Brake help
loganzillmer
loganzillmer is offline
PostPosted: Sun Nov 29, 2020 5:10 pm    Post subject: Brake help Reply with quote
Hi all. I need some help with my brakes.
I have a '70 Fastback. When I got it, the car had no brake pressure. None of the lines leaked, but I decided to use this issue to launch the first stage of my build project and I restored the whole front end. When I pulled the master cylinder, it was in rough shape, and I found moisture in the frame where the end of the master cylinder meets the pedal rod, so I figured the fluid was leaking out of the master cylinder itself. I ended up replacing the master cyl, all of the front brake lines and hoses, including those going from the reservoir to the master. After this I discovered the previous main line that runs to the T in back didn't like the new master, as it leaked at that connection point, so I replaced the main line as well. No more leaks.
Finally I got to bleeding the brakes. I no longer am getting any air coming out of any corner, but when I depress the brake pedal (with a partner), I get no pressure still. If I pump a couple times rapidly it builds lots of firm pressure, but when I let the pedal all the way out, the first depress of the pedal has no pressure. And unless I pump the pedal quickly to build pressure, I get no pressure.
I have no visible leaks, and no air comes out of any corner when bleeding (Right front, left front, right rear, left rear in that order), but I have no pedal pressure unless I pump quickly.
I am at a loss and could really use some help. Thanks.
old_man
old_man is offline
PostPosted: Sun Nov 29, 2020 5:29 pm    Post subject: Re: Brake help Reply with quote
Did you adjust your rear shoes? If you pull/set the parking brake all the way does the pedal feel change?
loganzillmer
PostPosted: Sun Nov 29, 2020 5:56 pm    Post subject: Re: Brake help Reply with quote
I adjusted the brake shoes so that they are as far out as they can be. I just ran out to the garage to try with the parking brake on. If I set the parking brake, and depress the pedal, the first pump has no pressure, but if I pump it a few times I will get pressure like before, but with the parking brake on, the pressure stays. If I take the parking brake off, the pressure is gone. I then set the parking brake again, first press no pressure, couple pumps build pressure, pressure stays.
What does this mean?
loganzillmer
PostPosted: Sun Nov 29, 2020 6:17 pm    Post subject: Re: Brake help Reply with quote
I can be a little more precise.
With the parking brake set, the first press has no pressure. If I let the pedal all the way out and push it back in, I get some pressure. If I pump the pedal, it builds lots of pressure quickly. If I let the brake pedal out all the way (parking brake still set) some/most of that pressure stays. If I keep my foot pressed on the brake pedal, I don't lose any pressure. If I take the parking brake off with my foot on the pedal, the pressure stays.
With the parking brake off, the first pump of the pedal has no pressure. If I pump it builds pressure quickly. If I hold my foot, the pressure stays. If I let the pedal all the way out, the first pump will have no pressure. If I pump slowly, letting the pedal all the way out, it does not build pressure. If I pump quickly, it builds lots of pressure quickly.
Hope this helps.
Mike Fisher
Mike Fisher is offline
PostPosted: Sun Nov 29, 2020 6:41 pm    Post subject: Re: Brake help Reply with quote
Fig. 9-3 in Chapter 2 of the brown Type 3 Bentley says to bleed fronts before rears! Shocked RF,LF,RR,LR in that order.
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
loganzillmer
PostPosted: Sun Nov 29, 2020 6:55 pm    Post subject: Re: Brake help Reply with quote
I did.
Bobnotch
Bobnotch is offline
PostPosted: Mon Nov 30, 2020 9:32 am    Post subject: Re: Brake help Reply with quote
Make sure you adjust the hand brake cables so that when you lift the handle 3 clicks, it starts activating the rear brakes (they stop turning by hand). This gets the cable adjustment correct.
