Another dash thread 73
DaveVHS
DaveVHS is offline
PostPosted: Sat Feb 06, 2021 2:05 am    Post subject: Re: Another dash thread 73 Reply with quote
Kinda finished it, im a bit over it now really. Many attempts at the vinyl and paint...auuugh anyways, this is the design I wanted so happy I got it done, up close its a bit rough in places
Top half I wrapped in vinyl and painted the lower half.
I did fibreglass the holes and fill sand over... it was hella messy,
I ran a chrome datum around entire inside that curls up onto the rear parcel shelf, just used that stick-on moulding stuff, cost about $30 for a roll
Vinyl I bought for $20 and got so much I did the dash three times due to a few failed gluing attempts
Still have some cleaning up and new lights/ switches to put in
Gauges were some smith replicas off eBay for $70... not sure how theyll go as not wired up yet
Overall, very happy with my budget attemptit but trying to get vinyl neat and painting dash was a nightmare
myghiarocks
myghiarocks is offline
PostPosted: Tue Dec 01, 2020 12:42 pm    Post subject: Re: Another dash thread 73 Reply with quote
We filled and painted mine with metal. Complete interior was removed.
Really like how it turned out. I was not a fan of the fake wood. With the original style dash pad I get no glare.
kingkarmann
kingkarmann is offline
PostPosted: Tue Dec 01, 2020 11:45 am    Post subject: Re: Another dash thread 73 Reply with quote
I love the look of a painted dash but I will say i get a lot of glare. I lay a towel or microfiber when I'm driving.
I once considered finishing the dash face and top with Alcantara. I think it looks very classy.
"Who died and made you king of anything?"
Sara Bareilles
"Ego is the anesthesia that deadens the pain of Stupidity.
"Rick Rigsby"
Braukuche
Braukuche is offline
PostPosted: Tue Dec 01, 2020 7:35 am    Post subject: Re: Another dash thread 73 Reply with quote
If you are going to weld or braze youll want to gut that nice interior, and pull the windshield. sparks and slag will fly everywhere.
If you are bent on doing this Id just fiberglass mat the holes from behind, fill, sand and paint. Its gonna be one hell of a messy job anyway you go.
Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1961 Beetle convertible
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Ghia coupe
1967 21 window rust bucket
1969 Ghia convertible
1970 Ghia convertible
1973 Ghia convertible X 2
Vladiiiii
Vladiiiii is offline
PostPosted: Mon Nov 30, 2020 11:52 pm    Post subject: Re: Another dash thread 73 Reply with quote
That's a nice color combination Cool
Vlad's 72 Ghia (Once in a Lifetime Restoration topic)
https://www.thesamba.com/vw/forum/viewtopic.php?p=9237746#9237746
DaveVHS
DaveVHS is offline
PostPosted: Mon Nov 30, 2020 3:26 pm    Post subject: Re: Another dash thread 73 Reply with quote
No, I removed the factory AC unit and that thin horizontal vinyl strip between metal dash and the AC unit.
AC unit was missing condensor & compressor and the car is far from original, just trying to create more room in the front and style it the way I like, doesn't have to be 100% original as I struggle with leg room
I've really progressed the interior which was a bit dumb so now I need to cover everything to tidy up this dash.
I was reading about those low temp solder/ weld rods and wondered if if anyone here has used them?
I hear they are OK for cosmetic stuff not structural so maybe these would be better than me grinding and welding the dash up now I've already finished a large part of the interior
Before:
After:
Vladiiiii
PostPosted: Thu Nov 26, 2020 11:18 am    Post subject: Re: Another dash thread 73 Reply with quote
Are you planning to use the lower dash pads? Be aware that those lower horizontal slats may be visible, in case the fittment of the dash pads is not so good Confused
(or they have not yet been covered, in the picture?)
56reddy
56reddy is offline
PostPosted: Wed Nov 25, 2020 5:59 am    Post subject: Re: Another dash thread 73 Reply with quote
The dash holes are fairly easy to weld up. I took the time to delete all holes, seatbelt indicator, fresh air controls, speaker grill, and defroster vents. I think the final thing Ill do is relocate the headlight and wiper switches to a hidden location.
New Vintage Specialist.
1974 ghia convertible
1981 Vanagon Westfalia
Making VWs Fun Again.(MVFA)
Braukuche
PostPosted: Tue Nov 24, 2020 4:07 pm    Post subject: Re: Another dash thread 73 Reply with quote
kingkarmann wrote:
Braukuche wrote:
Ive seen it done and it just doesnt look right. The later dashes have too many switches hes and warning lights, they are physically larger...lus you cant hide the carnage because it is visible from behind if anyone looks.
If you ever decide to sell it will take away the value significantly. Done right the plastic cover looks good and visually correct.
