leoasman Samba Member
Joined: August 14, 2020 Posts: 94 Location: San Diego
Posted: Sun Dec 06, 2020 9:23 pm Post subject: 68 fastback |
Didn’t want to start tearing into the squareback, so I HAD to get another to do a full project on. This is all very addictive! So far the tear down has gone smoothly. Pans are toast and a few rust spots on the body. Looking forward to learning a bunch along the way.
andybla Samba Member
Posted: Mon Dec 07, 2020 1:04 am Post subject: Re: 68 fastback |
the box of pandora has been opened |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22425 Location: Kimball, Mi
Posted: Mon Dec 07, 2020 10:45 am Post subject: Re: 68 fastback |
andybla wrote: |
Yup. It does look fairly straight though. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
galencurrington Samba Member
Joined: March 16, 2004 Posts: 426 Location: bowling green, ky
Posted: Mon Dec 07, 2020 11:50 am Post subject: Re: 68 fastback |
The rabbit hole just gets deeper and usually deeper than you think but it's all worth it in the long run. I'm doing a pan off restore on a 69 auto square right now. A pan off is really not that bad you can get to everything a lot easier. _________________ "asking and getting are two different things" |
Posted: Mon Dec 07, 2020 7:33 pm Post subject: Re: 68 fastback |
I’m definitely looking forward to it! |
Posted: Tue Dec 08, 2020 11:44 am Post subject: Re: 68 fastback |
galencurrington wrote: |
The rabbit hole just gets deeper and usually deeper than you think but it's all worth it in the long run. I'm doing a pan off restore on a 69 auto square right now. A pan off is really not that bad you can get to everything a lot easier. |
Yup, and it allows you to get to everything, even stuff you didn't plan on. I've done a couple over the years, and really it's the only way to go. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Thu Dec 10, 2020 11:11 am Post subject: Re: 68 fastback |
Most of the tear down is complete. I’ve bagged and labeled all the misc bolts and screws and took lots of reference pics. Like you guys said, I’ve found more rust than expected, but I’m pushing forward. Now I need to build a cart for the body and get it off.
My question is this. After I get all the screws and bolts off what is left to disconnect. I got the steering coupler disconnected since I didn’t pull the column off yet. The brake lines are disconnected in the front. No engine dipstick. Anything I’m missing?
Thanks,
Leo |
Posted: Thu Dec 10, 2020 1:45 pm Post subject: Re: 68 fastback |
Looks not that bad in the pictures.
If everything is loose, all that is left are the pan bolts and also 2 front and 2 rear around the suspension
in the front, under the gas tank next at shock absorber position
in the back, just behind the cross, next to the wheel wells |
Clatter Samba Member
Joined: September 24, 2003 Posts: 7544 Location: Santa Cruz
Posted: Thu Dec 10, 2020 3:05 pm Post subject: Re: 68 fastback |
Whoo! Brings back some memories!
Make sure to take out the shifter - it seems to hang things up.
You go brother. _________________ Bus Motor Build
What’s That Noise?!? |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34013 Location: Conejo Valley, CA
Posted: Thu Dec 10, 2020 4:46 pm Post subject: Re: 68 fastback |
heater and throttle cables? |
Posted: Thu Dec 10, 2020 6:01 pm Post subject: Re: 68 fastback |
andybla wrote: |
Thanks Andy! I’ve gotta work this weekend, but I’m hoping to tackle the removal next week! |
Posted: Thu Dec 10, 2020 8:25 pm Post subject: Re: 68 fastback |
KTPhil wrote: |
I’ll double check that, thanks! The engine was out when I got it. I’ve got it sitting in the garage at the moment. |
Posted: Fri Dec 11, 2020 10:05 am Post subject: Re: 68 fastback |
KTPhil wrote: |
Speedometer cable? Brake rez hoses? Brake light switches?
Here's where ALL of the pan bolts are.
I hope this helps. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Fri Dec 11, 2020 1:30 pm Post subject: Re: 68 fastback |
Bobnotch wrote: |
KTPhil wrote: |
I hope this helps. |
Thanks Bob! I’ve got all that disconnected. I think I’m ready to go. I actually copied that pic from another time you posted it. Can I ask what book that diagram comes from?
Leo |
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4921 Location: Southern AB
Posted: Sat Dec 12, 2020 9:24 am Post subject: Re: 68 fastback |
leoasman wrote: |
Bobnotch wrote: |
KTPhil wrote: |
Leo |
It's out of the big Blue Bentley manual. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Sun Jan 03, 2021 3:16 pm Post subject: Re: 68 fastback |
How do you guys accomplish drilling out tight spot welds? I’m trying to remove the cross brace/kick plate and cant seem to figure out how to make it happen. It’s such a tight area and I can’t get the drill in the right spot? Any tips
Thanks,
Leo
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Mon Jan 04, 2021 9:00 am Post subject: Re: 68 fastback |
Just weld in 1.5" repair pieces along the bottoms.
Not really necessary to gouge up the tunnel & heater channels for a complete kick panel replacement, if you even have skills to duplicate it? _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Mon Jan 04, 2021 9:20 am Post subject: Re: 68 fastback |
maybe from the backside, and if it's a really hard to reach spot, i just take the little multi tool and cut away around the spot weld or grind away the spot weld with a dremel grinder |
Posted: Mon Jan 04, 2021 11:02 am Post subject: Re: 68 fastback |
andybla wrote: |
Yup, this is one of those areas that unless your OCD won't let go, it doesn't have to be perfect. Maybe even sacrifice a small part to keep the larger part whole. It really depends on how visible that spot is. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
