charleslabri Samba Member
Joined: December 08, 2019 Posts: 615 Location: Nashville/Yosemite
Posted: Tue Nov 24, 2020 4:15 pm Post subject: Spring identification |
I got this van second hand.. id imagine like... MOST of you.
While under it ive done my best to comb every damned inch.
One place that I have been pretty mystified is the suspension.
Clearly I have some trash KYB shocks (ill be changing these out later), but the springs, I cant tell if they are OG or aftermarket.
My guess is that they are stock. Though my ride height (completely gutted/unloaded) is about 17 3/4" hub to fender.
this is a 1981 tin top as far as the VIN is concerned.
Rear
Front
_________________ -------------------------------------------------
An example of my labor in action:
https://www.instagram.com/wileythewesty/
My Build Thread:
https://www.thesamba.com/vw/forum/viewtopic.php?t=730525&highlight= |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7757 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Thu Nov 26, 2020 10:15 pm Post subject: Re: Spring identification |
Yeah, where's Loogy when you need him...? Probably sleeping off his Thanksgiving pie...
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
jimf909 Samba Member
Posted: Fri Nov 27, 2020 12:09 am Post subject: Re: Spring identification |
Check the second post in this thread for oem spring marks... The color is the primary id. The count of stripes is for grouping springs with minor variances w/in color codes. There are a few more threads but this is a good start.
https://www.thesamba.com/vw/forum/viewtopic.php?t=712754
jimf909 wrote: |
I did find this as a starter. Does anyone know if one brown stripe is the same as two noted below?
suebicum wrote: |
Hi
And with the springs, VW has 4 different front 2WD springs.
They are colour coded with rings around the wire.
2x blue, normal
2x brown, camper, ambulance, Carat (normal)
2x green, HD for heavy loads
1x yellow, lowered suspension, xx-Star, LLE, Carat
Michael |
Thanks. |
[/quote] _________________ - Jim
Abscate wrote: |
Posted: Fri Nov 27, 2020 12:30 am Post subject: Re: Spring identification |
Carbon copy of the post above... _________________ - Jim
Abscate wrote: |
Posted: Fri Nov 27, 2020 12:42 am Post subject: Re: Spring identification |
The paint marks are what you're looking for to i.d. oem springs...
You could also look for printed info as with the GW springs below but that seems less likely to find on your springs...
See spring info printed on the spring on the upper coil...
Abscate wrote: |
GreenMachineVW Samba Member
Posted: Tue Aug 24, 2021 10:21 pm Post subject: Re: Spring identification |
I am also trying to identify some rear springs. I have two sets: One set has a single yellow paint mark, the other set has a single blue paint mark. The yellow set has an overall length (or is it height?) of 10 1/2 inches, 8 coils, and the center coil measures 18.5 mm. The blue set is 11 inches, with 7 coils, and a center coil measures 16.5 mm. Can anyone identify the model they probably came with? Is the yellow set stiffer because t has thicker steel, or softer because it has an additional coil?
Thanks for any input you may have. |
DuncanS Samba Member
Posted: Wed Aug 25, 2021 5:06 am Post subject: Re: Spring identification |
My '91 stripped out tintop rides like the axles are bolted directly to the frame. How do I ID 30 year old springs? Wife has a bad back and I need to get her back in the car for some camping. Once had a 2300 pound load and it rode like a Caddy. Speed was like a U-Ridem lawn mower. |
Posted: Wed Aug 25, 2021 8:06 pm Post subject: Re: Spring identification |
GreenMachineVW wrote: |
Hmm. Perhaps someone in the Seattle-Tacoma area knows of a shop I could take my springs to have them rated? |
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6247 Location: Portland OR
Posted: Wed Aug 25, 2021 8:14 pm Post subject: Re: Spring identification |
There is a paint stripe on springs that identifies them if they are VW.
For Reference:
Front Springs:
Blue=Normal
Brown= Carat, Camper, Ambulance
Green=Increased payload
Yellow=30mm lower than normal
Violet=Syncro
The rear spring colors are as follows.
Yellow=Yellow - Normal and for increased payload or heavy duty shocks
Brown=Ambulance (UK)
Blue=Passenger vans
Green=30mm lower
2X green=Syncro
Here's one of my rear springs that is not explained:
_________________ 89 Westy 2.1 Auto |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9939 Location: Orbiting San Diego
Posted: Thu Aug 26, 2021 4:56 am Post subject: Re: Spring identification |
What about it needs explaining?
The color of the dot is the key.
When springs are produced they are not all exactly the same.
VW used the number of dots to grade a particular spring so the left and right springs could be more closely matched.
Any given spring version could have 1,2,or sometimes 3 dots of the same color and when the vehicle was built VW generally matched the number of dots side to side.
Mark
PDXWesty wrote: |
There is a paint stripe on springs that identifies them if they are VW........
ZsZ Samba Member
Joined: December 11, 2010 Posts: 1647 Location: Budapest Hungary, Europe
Posted: Thu Aug 26, 2021 5:34 am Post subject: Re: Spring identification |
OEM has paint marks - can be overpainted
OEM has partnr stamped on the lean-on surfaces - usually rusted away.
From the thickness and the nr of turns in the coil you can make guesses. Probably an OE standard spring _________________ Zoltan
1.9 MTdi 2wd Multivan (ex Caravelle)
Van since 2006, engine since 2008 |
Posted: Thu Aug 26, 2021 8:40 am Post subject: Re: Spring identification |
crazyvwvanman wrote: |
They are stock springs. I've never found a code for the two different colored dots purple and green for rear springs. _________________ 89 Westy 2.1 Auto |
Crankey Samba Member
Posted: Thu Aug 26, 2021 8:51 am Post subject: Re: Spring identification |
An oldy but a goody from the gallery. |
Abscate Samba Member
Posted: Thu Aug 26, 2021 10:04 am Post subject: Re: Spring identification |
The paint and rust discussion is the usual disconnect between the CA and rust belt car experience.
Personally, I just wait for winter, then I know the next one is Spring.
Sorry, I cant help myself. _________________ .ssS! |
