Cusser Samba Member
Joined: October 02, 2006 Posts: 31361 Location: Hot Arizona
Posted: Tue Dec 08, 2020 1:31 pm Post subject: My 1971 Super Beetle Convertible Thread |
OK, bought this in 1976 from original owner, was Clementine Orange, had a cheap replacement black top already. In 1978 I had the convertible painted white by Maaco for $140 to match my 1970 sedan. In 1980 I lent the convertible to a girlfriend, and she Armor-All'd the top before returning it to me, and the top cracked soon after. So I asked the VW who did their tops and got a replacement top fitted and new boot made by that shop.
Have had so few issues with it that I haven't detailed any on The Samba. About 25 years ago I replaced the idler bushing, 4 tie rod ends, and front bushings to fix the dreaded "Super Beetle steering wheel shimmy" issue.
In 2005 I installed the 1835cc DP engine that had been in my 1970 sedan since 1986. It has a single Weber 40DCNF and a German 009, stock cam, and Quiet exhaust. The engine runs a lot better than it looks.
Two weeks ago I noticed that my 20+ year-old lifetime warrantied Autozone brake master cylinder was leaking, saw fluid on VW pan underside and under the MC boot.
The two electrical connectors were also a little loose on the brake switch terminals and are decades old; I've got new German ones on order from Samba member Heimlich, see classifieds https://www.thesamba.com/vw/classifieds/detail.php?id=2372844
The driver side front wheel was removed, VW on jack stands. The master cylinder reservoir was emptied, then those switches were removed using a 24mm deep socket. Then the two line fittings could be removed, breaking them loose with an 11mm flare wrench (Supers only have two fittings/lines). The two blue flexible lines to the MC plastic "elbows" were removed (and later replaced with new special blue hose). Then the two bolts retaining the MC could be loosened - KEEP IN PLACE in the firewall - and the MC pulled out forward.
I took that in to Autozone and got a free replacement BRAND NEW MC they had ordered for me (Super MCs are different than in standard Beetles); fortunately, my receipt from 1994 from my rebuilt MC was still legible as before they went computerized.
This came with a bench bleed kit but unfortunately that did not have the correct type of fittings to bench bleed, so I used fittings from past MCs to bench bleed it.
I installed the new MC myself, used rag to hold the MC in place good enough to get the boot aligned and the two bolts threaded in. I advise getting a helper for this.
I wanted to try making a pseudo power bleeder to try. I found a cap in my garage that fit the VW MC reservoir. I drilled a 29/64" hole in the cap, because I had a tire valve stem that required a 0.432" hole. Then I pulled the valve stem through.
I filled the reservoir with new brake fluid, screwed on my cap with valve stem, set my air compressor to about 20 psi and attached it to the valve stem. Then I opened up the bleeders in sequence, filling up the reservoir as necessary to flush out all old brake fluid.
Success ! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
MACJELLY58 Samba Member
Joined: September 26, 2014 Posts: 400 Location: HONOLULU, HAWAII
Posted: Wed Dec 09, 2020 3:50 am Post subject: Re: My 1971 Super Beetle Convertible Thread |
NICE!
Cusser,
I'm sorry to hear that you had to replace that M.C. after only 26 years! I always enjoy reading about your quick, easy and inexpensive fixes. I especially liked this power assist bleeding system you made. Sounds so much easier than having my wife pump the brakes while I crawl around the floor to all four tires.
I also love reading how you drive your cars everyday for work and play...as It should BE!! Thanks for all the knowledge and help. |
Cusser Samba Member
Posted: Wed Dec 09, 2020 7:09 am Post subject: Re: My 1971 Super Beetle Convertible Thread |
MACJELLY58 wrote: |
I especially liked this power assist bleeding system you made. Sounds so much easier than having my wife pump the brakes while I crawl around the floor to all four tires. |
I've used a hand vacuum pump in the past for bleeding brakes, and also a small one-person bleed thing I got at O'Reilly https://www.oreillyauto.com/detail/b/performance-t...amp;pos=2.
I also used gravity bleeding on my other VW. But I wanted to try to rig up a small pressure adapter this time, to make it like a "pressure-assisted gravity bleed". Cost to me was the tire valve stem at O'Reillys (under $1, see https://www.oreillyauto.com/detail/b/xtra-seal-534...amp;pos=2) as I already had the 29/64" drill bit and a cap that fit.
Mrs. Cusser was here, but she has not proved to be the world's best brake bleeder, and I didn't want to wait until my daughter could come over to help. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297
AutoMechanic Samba Member
Joined: December 28, 2019 Posts: 483 Location: Roanoke Virginia
Posted: Wed Dec 09, 2020 7:15 am Post subject: Re: My 1971 Super Beetle Convertible Thread |
Great story. I could never keep a receipt that long lol. I am working on my Beetle getting it ready for the road. I haven’t done any suspension or brake work yet so that’s going to be fun to do. Luckily I know what all has been done as I know the 3 previous owners of it. |
Cusser Samba Member
Posted: Sat Dec 19, 2020 12:58 pm Post subject: Re: My 1971 Super Beetle Convertible Thread |
I installed two new German brake light switches from Heimlich into my 1971 Super and bled the brakes afterwards. Now my brake lights come on without having to power stomp on them. I did not need to remove the wheel, and 24mm deep socket was my friend.
