67ctbug Samba Member
Posted: Thu Nov 26, 2020 5:11 pm Post subject: Horn Ground? |
Is the spade connector on the bottom of the steering column tube the horn ground? Mine broke off, I still have the piece, but if it is the ground, can I just ground it elsewhere? _________________ '67 Beetle L41
'71 Westfalia (sold)
'74 Westfalia
‘69 Plymouth
Go Cubs!
World Series Champions 2016
KentPS wrote: |
...or the PO envied the terrorists' bus in "Back to the Future".  |
mukluk wrote: |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 10830 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Thu Nov 26, 2020 8:13 pm Post subject: Re: Horn Ground? |
67ctbug wrote: |
Is the spade connector on the bottom of the steering column tube the horn ground? Mine broke off, I still have the piece, but if it is the ground, can I just ground it elsewhere? |
Yes its a path to ground and no you cant ground it elsewhere...if you plan to use the stock horn ring/button.
Without getting too "into it"...YET.... when you attach the "ground" to the column tube its technically still power and energizes the tube with voltage that is until.... the horn contact at the button/ring is pressed and completes the path to ground.
Add an eyelet to the wire and a small sheet metal screw (or bolt n nut ) through the tube...but not touching the shaft.. be sure your connections are clean and tight.
Fore more in depth horn .. search topics... but start here https://www.wolfsburgwest.com/wired/wired_12_00/wired_12_00.htm _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
Danwvw Samba Member
Joined: July 31, 2012 Posts: 8630 Location: Oregon Coast
Posted: Sat Nov 28, 2020 2:05 pm Post subject: Re: Horn Ground? |
Ah ok thanks! I tried soldering it back on but no dice, so I guess the ring connector and screw will work. _________________ '67 Beetle L41
'74 Westfalia
‘69 Plymouth
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Danwvw Samba Member
