zoti Samba Member
Joined: December 26, 2007 Posts: 2060 Location: Plano, TX USA
Posted: Sun Mar 21, 2021 7:03 pm Post subject: Re: Idle Stabilizer Control Unit Alternative |
holdthewind2 wrote: |
Just a guess... I bet the solder-mask will be purple.
What conformal coat are you going to use? ...
There is a great shop in Austin to get all your FCC testing done, if and when you ever decide to go wireless. Since it is consumer based, albeit automotive, it's not as inten$ive as avionics. If recall correctly they're called "Professional Testing EMI" It used to be IBM's test facility, heck it's attached to IBM's building. I was "voluntold" that i got the pleasure of going there in late July when we did our FCC testing. Great people... just to FN hot for a PNW boy...
... now back to your regularly scheduled program |
We don’t have plans to go wireless. The input / output and control of the unit is rather basic. There is not really a need for wireless connection.
I’m not sure about the type of conformal coating. We will have the test units next week so we will be able to test and make more decisions. |
zoti Samba Member
Posted: Wed Mar 24, 2021 2:06 pm Post subject: Re: Idle Stabilizer Control Unit Alternative |
Project “stable idle” has made a big step today when we received the first test run of our Vanagon digifant idle stabilizing units. We will start testing these bad boys next week. For 86-91 digifant vanagons.
COWestySyncro Samba Member
Posted: Wed Mar 24, 2021 2:31 pm Post subject: Re: Idle Stabilizer Control Unit Alternative |
Interested in one of these when you put them into production. |
zoti Samba Member
Posted: Fri Mar 26, 2021 10:22 am Post subject: Re: Idle Stabilizer Control Unit Alternative |
Got a unit in my hands today to test the fit.
These do not have any software on them right now so they are not functional yet.
It’s so compact and fits perfect in the location of the original.
Installation takes 2 minutes.
You can see the internals of the original spanning over 2 boards with 1980’s components compared with our new and modern design.
The whole board will have conformal coating on it to protect it from moisture and then it will go inside the case and held in with 4 torx screws for easy access to the USB port.
It sits very nice in the original location and it’s lighter than the original which means less issues with vibrations.
Btw, who knows what goes in the plug in front of it? Mine had nothing there and no wires to the plug. I’m thinking VW put it there just so you can slide the ICU plug on it. It has rails the ICU plug will fit in.
The unit plugs into the original plug the same way the original unit does. It sits a couple on mm higher on purpose to clear the screws but it sits nice and tight with no way of it coming loose.
Vanagon Nut Samba Member
Joined: February 08, 2008 Posts: 10371 Location: Sunshine Coast B.C.
Posted: Fri Mar 26, 2021 11:05 am Post subject: Re: Idle Stabilizer Control Unit Alternative |
I see your comments re: future conformal coating and weight or part but do you think a brace between relay block and end of this part is warranted? I imagine not.
That's really awesome work. I only dabble with DC stuff, imagineering simple things, but can appreciate how much work went into designing that and getting an actual part in hand ready for Beta testing. Really darn nice to see.
1988 West DIY 50º ABA
VE7TBN |
zoti Samba Member
Posted: Fri Mar 26, 2021 11:20 am Post subject: Re: Idle Stabilizer Control Unit Alternative |
Vanagon Nut wrote: |
Neil. |
I doubt it will move. It’s hard to pull out of the connector as it is. |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16503 Location: Brookeville, MD
4Gears4Tires Samba Member
Posted: Fri Mar 26, 2021 11:33 am Post subject: Re: Idle Stabilizer Control Unit Alternative |
Waiting for them to go on sale. _________________ '87 Syncro
zoti Samba Member
Posted: Fri Mar 26, 2021 11:34 am Post subject: Re: Idle Stabilizer Control Unit Alternative |
dobryan wrote: |
Waterproof is a good thing. The original tends to do this as we know.
(Look closely at the lower left corner.)
Did you drive it in a puddle or is that moisture collecting in it? |
Posted: Fri Mar 26, 2021 11:43 am Post subject: Re: Idle Stabilizer Control Unit Alternative |
zoti wrote: |
dobryan wrote: |
No special treatment on my part. It was in the stock location. Moisture collected in it.
The idle went crazy on it's own. Revving to 3000-4000 rpm without any throttle.
I bought a good used ICV and ICU and when I removed the original ICU I poured slightly rusty water out of it. I imagine the inside of the unit is crusty.
As we know the D pillar can deliver rain water onto the ICU.... _________________ Dave O
The Western Syncro build
zoti Samba Member
Posted: Fri Mar 26, 2021 3:23 pm Post subject: Re: Idle Stabilizer Control Unit Alternative |
dobryan wrote: |
zoti wrote: |
dobryan wrote: |
As we know the D pillar can deliver rain water onto the ICU.... |
My partner says the new style conformal coating will be good for at least 15 years. The old style would flake as it got older so the electronics go exposed to humidity. |
zoti Samba Member
Posted: Fri Apr 02, 2021 6:29 pm Post subject: Re: Idle Stabilizer Control Unit Alternative |
A little bit more work. Code is getting written down. You can see a bit of it. Next week we hope to start testing on the van.
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4349 Location: United States, Iowa
Posted: Sat Apr 03, 2021 8:07 pm Post subject: Re: Idle Stabilizer Control Unit Alternative |
Looking good!! Plenty of stuff I can't see up above, but you are priming your array values with NULLs or zeros to start with, I hope? Always 'escape' while you are in front of your disasters. _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Aryana Samba Member
Joined: November 09, 2015 Posts: 568 Location: Southern CA
Posted: Fri May 21, 2021 12:43 pm Post subject: Re: Idle Stabilizer Control Unit Alternative |
Any update on progress/status? Thanks! |
zoti Samba Member
Posted: Fri May 21, 2021 4:18 pm Post subject: Re: Idle Stabilizer Control Unit Alternative |
Aryana wrote: |
I'm sorry. My partner got super busy with his daytime work and is waiting for a window where he can continue and finish the code to run the box. |
minsk Samba Member
Joined: March 17, 2008 Posts: 899 Location: pittsburgh
Luckyphil Samba Member
Joined: March 07, 2011 Posts: 156 Location: Australia
Posted: Sat Jun 19, 2021 11:36 pm Post subject: Re: Idle Stabilizer Control Unit Alternative |
Hi Mate, Any update on the Idle Stabilizer Control Unit Alternative, there are a few of us down under in Australia keen to get on board with this |
aykbobcat Samba Member
Joined: July 23, 2017 Posts: 2 Location: Québec, Canada
Posted: Sun Jun 20, 2021 6:50 am Post subject: Re: Idle Stabilizer Control Unit Alternative |
Super interested in getting one too. I've been looking for a refurbished one for a while. I'd much rather have a modern solution. Can't wait...! |
cdr Samba Member
Joined: July 09, 2021 Posts: 2 Location: Bitte wählen Sie Region, Land oder Bundesland
Posted: Fri Jul 09, 2021 6:06 am Post subject: Re: Idle Stabilizer Control Unit Alternative |
Same here, would be so great! |
zoti Samba Member
Posted: Thu Aug 19, 2021 9:26 pm Post subject: Re: Idle Stabilizer Control Unit Alternative |
I should have some news in a few weeks. Just wanted to update. |
