skramyrral Samba Member
Joined: April 12, 2006 Posts: 82 Location: Naples, Florida
Posted: Tue Apr 19, 2011 8:45 pm Post subject: European Motorsworks, company you can trust! |
I had an amazing experience with European Motorworks, Hawthorne Ca.
I ordered valve guides from them, But I ordered the wrong sizes, Not only did they send me the correct ones, but they didn't even charge me for them. They just said to send back the wrong ones! It is great business practice, above and beyond what most companies will do these days. So, If you need any parts or machine shop services, they are the guys to go to. The service was OUTSTANDING and the prices are great. |
craigman Samba Member
Posted: Tue Apr 19, 2011 9:00 pm Post subject: |
Yep! Also a GREAT place to get type 4 engine parts! |
Bloog Samba Member
Joined: April 11, 2007 Posts: 484 Location: Over yonder
Posted: Wed Apr 20, 2011 5:09 am Post subject: |
Shouldn't this be here?
http://www.thesamba.com/vw/forum/viewforum.php?f=14
WAKE UP GLENN!!
Bob Hoover wrote: |
Listen to what the ENGINE has to say. It won't take your money and it's incapable of lying. All you have to do is learn to speak its language.
-Bob Hoover |
chabanais wrote: |
Ah... you buy from Sum Ting Wong Distribution Company. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76935 Location: Sneaking up behind you
vwgearhead Samba Member
Joined: February 21, 2005 Posts: 100 Location: Los Angeles,Ca
Posted: Thu Apr 21, 2011 1:44 pm Post subject: |
Yes they are good guys,bought an item from them today,I have been doing business with them for years,always good service,they have been around for over 30 years,they used to distribute dellortos years ago! I recommend them. |
jmstu76 Samba Member
Joined: March 01, 2004 Posts: 1227 Location: Edmond Oklahoma
Posted: Sat Nov 14, 2020 10:18 pm Post subject: Re: European Motorsworks, company you can trust! |
I just made a huge purchase from Jorge at European Motorwerks. Not only are they very knowledgeable on the type IV but they have an in house machine shop. Prices are very competitive. I will continue working with them. Can’t recommend them enough. _________________ James
'76 Deluxe Sage Green Westy
2258 cc GD case 78mm CW crank, 2.0 H-beam rods 5,325” 22mm pin, JE forged pistons with 15cc dish, JE rings, type 11 clearanced oil pump, CB Eagle 2205 Type-2 “Torque Special” hydraulic cam with matched lifters fed by CB Dual Weber 40 IDF MX with 6” foam air filters, currently 55 idle, 130 main, 200 air correction, 32 mm venturis. 27in General Grabber AT2 All Terrains, Berg Shifter, stock '76 exhaust HPC Ceramic Coated. 11/18/2020 |
