bobby1978 Samba Member
Joined: January 07, 2011 Posts: 17 Location: victorville
Posted: Sat Dec 19, 2020 10:25 pm Post subject: 71 Baja build |
Getting started
Posted: Sat Dec 19, 2020 10:30 pm Post subject: Re: 71 Baja build |
Started on the cage this past weekend at a good friends. A lot more to be done. Cleaning up some parts i got and trying to figure out the length of the tweed arm setup i picked up. Got a 6 over beam and some 5X5's. Just placed an order for parts to get the front end done minus shocks. |
halfassleatherworks Samba Member
Joined: December 09, 2018 Posts: 636 Location: Reno NV
Posted: Sun Dec 20, 2020 8:44 am Post subject: Re: 71 Baja build |
your pics don't work _________________ Halfass Leatherworks*****GOT LEATHER Made to order Leather crafts, you can find us on that face book thing
Belts, wallets, mouse pads, drink coasters, Engraving, most things made in leather.
personal items if you want it in leather in Reno Nv, ***** |
Posted: Sun Dec 20, 2020 5:56 pm Post subject: Re: 71 Baja build |
halfassleatherworks wrote: |
your pics don't work |
think i fixed it |
Bad_chopper Samba Member
Joined: August 15, 2012 Posts: 295 Location: Portland, or
Posted: Sun Dec 20, 2020 6:34 pm Post subject: Re: 71 Baja build |
Whats your plan for the front strut bracing?[/quote]
Front end is getting cutoff. Stretching the wheels base 6" |
TVander Samba Member
Joined: December 23, 2017 Posts: 17 Location: Lake Ann,Mi
Posted: Sun Dec 20, 2020 7:32 pm Post subject: Re: 71 Baja build |
I have a 71 super that I am doing the same thing too! Just getting started I have the body off and chopped the front off the pan. I will be following your build so the more pictures you share the more help for me! |
Posted: Mon Dec 21, 2020 1:22 pm Post subject: Re: 71 Baja build |
bobby1978 wrote: |
Whats your plan for the front strut bracing? |
Front end is getting cutoff. Stretching the wheels base 6"[/quote]
Oh, that will be cool. Looking forward to the progress _________________ my build page http://www.thesamba.com/vw/forum/viewtopic.php?t=536267 |
Posted: Sun Jan 24, 2021 6:18 pm Post subject: Re: 71 Baja build |
Got the front end on this past weekend.
thesatelliteguy Samba Member
Joined: January 06, 2007 Posts: 1515 Location: Santa Rosa CA
Posted: Sun Mar 14, 2021 7:52 pm Post subject: Re: 71 Baja build |
Well picked up a Honda J35 a little earlier than planned, but oh well. Trying to figure out what master cylinder to get. Running disc brakes front and rear. |
Posted: Fri Apr 02, 2021 4:26 pm Post subject: Re: 71 Baja build |
I want to flip the intake, but been told different things about how the harness will need to be run. |
Posted: Fri Apr 02, 2021 5:43 pm Post subject: Re: 71 Baja build |
Bad_chopper wrote: |
Why do you want to reverse it? My bug has a subaru, and I am unfamiliar with a j35.. |
To avoid possibly cutting the firewall for the intake to clear. |
Posted: Fri Apr 02, 2021 5:57 pm Post subject: Re: 71 Baja build |
bobby1978 wrote: |
Posted: Mon Apr 05, 2021 8:53 am Post subject: Re: 71 Baja build |
Ah makes a lot of sense now, that is way worse then mine. I just made a 180 adapter for my throttle body and extended the wiring to reach. No reason you can't extend and reroute wiring if needed. An extra foot or so in wiring won't make any difference in output or input signals. _________________ my build page http://www.thesamba.com/vw/forum/viewtopic.php?t=536267 |
downdiver2 Samba Member
Joined: May 18, 2020 Posts: 1 Location: Orange County, CA
Posted: Tue Apr 06, 2021 4:55 pm Post subject: Re: 71 Baja build |
Dookie looking good Bobby! My first Samba post btw and the Dookie got it. |
Dkwautounion Samba Member
Posted: Sun Apr 11, 2021 5:55 pm Post subject: Re: 71 Baja build |
Are you running the stock ecu? |
Posted: Mon Apr 12, 2021 12:00 pm Post subject: Re: 71 Baja build |
Dkwautounion wrote: |
yes |
Posted: Sat Sep 11, 2021 8:16 pm Post subject: Re: 71 Baja build |
Been awhile. Working a lot. Haven't gotten a whole lot done. Have tank remounted to make room for a radiator eventually. Picked up a really nice fiberglass front end that had never been mounted. Got new master and front brake lines all done. Have everything for the rear just need to make time. Pulled the trigger and put a deposit down on a mendeola 2D. Figured pay once cry once |
