Dstolan83 Samba Member
Posted: Sat Nov 21, 2020 3:14 pm Post subject: A "GEX" story... the horror. |
So I bought a Gex 1776 hi performance Long block. They suggested I run dual Weber 40’s . I asked them about running a single 2 barel Weber but apparently that creates a flat spot in in the rpm curve. I really don’t want the extra work/ tuning time with 2 carbs. My type 1 is and will be driven at a daily. Was looking as the Rad (?) 2 barel 350 cFM set up , intake , carb, and linkage it a bit spendy. Any suggestions.
The motor is GEX rebuilt hi performance 1776 whit no major add ons did get the super tins though. |
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76941 Location: Sneaking up behind you
Dan Ruddock Samba Member
Joined: October 25, 2012 Posts: 3594 Location: Sarasota, in my adopted state of Florida
Posted: Sat Nov 21, 2020 3:37 pm Post subject: Re: Help choosing the right carb set up for GEX 1776 |
It is a common misconception that a single carb is less problems than duels, the opposite is true. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31380 Location: Hot Arizona
Posted: Sat Nov 21, 2020 4:16 pm Post subject: Re: Help choosing the right carb set up for GEX 1776 |
Glenn wrote: |
Oh come on, that have a A+ rating from the BBB. |
I believe that just means that the company responded in apparent good faith to an official complaint through BBB.
My only hands on experience with BBB was when Montgomery Wards would not own up to its written battery warranty for my VW battery, so I entered a complaint. 6 months later MW offered a discounted battery to me - duh!!! I'd already replaced the battery, but goes as a complaint responded to. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Sat Nov 21, 2020 4:21 pm Post subject: Re: Help choosing the right carb set up for GEX 1776 |
Not sure about the a+ Better Business comment, Sarcasm? Really looking forward to getting the engine. No negative on my part . Just an air cooled novice trying to figure things out . The only stupid question is the one you don’t ask ! The motor specs : Double Thrust Cam Bearing
NEW Big Valve Dual Port Heads 39 mm intake valves and 32 mm exhaust valves
8 Dowel Crankshaft & Flywheel 69 mm stroke
Guessing, stock/normal compression ratio
Heavy Duty Oil Pump
Hi Carbon Steel Pushrods
GEX 110 Cam 431 inches lift and 284 degree duration.
Heavy Duty Swivel Adjusters
Bolt on Aluminum Valve Covers
Solid Heavy Duty Rocker Shafts not sure the Ratio , I should ask
Cima Mahle Piston & Cyl. set |
DeathBySnuSnu Samba Member
Glenn Mr. 010
Posted: Sat Nov 21, 2020 4:29 pm Post subject: Re: Help choosing the right carb set up for GEX 1776 |
I'll save you a step.
busboyjake wrote: |
hello, i've had three GEX engines go bad within days or months because of internal problems, i now am asking for a refund, but i seem to be getting nowhere, will i ever see my money again? have any of you ever had this experience, or know anyone there that i can deal with? Help!!!!
thanks
Moderator note:
This thread has been locked in favor of this longer GEX thread:
http://www.thesamba.com/vw/forum/viewtopic.php?t=92079 |
_________________ Glenn
Member #1009
#BlueSquare |
Glenn Mr. 010
Posted: Sat Nov 21, 2020 4:31 pm Post subject: Re: Help choosing the right carb set up for GEX 1776 |
Dstolan83 wrote: |
Not sure about the a+ Better Business comment, Sarcasm? |
Yes...
GEX sells crap. Don''t believe what the spec sheet says. And their machine work is less than acceptable. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Sat Nov 21, 2020 4:46 pm Post subject: Re: Help choosing the right carb set up for GEX 1776 |
I worked for GEX in the 70’s when it was in CA. I know first hand there was little to no attempt to have quality. They exchanged junk rebuilds for pristine OG cores. |
Glenn Mr. 010
Posted: Sat Nov 21, 2020 5:09 pm Post subject: Re: Help choosing the right carb set up for GEX 1776 |
Back to the original question....