I had my extra holes filled on my 67. If the work is done correctly i think they can turn out just fine.
From behind
Agreed. Very well done.
Retirement is here!
1956 Ghia
1960 double cab
1963 356 B coupe
1963 Ghia coupe
kingkarmann
PostPosted: Tue Nov 24, 2020 10:13 am    Post subject: Re: Another dash thread 73 Reply with quote
From behind
Sara Bareilles
"Rick Rigsby"
c21darrel
c21darrel is offline
PostPosted: Tue Nov 24, 2020 9:42 am    Post subject: Re: Another dash thread 73 Reply with quote
Loren wrote:
Wouldn't it be easier to drill out the spot welds and weld in an early dash section? The dash is spot welded at the windshield opening and across the bottom. The sides are stitch welded. It doesn't take too long to drill out the spot welds and remove the current dash. I have never done this so I don't know how well an older sash section fits, but it would make for a super clean looking modification and welding the spot welds is much easier than patching the current dash.
I think it took me the better part of a Saturday to drill out all the spot welds, their are hundreds. But worth it.
Out with the old, ignition on the column.
67 dash, ignition on the dash.
GhiaBuild
sputnick60
sputnick60 is offline
PostPosted: Mon Nov 23, 2020 11:48 pm    Post subject: Re: Another dash thread 73 Reply with quote
DaveVHS wrote:
I like this idea and would think its a lot easier to weld in a full or partial dash than patch everything. Not sure where I'd find a donor dash tho. I'm in Australia, doesn't seem to be many KG's around for parts like this
You can ask the local VW club. Also you can ask the Suppliers in BNE, SYD and ADL. Another guy is Vic Brkovec (Vic's Bahn) who is a specialist for obscure Ghia parts. http://www.vicsbahn.com/karmann.html
Nicholas
'66 Karmann Ghia Cabriolet...
'65 Porsche 356C Coupe...
2014 Passat B7 130TDI wagon (cheats in tests)
"Have no fear of perfection - you'll never reach it."(Salvador Dali)
Bones 53
Bones 53 is offline
PostPosted: Mon Nov 23, 2020 8:24 pm    Post subject: Re: Another dash thread 73 Reply with quote
DaveVHS
DaveVHS is offline
PostPosted: Mon Nov 23, 2020 5:39 pm    Post subject: Re: Another dash thread 73 Reply with quote
Marcdeb
Marcdeb is offline
PostPosted: Mon Nov 23, 2020 5:38 pm    Post subject: Re: Another dash thread 73 Reply with quote
Prior to buying my car, a PO did exactly that to my 71 Vert. The original dash was removed and a 62 dash was welded in. There was nothing wrong with the original dash other than they wanted a different gauge arrangement. I just had the windshield out and it is hard to tell anything was changed.
Marc
1971 Karmann Ghia Cabriolet
Restoration thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=726710&postorder=asc
Loren
Loren is offline
PostPosted: Mon Nov 23, 2020 2:43 pm    Post subject: Re: Another dash thread 73 Reply with quote
DaveVHS
DaveVHS is offline
PostPosted: Mon Nov 23, 2020 2:27 pm    Post subject: Re: Another dash thread 73 Reply with quote
runamoc - thanks. good tip I might give that a try.
My glove box door is in bad shape so I might start with that as a test by welding a plate over the door to clean it up
Braukuche - agree with all points, unfortunately the car has been modified heavily so I don't need to keep it original. A lot of the switches and warning lights are items that have been removed by PO
Braukuche
PostPosted: Mon Nov 23, 2020 9:07 am    Post subject: Re: Another dash thread 73 Reply with quote
Retirement is here!
1956 Ghia
1960 double cab
1963 356 B coupe
1963 Ghia coupe
runamoc Premium Member
runamoc is offline
PostPosted: Mon Nov 23, 2020 7:54 am    Post subject: Re: Another dash thread 73 Reply with quote
if you can 'back-up' where you want to weld with some copper it will stop burn-thru and the weld doesn't stick to the copper. I've used this 'method' to fill in 1/2" holes. Here I'm fixing the gap.
Daily driver: '69 Baja owned 41 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
In garage for rehab: '71 Beetle
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires
DaveVHS
DaveVHS is offline
PostPosted: Mon Nov 23, 2020 1:18 am    Post subject: Another dash thread 73 Reply with quote
Another dash question but her goes
I want to fill these holes
My gasless MIG welder will prob blow holes thru the metal cause a) its thin and b) my welding skills are average
Question:
Is it possible to fibreglass, fill, sand and paint a dash and get a decent result that might look like a painted metal style dash?
Pic of my current status and yes, Im sure ppl will ask why Ive forged ahead with interior before doing the dash but it was a bit of a last minute decision
