legotech7 Samba Member
Joined: May 09, 2009 Posts: 879 Location: North Carolina
Posted: Sat Nov 21, 2020 11:59 am Post subject: Heat Risers... |
Decided to get a new progressive carb kit, to replace the one I have. Its shot. My question is my buggy's set up doesn't have the heat risers, though it was running fine, till the fuel pump crapped out on me. I will be replacing that as well with an electric pump. Will I need the heat risers with the new kit I ordered? I've seen a few buggy's wit out them. Any input on this would be greatly appreciated... thanks.. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76907 Location: Sneaking up behind you
Posted: Sat Nov 21, 2020 3:17 pm Post subject: Re: Heat Risers... |
if you drive in cool/cold weather you'll need them. _________________ Glenn
Member #1009
#BlueSquare |
jspbtown Samba Member
Posted: Sun Nov 22, 2020 7:17 am Post subject: Re: Heat Risers... |
Can I ask why you decided to go with a progressive set up with electric fuel pump?
Your fuel pump should be wired into some sort of safety switch (oil sender?) to make it safe. |
Posted: Sun Nov 22, 2020 7:27 am Post subject: Re: Heat Risers... |
jspbtown
I went with the progressive kit, my engine ran so well with it , even with out the heat risers. But I decided to go with them anyway as suggested. The electric fuel I think fare better with these set ups, As well ass ease of replacement if ti ever goes south. Had them before in other bugs and never had issues with them. My last one ran for 10 years. No issues. The new mechanical pump are just garbage. They may last a year at best and to replace them with a weber progressive kit is a PITA......Electric pump/... easy peasy....And yes I will have an over ride switch for it... Thanks for the input... |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8699 Location: Sunset, Louisiana
Posted: Sun Nov 22, 2020 9:05 am Post subject: Re: Heat Risers... |
I like to keep it simple. My original VW fuel pump is over 50 years old. Every few years it gets a cleaning and a rebuild.
_________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
Glenn Mr. 010
Posted: Sun Nov 22, 2020 9:08 am Post subject: Re: Heat Risers... |
Q-Dog wrote: |
I like to keep it simple. My original VW fuel pump is over 50 years old. Every few years it gets a cleaning and a rebuild. |
Why?
My fuel pump is over 20 years old and works just fine. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Sun Nov 22, 2020 10:07 am Post subject: Re: Heat Risers... |
Q-Dog Thats a good pump, you can rebuild, but hard to find. These new pumps coming from Brazil are garbage. Had to change quite a few in too short of periods of time. Going electric... |
Q-Dog Samba Member
Posted: Sun Nov 22, 2020 10:33 am Post subject: Re: Heat Risers... |
Last time I rebuilt the pump I am using in my buggy was 8 years ago. About 30,000 miles so far. _________________ Brian
'69 Dune Buggy
'70 Beetle |
Posted: Sun Nov 22, 2020 12:57 pm Post subject: Re: Heat Risers... |
Well had some time this afternoon. Took out the engine, Easy on a buggy, took me a bit since I have a bad case of CRS. I tagged everything for ease of replacement. Now to go over it and see what else I need. This engine had no signs of oil leakage anywhere. Dry as a bone, but would you all recommend I change the seals in the oil cooler? I might apt to change the clutch and pressure plate as well. Am I missing anything? I will replace the exhaust gaskets, they look pretty rusty from setting around so long. Should I use a relay for the electric fuel pump? I'll post as I go along, any other recommendations would be appreciated... Thanks.. |
Posted: Sun Nov 22, 2020 5:43 pm Post subject: Re: Heat Risers... |
Front seal. Yes on the oil cooler seals. Be sure to get the right pressure electric pump (or regulator) and yes on the relay. |
Posted: Mon Nov 23, 2020 9:05 am Post subject: Re: Heat Risers... |
Thanks. Noted on all.... |
andygere Samba Member
Joined: January 31, 2014 Posts: 600 Location: Central Coast, CA
Posted: Mon Nov 23, 2020 2:41 pm Post subject: Re: Heat Risers... |
The stock rebuildable Pierburg fuel pumps are sold by a few vendors as rebuilt units, and the rebuild kits are available from Wolfsburg West if you can get your hands on a used one. I was able to find a NOS unit when I had my 2165 built last year. I wanted a stock mechanical pump for simplicity and reliability, and the Pierburg fit the bill in terms of working well with my dual Webber linkage and relocated coil. For those interested, here are a few of the vendors that list them.
https://www.classiccult.com/vw-pierburg-fuel-pump-1958-67.html
http://www.vintagewerks.com/Fuel%20Pumps/fp_4sale.html#1300pierburgfuelpump |
EVfun Samba Member
Posted: Mon Nov 23, 2020 9:52 pm Post subject: Re: Heat Risers... |
legotech7 wrote: |
You have no leaks... why would you replace any seals? _________________
Wildthings wrote: |
