Raymondo Samba Member
Posted: Sat Dec 19, 2020 7:10 am Post subject: Rear Bumper mount |
Hi
I'm about to start on my 67 bug on the rear inner arch. I am going to have to replace the engine bay side plate behind this as well as there is rust starting to show.
Is it best to take out the engine to tackle this whole job? Or should i leave it in?
I assume i need to put the rear valance and decklid back on when i go to fit the bumper bracket?
anthracitedub Samba Member
Posted: Sat Dec 19, 2020 4:56 pm Post subject: Re: Rear Bumper mount |
Yeah, you’re getting deep into it... yank the engine.... does it even have an apron? Looks to be missing. |
Posted: Sun Dec 20, 2020 5:25 am Post subject: Re: Rear Bumper mount |
anthracitedub wrote: |
Yes it has an apron it was cut off in the past so has the inner wing bits attached to it. The wings were the only thing holding it on.
I put everything back together and noticed the bumper bracket on the drivers side sits way higher than the passenger side. Both mounts will need to be done.
What's the best thing to do so that they line up when fully welded in? Am I best yo strip the car tack the new mounts in and then use a level to make sure there the same height? |
Posted: Sun Dec 20, 2020 5:40 am Post subject: Re: Rear Bumper mount |
You’ll have to do several test fits of fenders, bumper and rear apron before you do final welding. Are you using German parts or reproductions. The repros will require a lot more test fits. Don’t get discouraged, but you’ll have the fenders and bumper off/on quite a few times before you do final welding. Take your time because you want it to look good. |
Posted: Sun Dec 20, 2020 8:31 am Post subject: Re: Rear Bumper mount |
I was thinking cut off the current mounts then with both new mount panels I was tempted to tack weld the new panels to the valance and then offer it up with the wings attached and then line up the wings with the body then mark up where I need to cut. Tack everything in and then see if the mounts are level and go from there.
Obviously I will make sure the deck lid lines up aswell but does this seem like the right way to go? |
beetlenut Samba Member
Posted: Sun Dec 20, 2020 4:22 pm Post subject: Re: Rear Bumper mount |
I did something similar with my 74 that had shock mounts, but I replaced both bumper mounts with with earlier 73 solid mounts. Once I cut off the old mounts, I attached the rear fenders, then bolted the new mounts to the fenders using the associated correct holes, replacement apron, and closed the engine lid. Then I was able to transfer the cut lines from the body to the replacement panels. I cut the new panels to fit, reattached everything again to make sure it lined up, it didn't, and I had to do several rounds of trimming and fitting until it did. Then once everything fit while bolted up, I tack welded the replacement panels in.
_________________ scrapyards are for quitters
Wetstuff wrote: |
... I spend more time shaking it than directing it?! I get a pretty decent blast for 8sec. then have to shake it again. |
- Words to live by right there!
My 74 Super rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=6507104#6507104 |
Posted: Sun Dec 20, 2020 4:42 pm Post subject: Re: Rear Bumper mount |
I think you’re approaching it fine. Remember, if you use the aftermarket panels... you don’t have to use the whole piece... just clean up the originals and see how much you have to cut away to get to the good stuff.
If you’re just doing bumper brackets, you can drill all the spot welds and just remove the brackets.
Cut off the bad, cut nice and use for-thought to set yourself up with some good seams to weld together.
Take your replacement panel and cut just a bit larger then you need, this way you can test fit and sneak up on the proper dimensions while checking bumper and fender alignment.
Do this until you’re happy with your bumper/fender/seal seam. Also the apron/ decklid fitment should be checked. You can use screws, magnets or tack welds to begin the rough assembly of the parts.
Take your time, test fit, weld nice joints and they’ll finish out smoothly and remain clean after minimal body work and sealing/painting. |
Posted: Mon Dec 21, 2020 1:31 pm Post subject: Re: Rear Bumper mount |
Cheers all
Managed to get a look at the passenger side it looks fine as in it doesnt need much work. Just need to weld a strip for the last two bolt holes for the wing.
Only thing that worrys me is that if it's not original has it been done correctly. I spose I wont know until I offer up the drivers side mount and then see if the brackets are level. |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Mon Dec 21, 2020 3:54 pm Post subject: Re: Rear Bumper mount |
If you'd wire wheel all the crud off them you might find they could be welded/repaired in situ instead of pasting on new ones? _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
Posted: Thu Dec 24, 2020 12:57 am Post subject: Re: Rear Bumper mount |
1966-67 rear bumper mounts are unique And they are no reproduction pattern parts available. The aftermarket only has universal 1968-later that might fit. If you’re car is worth the effort, you might want to find and purchase donor panels from a 1966/67 beetle.
I had to do the the same repair. My mounts were so far gone that a previous owner welded the bumper brackets directly to the mount.
_________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
VeeDee Samba Member
Joined: February 02, 2020 Posts: 212 Location: Wolfsburg, Germany
Posted: Thu Dec 24, 2020 5:32 pm Post subject: Re: Rear Bumper mount |
I will do 66/67 rear bumper mounts in the next weeks. These will be as close as possible to the originals.
I do not do this for the first time. I need them for 3 project cars the next year and will run about 10-12 sets.
A pic from my own 67, made about 15 years ago:
_________________ Always Aircooled
VeeDee |
sportin-wood Samba Member
Joined: September 12, 2010 Posts: 2009 Location: Texas
Posted: Thu Aug 19, 2021 12:55 pm Post subject: Re: Rear Bumper mount |
VeeDee wrote: |
Hi,
I was wondering if you were able to reproduce these? And if you're selling them?
Thanks,
Dave _________________ .
Paused 66 project bug
"Relax, all right? My old man is a television repairman. He's got this ultimate set of tools. I can fix it." --- Jeff Spicoli |
