74 Thing Samba Member
Posted: Fri Nov 27, 2020 7:24 pm Post subject: 73 gas heater questions |
I have a few questions about the 73 Thing gas heater:
1. Why are there two outlets for the fresh air intake for the combustion chamber (one in the upper inner fender well area an the other straight down by the rubber grommet for the gas tank breather line that runs back to the charcoal cannister)?
2. Where does the gas line come through the body to attach to the gas heater?
3. Is it necessary to have a "foot" on the exhaust pipe that exits through the fender and if so what are the consequences of running without the foot?
4. What is the gasket material made of for the exhaust pipe so it does not burn or damage the paint?
Thanks! |
Joined: February 21, 2003 Posts: 868 Location: Clifton Park NY Saratoga County
Posted: Fri Nov 27, 2020 9:24 pm Post subject: Re: 73 gas heater questions |
one is a fresh air intake from outside fender
the other is a recirculation fresh air pipe
through small hole under exhaust pipe along with the wiring to gas heater fuel pump
probably a danger of re entering gas exhaust back into passenger compartment
vw engineers designed it this way for a good reason
its a special secret substance derivative unknown just kidding idk
original gas exhaust pipe was asbestos ring pipe to heater _________________ Michael Basso
http://www.thingparts.com
New and Used VW Thing Parts Free advice
CALL 518 630 0173 |
KAmes Samba Member
Joined: February 16, 2014 Posts: 876 Location: Illinois
Posted: Fri Nov 27, 2020 9:35 pm Post subject: Re: 73 gas heater questions |
I don't know the answer to that one.
On mine it comes through a hole along with the fuel pump wires under the heat shield and exhaust pipe.
I have the foot on my thing heater, I think it's to deflect from blowing on the tire. I also have a Webasto gas heater in my '74 beetle and it exits straight through without the foot, doesn't seem to bother anything. The Thing Shop sells the foot and the complete pipe.
https://www.thethingshop.com/GAS-HEATER-EXHAUST-PIPE-ELBOW-NOS/productinfo/181261145A/
https://www.thethingshop.com/HEATER-EXHAUST-PIPE-NEW/productinfo/181261603TTS/
It appears to be maybe some kind of silicone rubber. Thingparts.com has a used one.
https://www.thingparts.com/gas-heater-sealing-ring-exhaust-pipe-to-body/
Edit: I just saw that Mike from Thingparts.com posted above me |
mondshine Samba Member
Joined: October 27, 2006 Posts: 2769 Location: The World's Motor Capital
Posted: Sat Nov 28, 2020 8:39 am Post subject: Re: 73 gas heater questions |
I plan to install my BN4 sometime soon.
What are people using for "alcohol-safe" fuel line from tank to pump, and pump to heater?
What is the I.D. of these hoses?
Are there rubber mounts under the "mounting feet" of the heater body?
Probably more questions once I get into it. (My heater is still in a cardboard box.) |
Posted: Sat Nov 28, 2020 12:34 pm Post subject: Re: 73 gas heater questions |
KAmes,
Can you post a photo of your Webasto install? |
KAmes Samba Member
Posted: Sat Nov 28, 2020 12:40 pm Post subject: Re: 73 gas heater questions |
mondshine wrote: |
I bought the Thing Shop's heater fuel hose, it looks the same as the cloth covered carb hose others sell. It's been ok so far.
https://www.thethingshop.com/FUEL-HOSE-35-MM-GAS-HEATER-TO-FUEL/productinfo/N0203531/
Yes there are rubber mounts, I had original ones but I've bought similar isolation mounts from McMaster Carr before.
Edit: My Webasto heater in the other car came with/uses rigid tubing, looks like vacuum control tubing or 1/8 air shock tubing with short pieces of rubber hose with clamps making the joints. I think an advantage is it has a very small inside diameter making priming the heater faster.
KAmes Samba Member
Posted: Sat Nov 28, 2020 12:57 pm Post subject: Re: 73 gas heater questions |
74 Thing wrote: |
KAmes,
It draws in air on the driver's side and exits on the passenger side. The tube with the fiberglass sock is the exhaust.
Exhaust exits through the fender with a fitting made for boats.
It uses a similar style metering pump.
I put the control in place of the ash tray.
It works easily as well as the BN4 in the thing. |
Posted: Sun Nov 29, 2020 4:33 pm Post subject: Re: 73 gas heater questions |
KAmes wrote: |
Edit: My Webasto heater in the other car came with/uses rigid tubing, looks like vacuum control tubing or 1/8 air shock tubing with short pieces of rubber hose with clamps making the joints. I think an advantage is it has a very small inside diameter making priming the heater faster. |
Kevin-
I have seen that rigid stuff on modern Espar heaters as well, but I chose to avoid the extra connections.
I went with the Flennor (Germany) Multi-Fuel Hose 3.2mm Braided.
It's rated for up to 85% ethanol.
(But that project is still a couple of weeks away.)