VWNOS.com
Yep -so far satisfied with the Autozone brand new master cylinder; at FREE the price was right !!! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9756 Location: Oregon
Posted: Sat Dec 19, 2020 2:42 pm Post subject: Re: My 1971 Super Beetle Convertible Thread |
Hey Cusser, It looks like you used an oil bottle cap for your pressure bleeder adapter.
I have used a Coke bottle cap before with success. But it only worked once. Coke bottle caps aren't very deep.
I'll have to try the oil bottle cap next time and see if that works better in my situation.
Thank you for sharing your MC replacement and bleeding solution. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Cusser Samba Member
Posted: Sat Dec 19, 2020 5:15 pm Post subject: Re: My 1971 Super Beetle Convertible Thread |
67rustavenger wrote: |
Hey Cusser, It looks like you used an oil bottle cap for your pressure bleeder adapter. |
I don't know, just pulled it out of my little box of spare caps, and the first one fit !!! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Lost69Convertible Samba Member
Joined: July 29, 2020 Posts: 445 Location: Rhode Island
Posted: Sat Dec 19, 2020 6:18 pm Post subject: Re: My 1971 Super Beetle Convertible Thread |
Cusser - ok I have to ask, what lasted longer, the Armor-All'd top or the girlfriend? _________________ 1956 Beetle Ragtop: My Father's car
1969 Beetle Convertible: My first car. I loved it, I lost it, and I never got over it.
1979 Super Beetle Convertible |
Cusser Samba Member
Posted: Sun Dec 20, 2020 8:54 am Post subject: Re: My 1971 Super Beetle Convertible Thread |
Lost69Convertible wrote: |
Cusser - ok I have to ask, what lasted longer, the Armor-All'd top or the girlfriend? |
The girlfriend. But she declined to be Mrs. Cusser #1.
Cusser Samba Member
Posted: Sun Jan 10, 2021 12:31 pm Post subject: Re: My 1971 Super Beetle Convertible Thread |
I completed the addition of an LED 3rd brake light/turn signal light to my 1971 Convertible. I didn't want to fabricate bracket or drill new holes in the engine lid so bought an LED license plate bracket and about $5 in wire (thought vibration might break the thin-stranded wire on the LED license plate bracket, so soldered new 4-conductor wire on.
All connections were soldered, not crimped. I'll paint the black wire white, did not want to drill a new hole at this time to hide that. Yes, I know that the engine lid is from a 1970 sedan (I use lid stand-offs, 1835cc engine), and so are the cool reflectors.
Of course lights will appear brighter at night
Cusser Samba Member
Posted: Tue Jan 19, 2021 3:38 pm Post subject: Re: My 1971 Super Beetle Convertible Thread |
gt1953 here had recommended to me a few years ago about putting Fritos or Cheetos reflective bags into the tail light housings so the tail lights, brake lights, turn signals would be brighter. Since I don't like Fritos or Cheetos, I used aluminum foil to do such on my 1970 sedan tail lights a couple of years ago.
Today I got around to doing this on my 1971 tail light housings, and took photos. This is is mine looked after removing the lens.
My left housing had a piece of sheet metal here; I cut it to fit decades ago, as its factory one must've fallen out when first owner changed a bulb or when I had it repainted by Maaco in 1978
Instead of aluminum foil or snacks bags, I used reflective aluminum tape I had at the house (have seen similar at Home Depot near the water heaters).
Here's what the housing looked like after taping.
I also put the reflective tape on the bottom of that piece of sheet metal.
I did same on the other side, which did have its little plate still in place. The housings do not look any different during the day, but brighter when the lights are on, so a success. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
EA812 Samba Member
Joined: December 07, 2008 Posts: 1223 Location: North central, CT
Posted: Tue Jan 19, 2021 5:54 pm Post subject: Re: My 1971 Super Beetle Convertible Thread |
Cusser wrote: |
Success ! |
I did this trick with the air compressor and a valve stem, it worked out great! _________________ Project 66 Daily Driver http://www.thesamba.com/vw/forum/viewtopic.php?t=538786&highlight=
Herbie build
http://www.thesamba.com/vw/forum/viewtopic.php?t=336044 |
Cusser Samba Member
Posted: Tue Jan 19, 2021 7:12 pm Post subject: Re: My 1971 Super Beetle Convertible Thread |
EA812 wrote: |
I did this trick with the air compressor and a valve stem, it worked out great! |
Great !!! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Tue Jan 19, 2021 8:25 pm Post subject: Re: My 1971 Super Beetle Convertible Thread |
Cusser - You had me at “Frito bag.” _________________ 1956 Beetle Ragtop: My Father's car
Cusser Samba Member
Posted: Tue Sep 28, 2021 9:50 am Post subject: Re: My 1971 Super Beetle Convertible Thread |
Cusser wrote: |
Have had so few issues with it that I haven't detailed any on The Samba. About 25 years ago I replaced the idler bushing, 4 tie rod ends, and front bushings to fix the dreaded "Super Beetle steering wheel shimmy" issue. |
Last year, I noticed a small shimmy, nothing like the dreaded "Super Beetle steering wheel shimmy" I had decades ago. I got a warranty replacement steering damper but didn't really help.
