vwinnovator Samba Member
Joined: July 11, 2005 Posts: 1555 Location: Still doing it in the back of your VW
Posted: Thu Nov 12, 2020 8:18 am Post subject: 52 IDA idle out of control |
Running some 52 IDAs
200air
180main
55 f10 idle w/120
Throttles fully closed
Timing 8° btdc
Fuel pressure 2.5psi
No vacuum leaks
50mm intakes 2332cc FK89, 11:1
Idle is out of control shooting from 4-5000rpm
Throttles fully close, screw not even touching
What / where is feeding fuel to rev out of control? |
QRP Samba Member
Joined: April 27, 2008 Posts: 1712 Location: NORTH HOLLYWOOD,CA
Posted: Thu Nov 12, 2020 9:11 am Post subject: Re: 52 IDA idle out of control |
This may be a silly question but is your linkage disconnected?? |
Dan Ruddock Samba Member
Joined: October 25, 2012 Posts: 3594 Location: Sarasota, in my adopted state of Florida
Posted: Thu Nov 12, 2020 9:19 am Post subject: Re: 52 IDA idle out of control |
Fuel alone would not do that, must be getting air too. Check for leaks |
Ohio Tom Samba Member
Joined: February 09, 2006 Posts: 1660 Location: Marshallville Ohio
Posted: Thu Nov 12, 2020 10:03 am Post subject: Re: 52 IDA idle out of control |
sounds like it sucked in an intake gasket.
Also, I have seen on 51.5 (empi) that the cam for the accel pump on the throttle shaft will hit the casting and prevent the throttle plates from closing all the way. A few minutes with a dremel fixes that problem.
Flip the carb over and look for this issue... |
oprn Samba Member
Joined: November 13, 2016 Posts: 12741 Location: Western Canada
Posted: Thu Nov 12, 2020 10:45 am Post subject: Re: 52 IDA idle out of control |
Mine did that with a bad intake to head gasket. |
Posted: Thu Nov 12, 2020 9:15 pm Post subject: Re: 52 IDA idle out of control |
bent throttle shafts |
King_vw61 Samba Member
Joined: February 03, 2018 Posts: 1383 Location: Southern California
Posted: Fri Nov 13, 2020 1:29 pm Post subject: Re: 52 IDA idle out of control |
I had bent new shafts also. Geers fixed them. Sucked to have a new set of custom 52’s from a well known builder and they need to be re done by geers. 2k you think they would be perfect. Oh well live and learn. _________________ 1961 Ragtop, Autocraft 2783cc for street/strip 10k miles and counting...230.84 HP to the wheels thru Muffler 13.4 to 1 on E85
https://www.instagram.com/king_vw61/?hl=en |
