bobrk Samba Member
Joined: March 07, 2002 Posts: 288 Location: Beautiful Downtown San Jose
Posted: Fri Apr 02, 2021 12:24 pm Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" |
Oh hi.
_________________ 1959 Single Cab “Otto”
1500 single port | 1963 small nut/big brake transaxle | CSP Disc Brakes | dual circuit m/c | Deutsch Polster seats |
ach60 Samba Member
Joined: May 14, 2001 Posts: 4139 Location: Santa Maria
Posted: Thu Apr 08, 2021 12:43 am Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" |
bobrk wrote: |
In my never-ending quest to find the keys to this stupid bus, |
The ignition switch isn't original anyway, because I remember you changed it.
Get one of these, and worry about the doors later.
https://www.westcoastmetric.com/search.html?q=ignition+switch&go=Search _________________ Good Luck
Al |
ach60 Samba Member
Posted: Thu Apr 08, 2021 8:50 am Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" |
bobrk wrote: |
Another interesting mystery is this blue paint under my VW emblem...
It does look like that white paint is flaking off, and you can see the SWR on the outside of the emblem, under the same flaking white paint.
I will have to pull the emblem off to see, and since it's missing a couple of clips anyway, it's probably a good idea. |
Done with the lettering City Foreign Car
https://www.facebook.com/photo?fbid=10160705247553362&set=a.10150503602398362 _________________ Good Luck
Al |
bobrk Samba Member
Posted: Thu Apr 08, 2021 11:10 am Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" |
ach60 wrote: |
bobrk wrote: |
https://www.facebook.com/photo?fbid=10160705247553362&set=a.10150503602398362 |
Yeah, I have that picture up here, too...
bobrk Samba Member
Posted: Fri Apr 30, 2021 7:23 pm Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" |
Found my OG door panels and was comparing them to some panels my buddy Al bought years ago.
Trying to decide if I can get these pockets installed on them or if I should just splurge on a new Clara set. _________________ 1959 Single Cab “Otto”
jeremy57ride Samba Member
Posted: Sat May 01, 2021 6:11 am Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" |
Hello- I installed my OG pockets on Clara's panels with pretty good success. Two things to note...
1- The color was harder to match than I thought it would be
2- The OG holes for the rivets are usually too rough to reuse. I moved the rivet holes slightly and redrilled for a fresh start.
_________________ "If you don't do it this year, you'll be one year older when you do." -Warren Miller |
bobrk Samba Member
Posted: Sat May 01, 2021 7:25 am Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" |
jeremy57ride wrote: |
Ah, I hadn't even thought about that.
Thanks, those look great! What do you think of the quality of Clara's panels? _________________ 1959 Single Cab “Otto”
Posted: Sat May 01, 2021 7:00 pm Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" |
Quote: |
Thanks, those look great! What do you think of the quality of Clara's panels? |
Clara's panel are outstanding, nothing but good things to say. This is my second set, I also used her panels for our westy. well worth it _________________ "If you don't do it this year, you'll be one year older when you do." -Warren Miller |
bobrk Samba Member
Posted: Sun May 02, 2021 9:34 am Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" |
Well, I got my windows out yesterday. The rear Philips screws gave me some trouble, but a thorough whacking with an impact screwdriver persuaded them to come out. Several missing bolts on one side that I'll have to replace. Couldn't figure out how to get the windows out after removing those visible bolts and after much struggling, decided to consult my Bentley and found out about the two hidden bolts inside the door. Once I got those off, removal was achievable.
Just noticed the insulation in this Bentley photo. Did the old buses have insulation in the doors?
Now on to the fun jobs of disassembling the frame and replacing all that destroyed rubber. _________________ 1959 Single Cab “Otto”
bobrk Samba Member
Posted: Sun May 02, 2021 3:09 pm Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" |
Got the windows disassembled completely, almost.
Trying to figure out how to get this rock solid door molding out, any ideas?
Looks like there are stops in these grooves, hopefully they're in the WW kit I got...
