Loretta007 Samba Member
Joined: December 03, 2020 Posts: 5 Location: Hampshire
Posted: Thu Dec 03, 2020 9:54 pm Post subject: Type 3 Oil Leak |
My otherwise leak free Type 3 Single Port has developed a slight oil seep from the Main Bearing Stud nearest the Flywheel. Is it safe to remove the nut and possibly replace it with one of those self sealing nuts without having to strip the engine |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5364 Location: Lefty, CA
KTPhil Samba Member
Posted: Fri Dec 18, 2020 4:24 pm Post subject: Re: Type 3 Oil Leak |
If it is one of the face-sealing nuts, there are opinions on this:
- VW tried it but found they tended to dig into the case where they seal, especially if over-torqued.
- The stock washer, thick because it is intended to spread the load, can't be used with the sealing nut, since it defeats its sealing function.
- Some mistake a sealing nut for a nylock nut, which does not seal. These are not the same:
Posted: Fri Dec 18, 2020 5:00 pm Post subject: Re: Type 3 Oil Leak |
KTPhil wrote: |
Good right up and pics phil. However, the teacher in me asks, can you explain / show the difference between a sealing nut and a nylock?
I wonder if they have always been called nylock? My dad worked as a civilian during the Korean, and Vietnamese wars at aircraft depots, upgrading various aircraft avionics. He told me that they were developed for aircraft, and were designed so that even if the nut worked loose, it wouldn't fall off causing a catastrophic event. They just called them aircraft nuts. _________________ 69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight= |
KTPhil Samba Member
Posted: Fri Dec 18, 2020 5:08 pm Post subject: Re: Type 3 Oil Leak |
On a Nylock, the plastic grips the bolt/stud threads, keeping it from loosening.
On a sealing nut, the plastic is on the face the the nut gets tightened against (in this case the engine block) to form a seal. |
Posted: Thu Jan 07, 2021 12:55 am Post subject: Re: Type 3 Oil Leak |
On the subject of self sealing nuts ( not Nylocs ). Are we sure that the sealing face does goes towards the block ? I have seen videos of so called “ VW Expert” engine builders installing them the other way round (YouTube vwdarrin). I suppose the torque loading would be compromised when compressing the rubber if it were to be installed facing the block. Anyway, they are not available here in the U.K. |
Posted: Thu Jan 07, 2021 1:11 am Post subject: Re: Type 3 Oil Leak |
YouTube. vwdarrin How to build a stock 1600 vw motor part 2. 9:10. |
KTPhil Samba Member
Posted: Thu Jan 07, 2021 10:18 am Post subject: Re: Type 3 Oil Leak |
Loretta007 wrote: |
They were probably nyloks, not sealing nuts. There is no value to putting a sealing nut on backwards! |
Posted: Thu Jan 07, 2021 10:26 am Post subject: Re: Type 3 Oil Leak |
In his videos (vwdarrin) he makes it clear that he uses the red self sealing nuts with silicone under the washers and then the nut with the seal uppermost to prevent oil from seeping up the threads. I can see his point as the correct torque would not be applied when having to squash a rubber seal against the crankcase. |
KTPhil Samba Member
Posted: Thu Jan 07, 2021 12:33 pm Post subject: Re: Type 3 Oil Leak |
Post a link? That sounds wrong! |
KTPhil Samba Member
Posted: Thu Jan 07, 2021 1:57 pm Post subject: Re: Type 3 Oil Leak |
The video is a little too blurry to tell for sure, but those look like nyloks to me.
He is using "sealer" on both the stud threads and the undersides of the washers. This should provide complete, albeit messy sealing, and so the nut is a nylok in order to stay tight, not to seal.
If he was using sealing nuts to seal, he wouldn't have applied sealer, and he would have installed them face down, sans washers. This was recommended for a time, but it was found the hard steel nuts cut into the case without a washer, causing poor torque retention and leaks, and so this practice was discontinued. |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13281 Location: Tejas!
Posted: Thu Jan 07, 2021 3:38 pm Post subject: Re: Type 3 Oil Leak |
I thought that name sounded familiar - yep, sex offender and should have his youtube page pulled. he's a hack anyways, lots of sealant where you don't need it, etc. watch out who you consider an x-purt _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
