Help identifying CV damage
Page: Previous  1, 2
Abscate
Abscate is offline
PostPosted: Sun Dec 06, 2020 7:35 am    Post subject: Re: Help identifying CV damage Reply with quote
charleslabri wrote:
Well dang. Silly me pulled Em without marking.
What’s this going to do to me?
Nothing. Go back and match the marks of crud up . You just need to know which axle (twoCVs plus shaft) went on which side of car, not their exact position
.ssS!
djkeev
djkeev is offline
PostPosted: Sun Dec 06, 2020 7:48 am    Post subject: Re: Help identifying CV damage Reply with quote
Opinions are all over the map on location marking.
Many feel, as I do, that knowing where the CV joint came from is important.
Many feel, again as I do, that knowing the original relationship of the cage and the star is important and what cage goes with what star.
Some feel that every ball location is important within the joint. I'm on the fence on this one but could easily slide into agreement.
Some feel that the order and placement of components doesn't matter, cleaning them and repacking is what truly matters most.
There is an "in" and an "out" on each joint.
It does matter also that keying both joints properly on one shaft is important to prevent possible binding on rotation.
Do some googling, read up on the opinions and decide for yourself what is important to you.
https://www.thesamba.com/vw/forum/viewtopic.php?t=568247
https://www.thesamba.com/vw/forum/viewtopic.php?t=432312
Dave
Ghia
Vanagon
Beetle
charleslabri
charleslabri is offline
PostPosted: Sun Dec 06, 2020 10:24 am    Post subject: Re: Help identifying CV damage Reply with quote
I’ve been doing a bunch of reading on the placement of the CV parts in orientation of the flange/shaft. That all makes sense, per square there.
The axle shaft is just an axle shaft right? There’s no in/out left right on it is there?
An example of my labor in action:
https://www.instagram.com/wileythewesty/
My Build Thread:
https://www.thesamba.com/vw/forum/viewtopic.php?t=730525&highlight=
djkeev
djkeev is offline
PostPosted: Sun Dec 06, 2020 10:36 am    Post subject: Re: Help identifying CV damage Reply with quote
Automatic? Yes, two different lengths.
Stick shift? No, both are the same
Dave
Ghia
Vanagon
Beetle
charleslabri
PostPosted: Sun Dec 06, 2020 1:46 pm    Post subject: Re: Help identifying CV damage Reply with quote
cool. yeah manual
My Build Thread:
charleslabri
PostPosted: Sun Dec 06, 2020 1:53 pm    Post subject: Re: Help identifying CV damage Reply with quote
since i didnt mark them, i noticed this here, which lines up with my having bearing balls of 2 different sizes.
I am assuming one of these cages is the loebro and one is the OEM, anyone identify?
Notice one of the bearing cages have these notches
My Build Thread:
djkeev
djkeev is offline
PostPosted: Sun Dec 06, 2020 1:57 pm    Post subject: Re: Help identifying CV damage Reply with quote
VW OEM joints generally have VW part numbers stamped on them.
Dave
Ghia
Vanagon
Beetle
Wildthings
Wildthings is offline
PostPosted: Sun Dec 06, 2020 2:00 pm    Post subject: Re: Help identifying CV damage Reply with quote
The cages certainly need to match the ball sizes. As far as the one ball that looks pitted, I don't think I would run it or any others that look that rough.
Abscate
Abscate is offline
PostPosted: Sun Dec 06, 2020 3:05 pm    Post subject: Re: Help identifying CV damage Reply with quote
Groove ball groove tolerance is important , don’t mix these if you can avoid. Yes, I have mixed and no explosions occurred.
Cage tolerance is much looser as these more just hold ball position than take thrust forces. I’ve mixed many cages on CVS without I’ll effects, you can say that cage free joints are happier, just like hens.
.ssS!
charleslabri
PostPosted: Sun Dec 06, 2020 4:30 pm    Post subject: Re: Help identifying CV damage Reply with quote
for posterity, the older tightened cage (the ones with the pronounced cages) were the older style ones.
My Build Thread:
fxr
fxr is offline
PostPosted: Sun Dec 06, 2020 7:13 pm    Post subject: Re: Help identifying CV damage Reply with quote
A bit of thought (it's not 'intuitive'!) will let you position and use the CVs so the thrust is on the unworn sides - in this case it may not be so essential to keep all the bits in the same relative place as they were before.
But remember to keep track of them next time!
Jim Crowther
Vespa GTS 300
AZ Landshaper
AZ Landshaper is offline
PostPosted: Sun Dec 06, 2020 7:25 pm    Post subject: Re: Help identifying CV damage Reply with quote
Id say buy new lobros and get on with life. When these dont ride well youll be back in the grease, Ive reloaded some real shitty parts in the past but I was en route and just needed to get someplace. If your home and can float them. Buy new ones and do the job once. Measure the shafts and see if new joints will fit 1st. Its one of those jobs that sucks to do twice or on the side of the road. Too much damn grease to contend with.
Support Small Business.
85 Weekender w/ EJ22
Previously
64, 71, 72, 73, 76, 81, 84, 85 & 87 Campmobiles and Westfalias
and a 67 bug.
charleslabri
PostPosted: Sun Dec 06, 2020 9:06 pm    Post subject: Re: Help identifying CV damage Reply with quote
Yeah, ordered a set from burley. Gonna use these as backups
My Build Thread:
Page: Previous  1, 2
Page 2 of 2
