fredybear Samba Member
Posted: Tue Jun 15, 2021 11:50 am Post subject: Re: 1973 Bubbled Rear Apron & Restoration Thread |
Painting the original brake lines. Already pre bent to correctness
Let it dry for a few and than spin the thread things befor they lock up |
Posted: Tue Jun 15, 2021 6:49 pm Post subject: Re: 1973 Bubbled Rear Apron & Restoration Thread |
Gettin R Groove On
The Etch
The Primer
We-B-Jammin Haaayyy |
OTTO 1303 Samba Member
Joined: March 17, 2020 Posts: 625 Location: Louisiana
Posted: Tue Jun 15, 2021 7:44 pm Post subject: Re: 1973 Bubbled Rear Apron & Restoration Thread |
A whole lotta CORRECTNESS
Looks great _________________ 74 Super Sun Bug - OTTO
74 Super - DANZIG
74 Super - HERZOG |
Posted: Wed Jun 16, 2021 11:35 am Post subject: Re: 1973 Bubbled Rear Apron & Restoration Thread |
Thanks OTTO
Gettin there
How did that surface rust get there One last acid scrub on the inside......
I think the Ants and are takin a Wee on my fresh cleansed metal |
Michael Ambrozik Samba Member
Joined: October 17, 2020 Posts: 631 Location: San Jose, CA
Posted: Wed Jun 16, 2021 11:42 am Post subject: Re: 1973 Bubbled Rear Apron & Restoration Thread |
Your car is looking great. Are you going to put in a removable rear apron? |
Posted: Wed Jun 16, 2021 3:49 pm Post subject: Re: 1973 Bubbled Rear Apron & Restoration Thread |
The apron will be welded in
BUT.....
Should I paint the inside first or weld it in than paint Hmmmm
Let me think
Which gun should I use for $300 Qt Paint
PIC....Cant post without pic
Posted: Wed Jun 16, 2021 5:26 pm Post subject: Re: 1973 Bubbled Rear Apron & Restoration Thread |
Acid takes the surface rust and destroys it. Hehehahahehehaha
The little flecks of red must be picked off or it cant be primed
Have to fix this, how to peops do this stuff
Cover with bondo for a hack-n-sleeze job or weld and make it pretty hmm |
Posted: Wed Jun 16, 2021 5:45 pm Post subject: Re: 1973 Bubbled Rear Apron & Restoration Thread |
A good squeeeeeeeeezzz before the weld
Posted: Thu Jun 17, 2021 6:25 pm Post subject: Re: 1973 Bubbled Rear Apron & Restoration Thread |
Shrinking Disk
1 1/2 hours to go from this
To This
To This
Push up the low spots and shrink up |
pittbull Samba Member
Joined: April 06, 2015 Posts: 41 Location: Nieuwegein, The Netherlands
Posted: Fri Jun 18, 2021 12:28 pm Post subject: Re: 1973 Bubbled Rear Apron & Restoration Thread |
Awesome progress, keep it going! |
Posted: Fri Jun 18, 2021 6:07 pm Post subject: Re: 1973 Bubbled Rear Apron & Restoration Thread |
Yes-O-Yes....I keep going --- -BUT-----I think this is affecting my Golf Time ---hmmm
The other door
WHY-O-WHY
You can see the low spots... plus...A little filler never hurts
Posted: Sun Jun 20, 2021 7:32 pm Post subject: Re: 1973 Bubbled Rear Apron & Restoration Thread |
From this
It was like a 1/2 inch of filler on this door
To This
Now -- a little to fill the low spots
alittle more and than epox, some polly than ure Than Paint
The door handle was pushed in, gotta pop that out |
Posted: Mon Jun 21, 2021 6:50 pm Post subject: Re: 1973 Bubbled Rear Apron & Restoration Thread |
Sweeeeettnessssss Any drop of rust, done
Look at that etching---Juicy
The exterior metal take the etching beautifully, while the interior metal does not.
Must be the sunshine
24hr dry than prime, some filler hmm
Posted: Tue Jun 22, 2021 7:05 pm Post subject: Re: 1973 Bubbled Rear Apron & Restoration Thread |
Kiss My Dash
Lookin Juicy |
Posted: Sun Jun 27, 2021 3:48 pm Post subject: Re: 1973 Bubbled Rear Apron & Restoration Thread |
Lookin kinda sexy OOOOLaaaaLaa
Posted: Tue Jun 29, 2021 10:21 am Post subject: Re: 1973 Bubbled Rear Apron & Restoration Thread |
The Boring Stuff------The Pieces
Homemade pressure blaster. It keeps the sand flowing
Around 10psi, anymore and the lid will blow off, up in the air and come down on your head, coulda landed anywhere, But
Parts-
--wire wheel and steel wool
Time to plate the small stuff and get it lookin goooooood |
Posted: Tue Jun 29, 2021 10:40 am Post subject: Re: 1973 Bubbled Rear Apron & Restoration Thread |
Do you tuck your pan in at night
And read him a bedtime story
Cant have and dust on this bad boy |
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4390 Location: Stuck in Ohio
Posted: Tue Jun 29, 2021 6:27 pm Post subject: Re: 1973 Bubbled Rear Apron & Restoration Thread |
Thanks Buggeee
Waiting for the epoxy to dry. Give it 2/3 days. Doors are comming along Next, shrinking with the little disc
Now im just -chillin chillin mindin my bizness, than I looked around and thought id take this
The hydrolic in place to push up the roof dents Very little pushin to do, -----but they put masses of bondo to cover it up
Lookin kinda different |
Posted: Tue Jun 29, 2021 6:38 pm Post subject: Re: 1973 Bubbled Rear Apron & Restoration Thread |
Here you can see the bondo through the primer. Shrinking the high spots the sanding. Apply more primer, wait, repeat.
The other door...
The 2 shinny spots were shrunk down. After the shrink disc, buzz it with the 36 grit, heats the metal good, than dab with cold water for the extra shrink |