Then like oldman was trying to say, adjust the rear brakes (at the adjusters) until they are tight to the drum. Then bleed the rest of the air out of the system. Once you've done that, then back off the adjusters so the drum will turn. You can check your work by lifting the hand brake handle about 4 clicks, and the drum shouldn't move. If so, they're set.
By having the rears tight, you eliminate any place to trap air, which sounds like your problem (having to pump multiple times to build pressure). That long line takes a couple of minutes to bleed out, as it humps up at the rear to exit the floor pan. Sometimes I'll jack the rear of the car/pan up to try and get it higher than that point to move the air pocket (get the bleeder screws to the highest point).
If you've replaced the lines and hoses up front, you might have to bleed them several times to get all of the air out of them. They need to be bled first.
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
loganzillmer
PostPosted: Mon Nov 30, 2020 3:14 pm    Post subject: Re: Brake help Reply with quote
Thanks Bob. Iíll try those suggestions. With the drums, I did adjust the shoes as far as they would go, and then backed off just enough to fit the drum on, but Iíll try full adjustment with the drum and see if that changes anything. Is it possible that I have a bad new master cyl? I ordered one from SoCal Imports, non German?
Multi69s
Multi69s is offline
PostPosted: Mon Nov 30, 2020 5:18 pm    Post subject: Re: Brake help Reply with quote
Logan, it sounds like you are doing everything right, or at least close enough to get a decent pedal. The one thing that I stress to my students, is just because something is new, doesn't mean that it will work right. There are three different parts that are made for VWs, where the quality has greatly diminished: Condensers, Ignition Switches, and Master Cylinders.
It really sounds like you got a bad one. I've seen this quite a few times, and tried to help others with it, but most of the time it was a waste of time. In fact yesterday I just ran into someone who is having the exact same problem as you (Market Place purchase). The methods that I have tried to help others: Pump pedal and crack bleeder, vacuum bleed, and reverse bleed, (pushing brake fluid into the caliper, or wheel cylinder towards the master). Nothing would work. I pulled the master apart and in every case the "piston" cups did not have adequate pressure against the bores.
The Master Cylinder is a very simple design. Unless it is totally filled with air, you will get pedal resistance. If you don't, the brake fluid is going pass the cups, and not expanding them against the bore.
69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight=
loganzillmer
PostPosted: Mon Nov 30, 2020 6:24 pm    Post subject: Re: Brake help Reply with quote
I think you may be right. It seems like the only explanation for not having any pressure at all when I push in the brake pedal for the first time.
One last thing I thought of that I am curious about. I was looking on ISP West at the brake line diagram and I noticed that in the diagram they show a hard line coming off the T in back that then meets a hose, and then meets a hard line again, which attaches to the left wheel cylinder. My car has a hose connected to the T, that then meets a hard line that goes to the wheel cylinder. So instead of hard line, hose, hard line, mine is hose, hard line. Nothing leaks, and I don't see where there would be enough room for another line, but I though it was weird that a hose is connected to the T instead of a hard line? Could this be part of the problem?
BobR24
BobR24 is offline
PostPosted: Sun Jan 31, 2021 11:10 am    Post subject: Re: Brake help Reply with quote
I am having the same issue. Was this ever resolved?
Bobnotch
Bobnotch is offline
PostPosted: Sun Jan 31, 2021 11:23 am    Post subject: Re: Brake help Reply with quote
A lot of this is the IRS/swing axle differences and their respective parts.
Tram wrote:
Tram wrote:
Bobnotch
Bobnotch is offline
PostPosted: Sun Jan 31, 2021 11:29 am    Post subject: Re: Brake help Reply with quote
What issue is that? Most times no pedal pressure can be resolved by adjusting the rears almost tight, bleeding the right front first, then the left front, followed by both rears, then slack off the rear adjusters. This is because you want to move the fluid/air out of the bleeder screw before you back off the adjusters (so you're no over traveling the wheel cylinders). VW (Bentley) says disc brake cars need the fronts bled first.
Tram wrote:
Tram wrote:
