Buggeee Samba Member
Joined: December 22, 2016 Posts: 4421 Location: Stuck in Ohio
fredybear Samba Member
Posted: Sat Mar 06, 2021 12:23 pm Post subject: Re: 1973 Bubbled Rear Apron & Restoration Thread |
Thanks El-cheeepoo Way ---I could bend and weld while I go, but I might fry all my original paint off.
The Channel Master 5000, only 29.99 only at....
Crazeeeee Freeeedddys,,,,,His prices are Insaaaaannnnneeeeeeeee
U can see the first few welds, ukkk till I got the flow goin on
Alittle cleanup, tappin-N-positioning OOOOOOOOAAHHHHH |
Posted: Sat Mar 06, 2021 1:30 pm Post subject: Re: 1973 Bubbled Rear Apron & Restoration Thread |
The channel was damaged, cause hood was damaged. The opening and shutting back in the day ruined my channel.
Hood welding......... Fixin
HoodRide Baby......Geettttooooooo
Fillin Holes
Posted: Sat Mar 13, 2021 4:36 pm Post subject: Re: 1973 Bubbled Rear Apron & Restoration Thread |
Fender Undercoating Removal......
Hammer and the HF Plastic Chisel...These things work awsome for keepin the original paint.
Posted: Sat Mar 13, 2021 4:37 pm Post subject: Re: 1973 Bubbled Rear Apron & Restoration Thread |
Its just abuse of my uselessness |
Posted: Sat Mar 13, 2021 6:28 pm Post subject: Re: 1973 Bubbled Rear Apron & Restoration Thread |
Sweeeeeeeeeeeeeeeetnneeessssss
The dark embedded undercoat is from the crappy bodywork
Lookin good......Alll that work just re-undercoat
Also Fix that crap weld someone did.... |
Posted: Mon Mar 15, 2021 3:31 pm Post subject: Re: 1973 Bubbled Rear Apron & Restoration Thread |
Next
Its a real pain, you want that beautiful original, this is it....Thinner the rest off..
Do al little, sit down and read 10 posts and be usless, than 5 min labor, 1 hour readng, repeat |
Posted: Mon Mar 15, 2021 6:33 pm Post subject: Re: 1973 Bubbled Rear Apron & Restoration Thread |
Pretty Fender, Looking Good oooooHHHHHHaaaahhhhhh
Should I nit pick it to perfection or just undercoat
Another Crappy weld to fix....
Posted: Tue Mar 16, 2021 7:19 pm Post subject: Re: 1973 Bubbled Rear Apron & Restoration Thread |
Cleaning up my buckets
Posted: Thu Mar 18, 2021 6:01 pm Post subject: Re: 1973 Bubbled Rear Apron & Restoration Thread |
Rear Fender Abuse. Worse than the front , cause they be lighter
Posted: Sat Mar 20, 2021 10:11 am Post subject: Re: 1973 Bubbled Rear Apron & Restoration Thread |
Back to blasting....
Let gravity help you
The Extention
Posted: Wed Mar 24, 2021 6:10 pm Post subject: Re: 1973 Bubbled Rear Apron & Restoration Thread |
Im back on the bottle.....I cant take the pain anymore.....Its too much.....
The .030 wire is killin me slowly.......Help
.023 is the only way to go
Harbor Freight Rules
$210 for a new bottle
The .30 can be used on new, but old pounded damaged rusted sheetmetal is a real pain....... |
Posted: Thu Mar 25, 2021 5:52 pm Post subject: Re: 1973 Bubbled Rear Apron & Restoration Thread |
Adding the cooler to the compressor........To much blasting, it starts blowin water.
Ready to rig up some compressor air cooling?????Whos with me??? anyone
anyone |
Posted: Sat Mar 27, 2021 11:31 am Post subject: Re: 1973 Bubbled Rear Apron & Restoration Thread |
Putting back an original rear apron
I cant take the bubble on this beautiful original 73
I dont like big butts and I can not lie - U other Buggies cant deny
Clean, Grind and Weld...O-MY |
Posted: Sun Mar 28, 2021 12:42 pm Post subject: Re: 1973 Bubbled Rear Apron & Restoration Thread |
Workin it......Drillin Holes
That Butt you got make me sooooo hoooooornnyy
Looks soo goood, it gives me a Metal
Alittle blasting and clensing, adjusting, painting and welding |
Posted: Sun Mar 28, 2021 5:10 pm Post subject: Re: 1973 Bubbled Rear Apron & Restoration Thread |
Linin up
Some Massage Therapy
Me Luv U Long Time |
vamram Samba Member
Posted: Sun Mar 28, 2021 5:40 pm Post subject: Re: 1973 Bubbled Rear Apron & Restoration Thread |
fredybear wrote: |
Linin up
Wow! Are you going to paint it? _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
Posted: Sun Mar 28, 2021 6:19 pm Post subject: Re: 1973 Bubbled Rear Apron & Restoration Thread |
U Bet
I will show all.....
Almost there, clean some paint, weld some stuff up, clean, clean and clean, than start the priming process |
Posted: Sat Apr 03, 2021 1:13 pm Post subject: Re: 1973 Bubbled Rear Apron & Restoration Thread |
Closin in.....
Who Loves Metal Buggie ........Maybe I should just polish & clear coat it
Can U spot the issue |
