fredybear Samba Member
Posted: Sat May 22, 2021 4:04 pm Post subject: Re: 1973 Bubbled Rear Apron & Restoration Thread |
Pan Sanding the first coat...
I've got Bumps...and its crap
Do Not Touch That Beautiful Bottom,,,,Say What
U Cant Touch This Its Buggie Time
Im tellin Ya Home-Boy, U Cant Touch This |
Posted: Sun May 23, 2021 3:50 pm Post subject: Re: 1973 Bubbled Rear Apron & Restoration Thread |
2nd Coat.......Looking way better
Maybe a 3rd coat, if I dont like something
i cant gat a good pic on stuff, the glare, this shine, the lighting, its crap
Than put it back together, stuff it in the corner, cover it up so no dust particles infest on that shine, and and and and ----finish the BOD |
Posted: Sun May 23, 2021 4:15 pm Post subject: Re: 1973 Bubbled Rear Apron & Restoration Thread |
How to save your pan
From This......YUK
To This.....YUM
After the tar board is fully glued, thats good for another 50yrs, looks better in person |
Posted: Sat May 29, 2021 4:36 pm Post subject: Re: 1973 Bubbled Rear Apron & Restoration Thread |
Weapons Of Mass Destruction
Take that Death Foam Hahahahahahaaaa
Had to pull the wiring out for a full cleanse, drivers side...
Welded the rod to the brush
Almost done, U can see a few little holes, weld weld time |
Posted: Sat May 29, 2021 6:24 pm Post subject: Re: 1973 Bubbled Rear Apron & Restoration Thread |
Fillin Holes
More foam holes to fill up
Posted: Sun May 30, 2021 6:48 pm Post subject: Re: 1973 Bubbled Rear Apron & Restoration Thread |
Need the proper disc to finish and smooth the line lets see
1 more hole to fill up No need to patch, just fill it line by line
Lets see what happens |
Posted: Mon May 31, 2021 10:58 am Post subject: Re: 1973 Bubbled Rear Apron & Restoration Thread |
Halfway
All the way
Grind time |
Posted: Mon May 31, 2021 3:34 pm Post subject: Re: 1973 Bubbled Rear Apron & Restoration Thread |
Metal in the Eyeball.....At the eye doc yesterday,,,,,,than leave and start welding
Posted: Tue Jun 01, 2021 11:17 am Post subject: Re: 1973 Bubbled Rear Apron & Restoration Thread |
Acid Etching before the primer. 2/3 hrs of scrubbing
Look at that deep dark and rich metal
phosphoric, phosphoric, put you hands all over my body, phosphoric, phosphoric
Next-----
Roll Roll Roll your primer, gently on the buggie |
Posted: Tue Jun 01, 2021 6:35 pm Post subject: Re: 1973 Bubbled Rear Apron & Restoration Thread |
Before Deep, Rich,""" Acid Etched Dark Metal"""....haaayyy..a new musical sound
After.....need to spray a few parts, 2 hrs to roll and brush ...First coat, scuffel and prime again
Posted: Thu Jun 03, 2021 11:25 am Post subject: Re: 1973 Bubbled Rear Apron & Restoration Thread |
The pictures come out way better with the primer on, no glare
Almost done here, lets see how flawless it can become
Posted: Thu Jun 03, 2021 4:41 pm Post subject: Re: 1973 Bubbled Rear Apron & Restoration Thread |
Got my 3 Bolt, Look at those blasted arms, sweetness
Painting pieces,
Posted: Thu Jun 03, 2021 4:51 pm Post subject: Re: 1973 Bubbled Rear Apron & Restoration Thread |
That Beam Looks Soooooooooooooooo Sweeeeet
My Amoeba's are having a Meltdown
Posted: Thu Jun 03, 2021 5:05 pm Post subject: Re: 1973 Bubbled Rear Apron & Restoration Thread |
You might not understand the 3 bolt arm, forgot to post in here.
What I had, sleeze n hack, someone put a 4 bolt arm in.
They drilled and tapped the arm for 4 bolts
That shaft is froze in that 4 bolt, found and awesome 3 bolt in the junkyard for $75 |
Posted: Thu Jun 03, 2021 5:52 pm Post subject: Re: 1973 Bubbled Rear Apron & Restoration Thread |
More Pics,,,,Who need words, """just zip it and pic it"""", Haaayyyyy
Hang Em High & Low
I Have Seen The Light OOOOoooooOOOooooOOoooo |
Posted: Sun Jun 06, 2021 6:47 pm Post subject: Re: 1973 Bubbled Rear Apron & Restoration Thread |
Sunday Pics.
2 different cameras..2005 Cannon Power Shot, 2019 G-S10
Sunday Sunday Sunday
A beautiful etching
The Primer
Posted: Wed Jun 09, 2021 3:20 pm Post subject: Re: 1973 Bubbled Rear Apron & Restoration Thread |
The boring primer updates.....This was sprayed.Tried 12 psi through the HF Gun....Too Low. The roll-on primer is really liquid.
First---Epoxy, than the sandable Urethane
Yaaaaaawwwwwnnnnnnn
My Rear is Glowing
Yaawwwnnnn
Fix a few defects first...
Posted: Sat Jun 12, 2021 5:36 pm Post subject: Re: 1973 Bubbled Rear Apron & Restoration Thread |
The last of the scrubbing It Just-B-Nasty
Cleanse than re-undercoat
Almost done
The original gray stuff with the red overspray...It looks better in person cause my photo-graffy is not that impressive
Next Up......Turning my HF Sandblaster into a pressure somewhat blaster |
Posted: Sun Jun 13, 2021 5:10 pm Post subject: Re: 1973 Bubbled Rear Apron & Restoration Thread |
Forgot, this is the last scrubbing
How to drain your fluid and make a mess
Off to the carwash for a super power scrub |
Posted: Mon Jun 14, 2021 4:03 pm Post subject: Re: 1973 Bubbled Rear Apron & Restoration Thread |
Cleaning the Nuts -N-Bolts & Stuff
This this works really good Except for the hours of run time
Good Stuff for the removal of rust.
