bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4351 Location: United States, Iowa
Posted: Thu Jun 17, 2021 11:38 am Post subject: Re: HERE WE GO!! .... 1990 Tintop! |
djkeev wrote: |
I am getting comments almost daily about the Van. We’ve even got some work leads because of it!
It is better than a billboard!
Dave |
Get the company to pony up a few $$$'s for a Wrap with your logo, and .com on it. THEN you'll get some work _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32633 Location: Reading Pennsylvania
Posted: Sat Jun 19, 2021 6:32 pm Post subject: Re: HERE WE GO!! .... 1990 Tintop! |
If you recall one of the used stub axles I had purchased was shipped to me as "good used" even though the nut would only thread on 1/2 turn or so by hand then lock up solid.
I ended up spending hours filing the threads with my limited on hand tool supply to get the nut to thread on by hand past the cotter pin holes.
Even then it was less than perfect and I'm not at all happy about it.
I contacted the seller about the deformed threads, Jan Blair & Son used auto parts, who told me that tight nuts are normal and to use a heavy duty impact wrench to get the nut on.
I replied that No, deformed threads are a sign of a deformed and abused stub axle.
An axle with the threads all stretched and deformed is garbage.
He offered to replace the axle if I picked up the shipping or he would refund me the axle cost.
I still need a good stub axle so I agreed to pay shipping if he promised a good stub axle.
Well it arrived.
The nut spins on freely, there is no sign of a die run over it that I can see.
All is well that ends well.
He is a responsive seller, has fair prices and ships quickly.
I would buy from him again, just be very clear about what you expect, as in the case of the stub axle threads.
Ghia
Vanagon
Beetle
DuncanS Samba Member
Posted: Sun Jun 20, 2021 5:36 am Post subject: Re: HERE WE GO!! .... 1990 Tintop! |
Thanks so much for the follow up. He is now on my list. |
danfromsyr Samba Member
Posted: Mon Jun 21, 2021 5:13 am Post subject: Re: HERE WE GO!! .... 1990 Tintop! |
a bit excessive to carry as a roadside emergency item.
engines fail far more frequently and w/o warning compared to a rear wheel bearing.
add in the fun fact of having to pop apart the rear backing plate as it's side positionally dependent.
bearing give plenty of notice before failure. _________________
Abscate wrote: |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16508 Location: Brookeville, MD
Posted: Sat Jun 26, 2021 6:51 am Post subject: Re: HERE WE GO!! .... 1990 Tintop! |
djkeev wrote: |
My Van had a friend come and visit yesterday.
This was the first Vanagon he has seen in quite awhile except for his step brother dbaron........
Sadly I failed to take any photos but dobryan was here for a few hours in his subie powered pop top.
He really liked my Hauler Rack.
And...... we failed on sending him home ice cold....... but we have a plan.........
Dave |
Thanks for the try Dave. I can’t believe we did not take one pic. _________________ Dave O
The Western Syncro build
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4800 Location: Bemidji, MN
Posted: Fri Jul 09, 2021 11:17 am Post subject: Re: HERE WE GO!! .... 1990 Tintop! |
djkeev wrote: |
Dave |
so. you still never saw them both *at the same time*, correct? _________________ -dan
www.thefixitworkshop.com |
Abscate Samba Member
Posted: Sat Jul 10, 2021 4:01 am Post subject: Re: HERE WE GO!! .... 1990 Tintop! |
DanHoug wrote: |
djkeev wrote: |
Dave |
so. you still never saw them both *at the same time*, correct? |
_________________ .ssS! |
Posted: Sun Jul 11, 2021 6:39 am Post subject: Re: HERE WE GO!! .... 1990 Tintop! |
I am gathering what I consider essential parts to carry on an 8,000 mile journey I have planned across the Northern USA.
I don't want to be in places like Winnett Mt on Mt 200 broken down and helpless.
Parts are getting hard if not impossible to get in this post-Covid lock down era.
The World supply chain is quite simply broken.
I have already gathered many parts that now show as out of stock and have unknown restock dates.
An item yet in my inventory is a Water Pump.
There is much chatter about which brand is less bad of the readily available brands..... Hepu, Graf or Meyle.
Searching for other historically trust worthy brands I stumbled upon an in stock Gates Pump.
It was a few $$’s more and no free shipping but I figured "why not?"
I am running a Hepu pump with only 6,500 miles on it but I read horror stories of short pump lives.
My belt is adjusted loose, I get a bit of squeal on a cold start.
I may never need this pump but hey! I will have it.
I've read advice to soak a new pump in antifreeze before installation to lubricate the seal.
I've also read that older dirty coolant contributes to short pump life.
Anyway here is the Gates part......
Gates #gat41153
Once it arrives I'll check it out and post my findings. If it is simply a Meyle in a Gates box, it will be going back!
Ghia
Vanagon
Beetle
Posted: Sun Jul 11, 2021 3:53 pm Post subject: Re: HERE WE GO!! .... 1990 Tintop! |
A four wheel aloignment before you hit MT 200? |
dabaron Samba Member
Joined: June 21, 2018 Posts: 2561 Location: Philly, mang
Posted: Mon Jul 12, 2021 8:21 am Post subject: Re: HERE WE GO!! .... 1990 Tintop! |
djkeev wrote: |
dobryan wrote: |
When was the last alignment done? |
STEVE!
Calling Steve!
Can you answer this?
Me? In 6,500 miles ........ Never........
my answer is if you didn't do it, consider it to never have been done. you get what you pay for _________________ 1991 Vanagon GL Camper
"burnin oil and cookin coils" -- Destructo
BiWerks Design, LLC |
Posted: Mon Jul 12, 2021 8:22 am Post subject: Re: HERE WE GO!! .... 1990 Tintop! |
djkeev wrote: |
One is far more good looking than the other.
you are talking about the Vanagons, right? _________________ 1991 Vanagon GL Camper
