dobryan Samba Member
Joined: March 24, 2006 Posts: 16504 Location: Brookeville, MD
Posted: Mon Dec 14, 2020 7:59 am Post subject: Truckfridge door prop |
I noticed a post somewhere about the truckfridge having a door prop tab on the latch. It was designed to hold open the door a skosh to be able to air it out but not trigger the light to come on. Perfect for when the fridge is not on between uses.
So the tab is there but it is useless in the stock setup. It does not spring up to grab the lip of the top cover over the door as it looks like it should.
So I looked for something to help keep it sprung upward.
I settled on a piece of closed cell foam. Shove it under the tab and it keeps it sprung up enough that it can grab onto the top cover.
In use. YMMV.
_________________ Dave O
The Western Syncro build
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4790 Location: Bemidji, MN
Posted: Mon Dec 14, 2020 10:14 am Post subject: Re: Truckfridge door prop |
pure genius. awesome. perfect material. _________________ -dan
www.thefixitworkshop.com |
Sodo Samba Member
Joined: July 06, 2007 Posts: 9610 Location: Western WA
Posted: Mon Dec 14, 2020 11:10 am Post subject: Re: Truckfridge door prop |
DOB you may be thinking of something you saw on Facebook.
But FB is almost impossible to search as an archive.
Not like TheSamba.
Need someone to harvest the good stuff off FB and put it into TheSamba Vanagon archive.
With credits of course.
I tried foam, but my latch would not/could not stay clicked down (stowed).
The best method I've found is to slide a penny under it, all the way across.
That I have to then remove when using the fridge.
It's (currently) easy to find another penny if you lose it. _________________
....KTMs, GasGas, SPOT mtb |
Posted: Mon Dec 14, 2020 12:26 pm Post subject: Re: Truckfridge door prop |
Sodo wrote: |
Not like TheSamba.
It's (currently) easy to find another penny if you lose it. |
Yep likely fb. And I remove the foam piece and stash it in the drawer when using the fridge. But I like the penny idea for when I lose the foam. _________________ Dave O
fxr Samba Member
Joined: December 07, 2014 Posts: 2325 Location: Bay area CA