EverettB Administrator
Joined: April 11, 2000 Posts: 69733 Location: Phoenix Metro
Posted: Sun May 02, 2021 5:08 pm Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" |
bobrk wrote: |
Arggg, been there with seals like that. Fresh razor blade to slice on them while being careful not to cut yourself and basically chiseling them out with little screwdrivers. If you can slice on them a little, it will often release some pressure against the channel and you can slide little pieces out. It's a PITA. _________________ How to Post Photos
bobrk Samba Member
Posted: Mon May 03, 2021 12:50 pm Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" |
Thanks for the advice. Off to get some razor blades. _________________ 1959 Single Cab “Otto”
peecee69 Samba Member
Joined: January 27, 2005 Posts: 1572 Location: Annapolis, MD/Bloomfield Hills, MI
Posted: Mon May 03, 2021 1:01 pm Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" |
EverettB wrote: |
bobrk wrote: |
Arggg, been there with seals like that. Fresh razor blade to slice on them while being careful not to cut yourself and basically chiseling them out with little screwdrivers. If you can slice on them a little, it will often release some pressure against the channel and you can slide little pieces out. It's a PITA. |
That and heat. I just did this job and it wasn't too bad. Also, take some sandpaper (I used some 1000 grit) in the channels. The ends of that channel are slightly bent in, which you can bend out while putting in the seal. After it's in, bend the ends back down on the seal. _________________ 1973 Standard Beetle - running maintenance thread - https://www.thesamba.com/vw/forum/viewtopic.php?t=675712&highlight=
1966 Doublecab - Starting resto - https://www.thesamba.com/vw/forum/viewtopic.php?t=668518&highlight= |
bobrk Samba Member
Posted: Tue May 04, 2021 11:26 am Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" |
Well, the first window took about 2 hours, the second, less than an hour, so I guess I got some mad skills going by the end.
Heat and a utility knife to slice along the side of each track. pick out the middle slice and dig out the two edge slices. Hopefully there will be enough structural integrity to pull them gently out without breaking.
bobrk Samba Member
Posted: Sun May 09, 2021 12:33 pm Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" |
Super glad I got these manuals, they’re saving me from doing stupid things.
Like ruining my window frames…
Or continuing a quixotic search for pick up bumpers…
bobrk Samba Member
Posted: Sat May 15, 2021 11:50 am Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" |
One way to clean your windows? Take them all out!
bobrk Samba Member
Posted: Sun May 16, 2021 7:15 pm Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" |
Well, this went better than I thought. I'm not a good driller, so I messed up my vent frames a little more than I wanted. I made a little anvil that fit inside my vent wing latches and hammered those rivets home. They're tight now, and I bet when I get those vent wing rubbers in, it's gonna be fine.
WW supplies aluminum rivets, I hope they hold up as well as the steel originals.
Did I mention I'm not much of a mechanic? I'm learning a lot. And hammering these down made me very happy.
I even got them on the correct sides.
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9787 Location: Exit 7, New Jersey
Posted: Sun May 16, 2021 10:43 pm Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" |
I've had problems with those repro vent wing latches.
Two issues:
1: The repros are pretty weak, and will snap off without much provocation.
2: All the new vent wing seals are WAY too thick. They cause the glass to have to press too tight to get the latches closed, making the first issue a real threat to breakage.
I end up having to do the two handed vent wing squeeze when opening and closing the vents. One hand pinches the glass against the frame to overcome the oversized seal, and the other hand opens or closes the latch.
It really sucks. Only when you see how easy the latch opens and closes with a good original setup can you appreciate the difference.
If anyone has a good lead on better repro seals I'd love to hear about it. _________________ Founder and Chairman Emeritus, ECMSAS
BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all! |
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4561 Location: St Charles, MO
Posted: Mon May 17, 2021 4:11 am Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" |
I took a tip from another Samba member and instead of using those "too-thick" vent window flat rubber seals, I used the "U" channel shaped Safari windshield rubber from WW. Thinner but not too thin. A nice fit! In the build thread on my '59 Double-Cab ( https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0 ) I did a pretty thorough how-to on vent and cab window rebuilding showing tools and products used including the Safari windshield rubber for the vent window seal that might be helpful to you...
It starts with some info on page 30 of the thread about 2/3 of the way down the page: https://www.thesamba.com/vw/forum/viewtopic.php?t=...;start=580
The how-to really gets going on page 35 of the thread:
https://www.thesamba.com/vw/forum/viewtopic.php?t=...;start=680
The Safari seals were MUCH easier to use in substitution for the 'too-thick" crap they sell in the past and now, and it REALLY helps to make and use metal of wooden press with clamps to crush the glass into the frames without bending the frame ends outward!
Good luck and have fun!
Bill Bowman _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
