My speedometer cable broke. So I looked in the Bentley on how to replace it and learned that the cable is actually connected to the hub of the car, which spins the cable. That seems ingeniously simple. The Bentley also indicated that the cable is attached with a circlip, but my old cable used a cotter key or split pin. So I ordered up a new cable and the related items JBUGs offered: a circlip, a Speedometer Cable to Body Seal, and a Speedometer Cable thru Drum Seal. My first hurdle was that the Cable to Body seal wasn’t shaped anything like the hole in my body.
I was not able to get this thing inside the exisitng hole so that the grooves in the side of seal fit over the body on the top and bottom. Instead, the whole seal is just sitting on top of the hole; it might stay put and do the job, but it doesn't seem like it was designed to fit a hole that size. Was it? Or is there another seal that would fit? Either way, this hole in the trunk was the only hole I ran the cable through until I reached hurdle #2; the tired rubber seal seen in these three photos:
Any idea what to call it or where to find one? I ended up reusing the old one but it’s no longer very effective.
My third hurdle was that the new cable didn’t seem to want to fit through the end of the hub; the circlip model cable end seems a little larger than the old cotter key model. In the end it simply took some extended wiggling and fussing.
Out on the road on a cool crisp evening I thought the speedometer might be over reporting as I got close to 70 pretty quickly. So I downloaded a free iPhone app (Speedometer Simple) for comparison. Assuming the app is accurate, the Super Beetle speedometer seemed – if anything – to underreport, showing, for example, 50 mph when the app said 53, but this didn’t seem consistent, so I’m saying the whole thing is pretty close. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31385 Location: Hot Arizona
Posted: Wed Nov 11, 2020 6:47 pm Post subject: Re: Replacing the Speedometer Cable in '71 Super Beetle |
I've replaced the speedometer cable on my 1970 standard bug, but my 1971 Super still has its factory speedometer cable. So can't help there, except to say that either an e-clip or a cotter/split pin would be fine to secure the end in the squared hole in the dust cover on the drum. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
bnam Samba Member
Joined: July 02, 2006 Posts: 2936 Location: El Dorado Hills CA/ Bangalore, India
Posted: Thu Nov 12, 2020 12:30 am Post subject: Re: Replacing the Speedometer Cable in '71 Super Beetle |
According to the parts book the grommet you used is only for regular beetles not supers. Supers don't seemed to have used a grommet. Perhaps just mastic to seal around the cable.
The other part...
https://www.msn.com/en-us/news/world/the-new-battl...d=msedgntp _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
1952 Citroen TA 11BL |
P-Bear Samba Member
Joined: July 20, 2020 Posts: 147 Location: Portland OR
Posted: Thu Nov 12, 2020 10:57 am Post subject: Re: Replacing the Speedometer Cable in '71 Super Beetle |
If it helps, I went and looked at my 74 Super speedo cable and I do not have a grommet next to the gas tank but I do have one under the fresh air box.
bnam wrote: |
According to the parts book the grommet you used is only for regular beetles not supers. |
Jbugs lists the one that he purchased for Supers, but to be honest I wouldn't be able to tell you where it would be used seeing that the only grommet I have is a perfect circle.
https://www.jbugs.com/product/111-861.html _________________ 1974 Super Beetle |
Posted: Thu Nov 12, 2020 8:44 pm Post subject: Re: Replacing the Speedometer Cable in '71 Super Beetle |
Thanks for the feedback, friends.
bnam wrote: |
According to the parts book the grommet you used is only for regular beetles not supers. Supers don't seemed to have used a grommet. Perhaps just mastic to seal around the cable. |
I'm curious: what "parts book" are you looking at, and what mastic are you thinking of? Something like this? https://www.lowes.com/pd/Titebond-Wood-and-Laminate-Mastic-9-5-fl-oz/1001061386 |
raydog Samba Member
Joined: February 09, 2006 Posts: 1163 Location: Cape Cod
Posted: Fri Nov 13, 2020 5:56 am Post subject: Re: Replacing the Speedometer Cable in '71 Super Beetle |
The mastic he is referring to, in the HVAC trade, is commonly called "thumb gum, duct seal, putty, etc". All of my Supers 71-72, always had putty to seal the hole, no grommet. |
bnam Samba Member
Posted: Fri Nov 13, 2020 7:26 pm Post subject: Re: Replacing the Speedometer Cable in '71 Super Beetle |
The VW Factory Parts Manual.
Mastic - what raydog said _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
Posted: Sat Nov 14, 2020 9:07 pm Post subject: Re: Replacing the Speedometer Cable in '71 Super Beetle |
Thanks, raydog and bnam.
bnam wrote: |
The VW Factory Parts Manual. |
I'm not finding anything like that title in my searches. Is this different than the Bentley Official Service Manual? |
Maddel Samba Member
Posted: Sun Nov 15, 2020 9:02 am Post subject: Re: Replacing the Speedometer Cable in '71 Super Beetle |
What a great resource. Thanks, Maddel! |
owdlvr Samba Member
Joined: June 23, 2008 Posts: 684 Location: Squampton BC
Posted: Sun Nov 15, 2020 11:18 am Post subject: Re: Replacing the Speedometer Cable in '71 Super Beetle |
It's been a few years, and the rally bug doesn't have a speedometer cable going through the original hole, but I don't recall a grommet being there on any of the 1302's I've owned or parted out. _________________ ---
Instagram: @DaveHord
1971 1302s - Salzburg Tribute the #RallyBug
1958 Beetle
1975 Beetle
1973 Super Beetle
1993 C3500 with Cummins swap
1967 MGB
1963 MG Midget |
