Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
Posted: Thu Nov 12, 2020 11:02 am Post subject: Front bushing arrangment? |
Trying to reconstruct the bushing arrangement between the front beam brackets and the body. Somebody got a diagram handy?
Max |
VWporscheGT3 Samba Member
Joined: September 01, 2006 Posts: 2076 Location: Gardnerville, NV
Posted: Thu Nov 12, 2020 11:34 am Post subject: Re: Front bushing arrangment? |
top to bottom
metal washer solid rubber bushing, beam clamp, funky rubber bushing with collar facing up , washer lock washer then bolt (edit) and the metal insert obviously inside the big funky rubber bushing _________________ Schnell, SCHNELL!
I like being wrong, Because, it is another opportunity to learn. If you stop learning from your mistakes than what is the point?
If you have any questions about Forged ICON 4032 VW pistons just shoot me a line. |
Dlglobal1 Samba Member
Posted: Fri Nov 13, 2020 2:44 pm Post subject: Re: Front bushing arrangment? |
Here you go:
See parts 53-58
_________________ Cheers, David
1969 Bug
1972 Bug
1968 Mercedes 230 "Heckflosse"
1970 Type 3 Fastback 1600 TA L60D |
Posted: Fri Nov 13, 2020 5:14 pm Post subject: Re: Front bushing arrangment? |
Dlglobal1 wrote: |
Here you go:
See parts 53-58
Interesting. That doesn't show a washer on top of 54.
This is from clatter's gallery
Max |
ataraxia Samba Member
Joined: March 19, 2010 Posts: 4504 Location: Illinois
Posted: Fri Nov 13, 2020 9:40 pm Post subject: Re: Front bushing arrangment? |
Max Welton wrote: |
Dlglobal1 wrote: |
Here you go:
See parts 53-58
Max |
That's because it doesn't belong there. |
Posted: Sat Nov 14, 2020 8:11 am Post subject: Re: Front bushing arrangment? |
OK. Dlglobal1, where did that diagram come from?
Max |
Posted: Sat Nov 14, 2020 8:44 am Post subject: Re: Front bushing arrangment? |
The diagram is from the parts book.
You can download a copy from this site:
https://www.thesamba.com/vw/archives/manuals/type3_parts_book/
Here's the quick and dirty:
The flat bushing (#54) goes between the underside of the body and the top of the front beam bracket (#19), the bushing with the 'ring' (#55) goes on the underside of that bracket - the groove fits into the underside of the bracket, the metal 'tube' (#53) fits in the middle of the two bushings - likely to keep the bolt from eating through the side of the bushings and the giant washer goes on the underside of the lower bushing, then a washer, then the bolt.
This photo of the front of my car doesn't show the lower metal washer because of the angle of the photo.
Posted: Sat Nov 14, 2020 8:52 am Post subject: Re: Front bushing arrangment? |
Thanks!
Max |