Yesterday, I went underneath, and everything felt tight except the inner tie rod end on each side, which had some play. So I figure within the next couple of months to try to tighten up those tie rod ends or simply purchase/install new ones and then re-adjust the toe-in... _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Cusser Samba Member
Posted: Wed Oct 13, 2021 7:27 am Post subject: Re: My 1971 Super Beetle Convertible Thread |
I confirmed that the two inner tie rod ends on my 1971 Super were left-hand thread, and ordered new ones. These two had a small amount of play and I want to replace them as I feel a little vibration in the steering wheel at certain speeds.
About 25 years ago I replaced four tie rod ends, the idler bushing, and the two front bushings to fix the dreaded common Super Beetle shimmy. So I think it will be worthwhile to replace those two tie rod ends again and then adjust the toe-in. The other tie rod end are all tighter with no play. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Fri Oct 15, 2021 4:02 am Post subject: Re: My 1971 Super Beetle Convertible Thread |
Seems that all your parts last about 20-25 years.
That is awesome!! I think that just goes to show, the more you drive it the longer it lasts.
Keep on Buggin, my good Sir! |
Cusser Samba Member
Posted: Fri Oct 15, 2021 6:38 am Post subject: Re: My 1971 Super Beetle Convertible Thread |
MACJELLY58 wrote: |
That is awesome!! I think that just goes to show, the more you drive it the longer it lasts. |
It may be associated that most parts that were replaced happened BEFORE so many parts were manufactured in China. Like my "rebuilt by Bosch" generators, ignition switches, "rebuilt by Bosch" starters are over 3 decades old. I also run my generator belts intentionally a little loose, as in the 1970s I was hurting generator bearing using the VW-detailed belt tightness; no cooling issues (belt is NOT slipping).
However, I do have several made-in-China part on both my VWs including a clutch disc and wheel cylinders on the 1971 Super. But - my own feeling is that many folks blame Chinese-made parts but the real issue is their lack of mechanical knowledge/experience/skills. Others may disagree.... _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Cusser Samba Member
Posted: Sat Nov 06, 2021 2:19 pm Post subject: Re: My 1971 Super Beetle Convertible Thread |
Cusser wrote: |
Have had so few issues with it that I haven't detailed any on The Samba. About 25 years ago I replaced the idler bushing, 4 tie rod ends, and front bushings to fix the dreaded "Super Beetle steering wheel shimmy" issue. Last year, I noticed a small shimmy, nothing like the dreaded "Super Beetle steering wheel shimmy" I had decades ago. I got a warranty replacement steering damper but didn't really help. I went underneath, and everything felt tight except the inner tie rod end on each side, which had some play. So I figure within the next couple of months to try to tighten up those tie rod ends or simply purchase/install new ones and then re-adjust the toe-in... |
Cusser wrote: |
I confirmed that the two inner tie rod ends on my 1971 Super were left-hand thread, and ordered new ones.. |
Today I did the two inner tie rod ends on my 1971 Super. First I measured the tread-to-tread distance of the front tires, to aid in final toe alignment. Next was to get my safety glasses, important for this job under the vehicle. I put the front up on jack stands, left the wheels on.
The inner tie rod end locknuts on these required a 22mm open end wrench. The right inner tie rod end was straightforward, used my little OEM #25297 tie rod puller tool https://www.autozone.com/test-scan-and-specialty-t...lsrc=aw.ds
The left inner tie rod end required for me to remove the steering damper to get access to use the puller. I marked each tie rod end with a paint pen so I could approximate/transfer length to the new inner tie rod ends. Each new tie rod end (O'Reilly lifetime) came with a grease fitting I had to screw in. Installation of the new tie rod ends was straightforward. I used my grease gun to pump each full of grease, good thing I have a flexible tube on my grease gun; would not be a dumb idea to get a replacement angled grease fitting for these to make greasing easier.
Anyway, replaced the steering damper, loosened the clamps for the outer tie rods, and lowered the Super to the ground. I adjusted the toe by rotating the tie rod ends on each side to get correct measurement, then double-checked and tightened the tie rod clamps at both ends. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Cusser Samba Member
Posted: Tue Nov 09, 2021 12:11 pm Post subject: Re: My 1971 Super Beetle Convertible Thread |
I forgot to post a photo of my 1971 Convertible's 50th birthday. I've only owned it since 1976.
