charleslabri Samba Member
Joined: December 08, 2019 Posts: 615 Location: Nashville/Yosemite
JimSyncrogr Samba Member
Posted: Mon Nov 30, 2020 10:57 am Post subject: Re: Walls/Pillars carpeting |
If you go off-road avoid the carpet, because the dust comes in and never get cleaned! You don’t want to breathe it!! |
Vashon Samba Member
Joined: September 23, 2012 Posts: 200 Location: Vashon Island
Posted: Mon Nov 30, 2020 11:18 am Post subject: Re: Walls/Pillars carpeting |
I have a boat yard and my wife has a marine canvas and upholstery business . We have used miles of hull liner on boats and I have used it in a couple of vanagons . I used it in my van to line the glove box and storage compartments and I lined a friends pop top with it and that worked very well. However it may be a bit to thick and fuzzy to the pillars etc. with. When I get to the shop today I,ll put a sample under the window rubber on my van and post a photo. my van just has painted pillars etc. so it will be an easy trial .
BCgee Samba Member
Joined: February 22, 2012 Posts: 126 Location: Montana
Posted: Mon Nov 30, 2020 1:17 pm Post subject: Re: Walls/Pillars carpeting |
I used Flex Form, a marine style carpet, to finish out the interior of the NAHT hightop and replace the old vinyl below. Its tough but can be stretched to fit angles. With the persuasion of a flat edge bar and help of 3m aerosol glue it went on to the pillars and ceiling no problem. Also easy to clean/vacuum.
_________________ 1987 SVX Syncro Hightop |
Vashon Samba Member
Posted: Mon Nov 30, 2020 1:23 pm Post subject: Re: Walls/Pillars carpeting |
https://www.thesamba.com/vw/gallery/pix/thumbnails/2118118.jpg
Yes, it will fit under the rubber, I could make this work. Hull liner could very well work in this application depending on your skill level and what your vision is. But.. hull liner would not be my first choice in this application for a number of reasons.
It is rather thick for this purpose and makes it look like a american conversion van from the early 20's .
The edges not covered (like the door jams) will be hard to trim neatly. all though that is not an impossible job. just tricky.
Cleaning and durability might well be a issue if your van sees hard use.
Honesty I have not done this project on a van, but might recommend a micro suede or micro what ever fiber that is a bit thinner and cleanable but still has enough stretch to make the corner moldings smooth.
Good Luck, Tim
Joined: April 29, 2015 Posts: 704 Location: Berkeley Ca
Posted: Mon Nov 30, 2020 4:01 pm Post subject: Re: Walls/Pillars carpeting |
[/quote]
Tim van looks killer any more pictures? |
