SGKent Samba Member
Posted: Sat Nov 14, 2020 5:46 pm Post subject: And the part number is... |
Believe these are the clips that hold the electrical wires under the bus above the trans. Green are marked 19 (19mm?) and the pink 17 (17mm?) - I am pretty sure one of the folks pulled these off a late bus for me years ago. Anyone know the part numbers?
_________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
ivwshane Samba Member
Joined: May 19, 2011 Posts: 1920 Location: Sacramento ca
Posted: Sat Nov 14, 2020 6:14 pm Post subject: Re: And the part number is... |
The green clips were what was holding my fuel hose to the underside. _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
SGKent Samba Member
Posted: Sat Nov 14, 2020 10:03 pm Post subject: Re: And the part number is... |
ivwshane wrote: |
The green clips were what was holding my fuel hose to the underside. |
The fiche only shows the U shaped clips, like the plug wires: 211 201 249 A . They end in early 1977. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Sat Nov 14, 2020 10:55 pm Post subject: Re: And the part number is... |
I got somethings similar to these from a local CarQuest a few years back, will keep my eye out for the remainder of the package. |
Joined: January 01, 2007 Posts: 16863 Location: sticksville, ct.
Posted: Sat Nov 14, 2020 11:13 pm Post subject: Re: And the part number is... |
steve, i have a shit ton of these. when i pick something clean before i scrap it, i leave only the rust
how many of what size do you need? _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
SGKent Samba Member
Posted: Sat Nov 14, 2020 11:30 pm Post subject: Re: And the part number is... |
don't need any - just trying to catalog the stuff that I am keeping. If I need one in a couple years or go to list it, would like to put the part number on it. Right now it is "unknown." Looks like 76 and prior used the U shaped clips and 77 and later used these. Don't see them in the fiche. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Sat Nov 14, 2020 11:48 pm Post subject: Re: And the part number is... |
SGKent wrote: |
don't need any - just trying to catalog the stuff that I am keeping. If I need one in a couple years or go to list it, would like to put the part number on it. Right now it is "unknown." Looks like 76 and prior used the U shaped clips and 77 and later used these. Don't see them in the fiche. |
The ones I bought were for a Vanagon, so likely the same or similar to the '76 and later ones. |
SGKent Samba Member
Posted: Sun Nov 15, 2020 12:08 am Post subject: Re: And the part number is... |
Wildthings wrote: |
SGKent wrote: |
I just looked in EKTA. It shows a similar clamp but the part numbers for those kinds of fasteners all appear superseded to a wire tie clamp N90666101. Arrrg. now reads, part number - Unknown, pink-17, green-19 fuel. Thank you all. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
rsbadura Samba Member
Joined: November 30, 2009 Posts: 656 Location: Berlin, Germany
deepcflea Samba Member
Joined: June 06, 2006 Posts: 150 Location: Sumter, SC
Posted: Sun Nov 15, 2020 7:37 am Post subject: Re: And the part number is... |
Pelican Parts out of CA carries them. Not sure on some of the sizes or if the ones below that don't have sizes is accurate. Pulled this info off their forum.
Gray 10mm 477-971-851
Blue 16mm 113-142-261-A
White 18mm 171-971-847-A
Yellow 321-971-847-B
Red 811-971-848-B
Green 999-651-168-40
Black 181-971-847
On my 78 DC, the pink ones are used in the engine compartment holding the wiring harness along the inner top rear edge for the taillights and the blue I found above the tranny holding fuel line.
_________________ 1978 Bay Window Double Cab (1600cc) - Marilyn
https://www.thesamba.com/vw/forum/viewtopic.php?t=...005b041ddd
Formerly owned VW's
1983 Westfalia
1956 Oval Ragtop
1967 Bug
1970 Ghia
1969 Buggy |
SGKent Samba Member
Posted: Fri Nov 20, 2020 5:39 pm Post subject: Re: And the part number is... |
awesome - thank you _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
old DKP driver Samba Member
Joined: March 30, 2005 Posts: 4145 Location: Los Gatos,Ca.
Posted: Fri Nov 20, 2020 7:19 pm Post subject: Re: And the part number is... |
I believe they were introduced on volkswagens here in the United States in
1974 when the vw dasher was introduced to America
. _________________ V.W.owner since 1967 |
