harrycrackerdog Samba Member
Posted: Tue Nov 24, 2020 2:57 am Post subject: T5 B dropped spindles |
I have searched high and low and asked a bunch of body shops and no one is definitive about using VW dropped spindles on a 356b T5 car
can anyone help or point me in the right direction
I want to use dropped spindles to maintain ride and get a 2.5" drop.
I know all about adjusters.
If anyone can help please no "I think so" or there's a wild goose chase threads with more "I think so" replies.
thanks again
Paul. |
ensys Samba Member
Joined: March 11, 2009 Posts: 322 Location: America's Automobile Heartland
Posted: Thu Nov 26, 2020 10:26 pm Post subject: Re: T5 B dropped spindles |
I believe that only the A spindle was/is interchangeable with VW spindles.
Those for the B and later are a beefier item and not interchangeable in the way you describe. _________________ Keep 'em flying...
S.J.Szabo |
RolandD Samba Member
Joined: January 15, 2017 Posts: 247 Location: Menomonee Falls, Wis
Posted: Fri Nov 27, 2020 4:19 pm Post subject: Re: T5 B dropped spindles |
I was given a 80's Funco with 356 spindles. I believe the Link pins are the same, but the bearing ID was bigger than a beetles. I was able to use VW drums, but had to swap in the bigger ID bearinga. Could you measure your inner and outer bearing IDs and ODs??
Crazy Roland |
badsix Samba Member
Joined: November 22, 2007 Posts: 228 Location: coos bay or.
Posted: Wed Dec 09, 2020 7:41 pm Post subject: Re: T5 B dropped spindles |
i was going to do this to my A but the spindles i got were junk, so i'm still at that point. anyway you'll need the vw tie rod ends, the taper is different they WILL thread into your tie rods. there are bearing to make the Prosche drums work.
Jay D. |
livnlow Samba Member
Joined: May 03, 2005 Posts: 53 Location: Jacksonville, Florida
Posted: Sat Mar 06, 2021 4:12 pm Post subject: Re: T5 B dropped spindles |
I have a 63 b t6 with lowered beetle spindles. They worked just fine. It's been quite a few years so i can't remember exactly but i think i used 1960ish front outer bus bearings to match the 356 drums. Also i pressed apart and used the original 356 king and link pins so i don't know if those vw parts work or not. As for the tie rod ends I think mine are baywindow bus but that probably depends on who made the spindles _________________ 1963 356B Coupe
1965 sundial |
gitchesum Samba Member
Joined: November 10, 2003 Posts: 513 Location: North Cali
Posted: Mon Mar 08, 2021 12:11 pm Post subject: Re: T5 B dropped spindles |
I’ll be using CB’s spindles, with VW rebuilt carriers. Have to change the tie rod ends to later bug.
Have yet to figure out the bearings. I thought the inner needed to be changed from the stock Porsche, no ? _________________ Looking for SP Kadron manifolds...please !!
57 SC
61 rag w/356B brakes
61 356B
Honda XLR 250, 69 Z50, Yamaha 100 Enduro...and others.
GMC SLT 4x4 Dmax
Kubota L3710, not enuf attachments.
And various VW's that come and go... |
Bub Samba Member
Joined: June 10, 2004 Posts: 1155 Location: Central Washington
Posted: Wed Apr 07, 2021 1:25 pm Post subject: Re: T5 B dropped spindles |
I put bug spindles on my 356/ S-90 (60') back in the old days.
Easy swap, perfect fit w/ all the stock 356 parts - EXCEPT the inner bearing. You can take both bearings to any machine/ bearing shop type place and tell them which inner race / outer race diameter combo you need and they'll have them on a shelf.
I think there's a VW bearing that swaps directly..can't remember from what though. Maybe Bus or Thing? _________________
hitest wrote: |
Had a girlfriend once who shall we say, nearly arrived at the mere sight of a semaphore in action- easy to please she was... |
Posted: Wed Apr 07, 2021 5:23 pm Post subject: Re: T5 B dropped spindles |
Bub wrote: |
I think there's a VW bearing that swaps directly..can't remember from what though. Maybe Bus or Thing? |
Totally correct. I put B brakes on my bug with dropped spindles and had to change the inner bearings. Now I wish Ida kept the part numbers. _________________ Looking for SP Kadron manifolds...please !!
57 SC
61 356B
GMC SLT 4x4 Dmax
