674me2enjoy Samba Member
Posted: Tue Dec 01, 2020 11:52 am Post subject: Recommendations:67 Bug 1600cc Solex 30/31 problems with stalling |
I have a 67 Bug with a 1600cc build that was done a few years ago. Presently has a unknown aftermarket single port intake with some aftermarket spacer with a Solex 30/31 PICT carb with a stock 67 Distributor. I just recently had the valves checked/adjusted which check out good. The tech said the “THE ENGINE WAS FALLING ON ITS FACE UNDER ACCELERATION” or stalling at first, which he felt like was due to a mismatch of carburetor and distributor and intake manifold. He recommended possibly upgrading carb to a EMPI 34 PICT-3 or continue using the Solex 30/31 carb (Like new) and going to a better Intake manifold, possibly a dual port and upgrading to an electronic distributor (example Pertronix SVDA #186504) along with a better coil (blue coil or Pertronix 40,000 volt coil.) The engine was rebuilt about 2500 miles ago with a new 1600 single port case, new heads, reconditioned cam (specs unknown), Solex 30/31 carb etc. Use of stock distributor with points.
Recommendations? Not wanting to go back into the engine. Would like to work with what I have as far as interior parts. Would like to get the most performance out of some exterior changes with reliability. Wouldn’t rule out going to twin Webers 40s possibly. Suggestions....thank you
sgmalt46 Samba Member
Joined: April 20, 2005 Posts: 1296 Location: south san francisco
Posted: Tue Dec 01, 2020 12:38 pm Post subject: Re: Recommendations:67 Bug 1600cc Solex 30/31 problems with stalling |
you need a svda dist. that stock one is vacuum only .works sweet with the stock 30pict-1 with power jet. the 30/31 does not pull enough vacuum . your (TECH) should know that . I run a german 009. works for me. with the 30/31.i know will get yelled at. _________________ 55 deluxe 23 window bus
64 crew cab
55 rag top beetle
66 beetle
71 square back (sold) ! good luck with it Henry!
46 beetle 552nd royal army service corps CCG |
glutamodo The Android
Joined: July 13, 2004 Posts: 26325 Location: Douglas, WY
Posted: Tue Dec 01, 2020 12:54 pm Post subject: Re: Recommendations:67 Bug 1600cc Solex 30/31 problems with stalling |
The above comment is WRONG.
The traditional vacuum advance fitting on the Brosol H30/31PICT is blended vacuum intended for a vacuum-only distributor.
This engine has a vacuum-only distributor. IT IS A MATCH.
The only fitting suitable for SVDA on this carburetor is the angled one all the way on the right side of the carb, and that is not the one being used here. _________________ Andy T.
Posted: Tue Dec 01, 2020 1:08 pm Post subject: Re: Recommendations:67 Bug 1600cc Solex 30/31 problems with stalling |
Andy so your saying the Solex 30/31 is a match for the stock vacuum distributor? Also your saying the location the the vacuum adv hose is connected presently on this carb (left side) needs to be switched to the angled one on the right side of the carb towards the base?
anthracitedub Samba Member
Posted: Tue Dec 01, 2020 1:37 pm Post subject: Re: Recommendations:67 Bug 1600cc Solex 30/31 problems with stalling |
Have you determined if the accelerator pump is working properly and the spray nozzle is positioned correctly in the carb?
You’re gonna get in trouble by the samba policia for your fuel filter location and lack of security on the fuel lines😁
I’d also recrimp that power wire on the left side of the carb, if that slips out... there’s potential for some issues. |
Posted: Tue Dec 01, 2020 2:19 pm Post subject: Re: Recommendations:67 Bug 1600cc Solex 30/31 problems with stalling |
Accelerator Pump working properly and spray nozzle positioned correctly. I will work on the other noted issues. |
Posted: Tue Dec 01, 2020 2:33 pm Post subject: Re: Recommendations:67 Bug 1600cc Solex 30/31 problems with stalling |
674me2enjoy wrote: |
Andy so your saying the Solex 30/31 is a match for the stock vacuum distributor? |
Yes that is correct. Provided the distributor's vacuum canister is still functional. The following might be considered "too much information" but I talk about it in depth here: https://www.thesamba.com/vw/forum/viewtopic.php?t=185095 _________________ Andy T.
Posted: Tue Dec 01, 2020 2:41 pm Post subject: Re: Recommendations:67 Bug 1600cc Solex 30/31 problems with stalling |
Thanks I will switch the vacuum hose. Hopefully it will have some affect on the carburetor stalling out. I guess you feel comfortable with what I have and you would suggest trying this out for awhile to see how it works out before changing out the distributor etc.