That Flennor hose looks very similar to the old style braided hose, except it is rated for modern fuel. I will use the same stuff (but 5mm) for the carburetor. |
KAmes Samba Member
Posted: Sun Nov 29, 2020 4:56 pm Post subject: Re: 73 gas heater questions |
mondshine wrote: |
KAmes wrote: |
Kevin-
I have a new metering pump for a modern Espar heater here in the box, If my fuel pump ever fails I'm gonna experiment. I looked up the Flennor hose just now, that does look like the ticket. I'll remember it next time I need some. Now I have to spend the evening browsing Belmetric for more stuff I didn't know they had. |
Posted: Tue Dec 15, 2020 5:18 pm Post subject: Re: 73 gas heater questions |
I started playing around with my BN4 this afternoon.
I rigged up a test stand and fired it up. It works great with one caveat.
The run-on time is infinite; the blower will never turn off.
The workshop manual says the heater should run on for ~200 seconds, but mine will run on until the battery is dead.
The manual's troubleshooting chart says to replace the quartz rod.
WTF is the quartz rod? Is it internal to the flame switch? No adjustment of the flame switch has any effect, so I returned it to it's original position.
I will be grateful for help on this one.
Thanks, Mondshine |
KAmes Samba Member
Posted: Tue Dec 15, 2020 6:58 pm Post subject: Re: 73 gas heater questions |
The quartz rod is inside the rod below the thermo switch, I would imagine it's what does the expanding and contracting to work the switch.
https://germansupply.com/thermo-switch-bn2-bn4-gas-heater.html
Beats me if they actually have one to sell but it's that thing. I've replaced the top electric switch on mine but never had the rod out. |
KAmes Samba Member
KAmes Samba Member
KAmes Samba Member
Posted: Tue Dec 15, 2020 7:38 pm Post subject: Re: 73 gas heater questions |
I was just thinking trying to remember what the deal with mine was. It was the opposite of yours, it was shutting the heater down early as if it wasn't heating up even though it was. It turned out it was just the switch itself not making contact not a problem with the rod, just thinking out loud. |
Posted: Tue Dec 15, 2020 8:13 pm Post subject: Re: 73 gas heater questions |
Thanks Kevin-
That's about what I was a'figurin'.
I will call Scott in Toronto tomorrow to see if he has a new one.
Worst case, I will take the risk on a used one.
Edit:
My lucky day. Scott in Toronto (German Supply) had a new flame switch for me, so with luck, I will get back to this heater in a week or so. |
doublecanister Samba Member
Joined: September 23, 2008 Posts: 1184 Location: Richmond, Va
Posted: Sun Dec 20, 2020 4:56 am Post subject: Re: 73 gas heater questions |
I know a broken timer switch (the one on the dashboard) will make it stay on too. Mine was broken when I got my 73 but the heater would work I just had to manually turn it off, after cool down it would completely go off. Replaced the timer switch eventually to fix. _________________ ****************************************
2020 - Mustang Eco Boost [High Performance]
1973 - Thing
1966 - Mustang GT- Fastback
1951 - Ford F1 pickup Flathead V8 |
Posted: Sun Dec 20, 2020 7:42 am Post subject: Re: 73 gas heater questions |
Thanks for that Double-
I don't intend to use the timer switch; no room for it on that dash panel with the transplanted gauges from the old car. I will just use a simple on/off switch, powered by the SU circuit (relay) so that the heater will operate only with the key in the ignition switch (like the radio, glove box light and garage door opener transmitter). This is a Summertime car; no real need for me to ever pre-heat it.
Now that I have a new flame switch ordered, I felt more comfortable about taking the old one apart. It is a simple SPDT microswitch (the switch itself is actually made in the USA) that is actuated by expansion of the quartz rod inside a steel tube.
Once I had it apart, the quartz rod (which looks like a glass rod maybe 1/8" diameter and 4" long) moves freely in the steel tube, and appears to be in perfect shape. The microswitch itself, when actuated by light finger pressure, works exactly as it should.
So now, I am in doubt about this whole deal until the new switch arrives.
Time will tell.
Posted: Mon Dec 21, 2020 6:08 am Post subject: Re: 73 gas heater questions |
Hey Mondshine,
oh yeah I forgot that part (being a summer car).
Well, just to mention,
If mine sit too long without use, the heater fuel pump can stick,
also,
with the original dash timer, once on, got hot, then it timed out, it ran a "cool down" mode for "x" minutes depending on temp I believe.
Hope you can sort that out with your new method, I guess it was to be safe and not do a hard shutdown on a super hot heater.
That thing gets freakin hot too, when I run mine I dont run it at the hottest temp, you can cook marshmellows under the dash, make tea, etc.
It made my water bottle water hot!
Well Good luck with it man! I know you'll get it sorted out.
T _________________ ****************************************
1973 - Thing
KAmes Samba Member
Posted: Mon Dec 21, 2020 6:31 am Post subject: Re: 73 gas heater questions |
I use a simple on/off switch with mine, it still runs the cool down cycle after shut off. I'm using a windshield wiper switch. |
Dougster43 Samba Member
Posted: Sat Oct 30, 2021 4:18 pm Post subject: Re: 73 gas heater questions |
Mondshine - did the replacement flame switch fix your issue? My heater just started acting up and I think it may be a flame switch issue. |