Get dual carbs. They run better and are NOT any harder to tune. I've been running dual carbs since 1978. That was my daily driver until 1998. it was never garaged and out in the rain and show. _________________ Glenn
Member #1009
#BlueSquare |
QRP Samba Member
Joined: April 27, 2008 Posts: 1712 Location: NORTH HOLLYWOOD,CA
Posted: Sat Nov 21, 2020 5:19 pm Post subject: Re: Help choosing the right carb set up for GEX 1776 |
GEX still builds motors ????? |
Posted: Sat Nov 21, 2020 6:55 pm Post subject: Re: Help choosing the right carb set up for GEX 1776 |
Now you guys got me a little worried hopefully they stand by they warranty. When I talked to Larry and was asking him questions and brought up the “Bob Hoover oil mod “ and his response was “ I have no idea what you are talking about and I have been building motors for 34 years”. Did kinda throw a huge red flag. Should I cancel my order? Ordered it last Friday and was told it’s 3 to 4 weeks out
Will look into the dual carbs . Any brand to stay away from? I was leaning towards the Weber’s build by Redline Performance |
Glenn Mr. 010
Posted: Sat Nov 21, 2020 7:08 pm Post subject: Re: Help choosing the right carb set up for GEX 1776 |
Dstolan83 wrote: |
Should I cancel my order? Ordered it last Friday and was told it’s 3 to 4 weeks out |
I would.
At least to do some research on them.
There are many other very good and reasonable builders. _________________ Glenn
Member #1009
#BlueSquare |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15309 Location: Deep in the 405
Posted: Sat Nov 21, 2020 7:09 pm Post subject: Re: Help choosing the right carb set up for GEX 1776 |
You will get better MPG with dual carbs when tuned correctly. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Teeroy Samba Member
Joined: April 20, 2003 Posts: 3685 Location: Eastern WA
Posted: Sat Nov 21, 2020 7:27 pm Post subject: Re: Help choosing the right carb set up for GEX 1776 |
I second cancelling your order now if that is still an option. Look at the vendor feedback thread. You can get complete Weber kits with different linkage air cleaner options from John @ Air Cooled Net as well, or CB Performance. _________________ Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org |
sgmalt46 Samba Member
Joined: April 20, 2005 Posts: 1296 Location: south san francisco
Posted: Sat Nov 21, 2020 7:31 pm Post subject: Re: Help choosing the right carb set up for GEX 1776 |
run away from GEX if it's not too late! the single 2 barrel as mentioned is harder to make run right. and will get mileage like a v-8 . 40idfs are easy to setup. I can't believe GEX is still around. I have seen some of there sweet work first hand! _________________ 55 deluxe 23 window bus
64 crew cab
55 rag top beetle
66 beetle
71 square back (sold) ! good luck with it Henry!
46 beetle 552nd royal army service corps CCG |
Posted: Sat Nov 21, 2020 7:47 pm Post subject: Re: Help choosing the right carb set up for GEX 1776 |
Dstolan83 wrote: |
I would run, I remember Larry trying to weasel out of warranties. For Larry VW’s were income and nothing more, no passion for trying to make the engine better. He did not care. Build the engine yourself from the advice of people who care. Carbs? I like to rebuild old Italian Weber dual throats, dcnf, idf and ida. Dan |
evanfrucht Samba Member
Joined: July 24, 2016 Posts: 2180 Location: Laurel Canyon, CA
Posted: Sat Nov 21, 2020 7:59 pm Post subject: Re: Help choosing the right carb set up for GEX 1776 |
CANCEL THE ORDER. _________________ 1967 Bug ( the daily rod )
1964 Fury Wagon ( the pavement shredder ) |
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Sat Nov 21, 2020 9:59 pm Post subject: Re: Help choosing the right carb set up for GEX 1776 |
I didn't know they were still in business.
Never heard of Gene Berg? Well even if you don't buy into his mantra, anyone who builds VW engines should know his name and the things he did.
It's your money. But I'd worry about more than what carbs you want to run. |