Posted: Tue Dec 01, 2020 3:08 pm Post subject: Re: Recommendations:67 Bug 1600cc Solex 30/31 problems with stalling |
I still have a flat spot after warming the engine up, when I accelerate. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31380 Location: Hot Arizona
Posted: Tue Dec 01, 2020 3:34 pm Post subject: Re: Recommendations:67 Bug 1600cc Solex 30/31 problems with stalling |
sgmalt46 wrote: |
I run a german 009. works for me. with the 30/31.i know will get yelled at. |
I won't yell at you - I have same thing in my 1970 VW: vintage German 009 distributor and Solex 30/31PICT3 carburetor on an adapter to the dual port manifold, 1600cc, built by me in 2016-2017. Runs fine. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Tue Dec 01, 2020 3:40 pm Post subject: Re: Recommendations:67 Bug 1600cc Solex 30/31 problems with stalling |
The only difference is i have a single port. I will figure it out eventually! Thanks |
Posted: Tue Dec 01, 2020 4:00 pm Post subject: Re: Recommendations:67 Bug 1600cc Solex 30/31 problems with stalling |
I’ve found from some research that the adapter plate thats beneath my Solex 30/31 carb was intended to be used only on a dual port Intake which I don’t have! I assume this should be removed? |
Cusser Samba Member
Posted: Tue Dec 01, 2020 4:36 pm Post subject: Re: Recommendations:67 Bug 1600cc Solex 30/31 problems with stalling |
674me2enjoy - YOUR engine DOES have a dual port intake manifold, we can all see the boots in YOUR photo.
So you DO have dual port cylinder heads. The adapter under the 30/31 carb mates the 30/31 to the larger port/larger hole spacing of the dual port manifold center section. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Tue Dec 01, 2020 4:54 pm Post subject: Re: Recommendations:67 Bug 1600cc Solex 30/31 problems with stalling |
I understand what your seeing but someone has put a dual port upper intake then it goes to a single port lower intake outlet towards the heads.
Posted: Tue Dec 01, 2020 5:51 pm Post subject: Re: Recommendations:67 Bug 1600cc Solex 30/31 problems with stalling |
Thanks I will switch the vacuum hose. Hopefully it will have some affect on the carburetor stalling out. I guess you feel comfortable with what I have and you would suggest trying this out for awhile to see how it works out before changing out the distributor etc. |
The stock location of the vacuum hose is correct for "SVA" vacuum-only distributors on the H30/31 carb. Don't move it. Just make sure the hose and the vacuum canister don't leak. _________________ Andy T.
Posted: Tue Dec 01, 2020 6:25 pm Post subject: Re: Recommendations:67 Bug 1600cc Solex 30/31 problems with stalling |
Sounds good. I’m planning on going back to an original Solex German 30-PICT 1 carb and a stock EMPI intake manifold. Which I feel like will be a better match with the stock distributor.
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Tue Dec 01, 2020 8:17 pm Post subject: Re: Recommendations:67 Bug 1600cc Solex 30/31 problems with stalling |
If your vacuum canister was bad you'd know it! You'd have exactly 0 degrees of advance and would only run ok at idle. You should verify that you are gettting close to 30 degrees of maximum advance.
The Samba policia have beaten the fuel filter thing to death. Actually that stock cloth covered hose grips the fuel pipes and the filter really well., the warning you'll get is overated IMHO. I haven't run one of those filters in years on three VW's and I've had no issues. There are filters in your gas tank and in your fuel pump, if it has a screw on the lid.
You might want to consider the stock German intake manifold and a restored German Solex 30 PICT carburetor rather than Chinese made Empi. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
Cusser Samba Member
Posted: Tue Dec 01, 2020 9:03 pm Post subject: Re: Recommendations:67 Bug 1600cc Solex 30/31 problems with stalling |
I understand what your seeing but someone has put a dual port upper intake then it goes to a single port lower intake outlet towards the heads. |
Aha ! I'm incorrect. You have a dual port center section with single port ends, have seen those advertised, never saw a picture of them before.
I wonder if the heat riser part is un-clogged in that center section and connected and operable.
Have you considered using a 1500cc/1600cc single port intake manifold and ditch the 30/31 adapter? Because I wonder if you have vacuum leak at the adapter or at the rubber boots????
I ask this because my own had a vacuum leak at the right rubber boot, and ran way better after I sealed that. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Wed Dec 02, 2020 7:39 am Post subject: Re: Recommendations:67 Bug 1600cc Solex 30/31 problems with stalling |
I checked my advance, I’m getting close to 30 degrees maximum advance. I also checked the adapters and rubber boots for air leaks! Sure enough there was air leaks at the boots and the adapters. Repaired the leaks, definitely helped out on the flat spots. Still planning on going back to a stock single port intake and a stock Solex German 30Pict-1 carb. Thanks again for all the suggestions.
FL-Frank Samba Member
Joined: August 08, 2015 Posts: 823 Location: Jupiter, Florida
Posted: Wed Dec 02, 2020 8:24 am Post subject: Re: Recommendations:67 Bug 1600cc Solex 30/31 problems with stalling |
I used to experience similar issues with my ‘67 Beetle. When I bought it 5 years ago, it had an incorrect carb, distributor, and fuel pump and plugged manifold tubes.
So, I sourced a restored German Solex 30Pict1 carb, a restored 205K distributor, a restored Pierburg pump, and a restored 701k manifold...all from the classifieds here.
Once I installed all of these parts (along with a correct thermostat which was missing), the car runs great!
IMO, although restored original parts will probably cost more than the similar aftermarket parts available, the quality and longevity of the restored original parts are far superior! _________________ “Tinker Toy” 1967 Savannah Beige Beetle Sedan...........Mostly Original Survivor
“Fritz” 1964 Gulf Blue Karmann Ghia Coupe...Complete Pan-Off Restoration SOLD |
