Manx II “2-Face” Ecotec IRS Bus 091
Page: Previous  1, 2, 3, 4, 5, 6, 7  Next
sailtexas186548
sailtexas186548 is offline
PostPosted: Mon Jan 04, 2021 7:47 pm    Post subject: Re: Manx II “2-Face” Ecotec IRS Bus 091 Reply with quote
Benco built 091, bus to bug nose cone conversion, Weddle 3rd and 4th gears, upgraded gear carrier, super diff, bus flanges, maybe some other stuff I forgot that’s all the big ticket items
I’ve had the engine for a few weeks, 2.4L from Alphafab, claims 10.5:1 CR and 210hp. It doesn’t really matter it will be more than enough! Just going for reliable
Drive by wire pedal and ECU:
Also pulled the bender and notcher out, and picked up an air/hydro ram from HF and started putting together a bracket for it I’m done yanking on that lever
sailtexas186548
PostPosted: Sat Jan 09, 2021 6:52 pm    Post subject: Re: Manx II “2-Face” Ecotec IRS Bus 091 Reply with quote
Finally got going today, after failing to get .095 wall DOM local I had to settle for mounting the engine and transaxle.
Rolled it out into the sun for the first time in a while:
Using a SSC type 1 solid mount kit, and a 002 type 2 solid mount kit, and some plate steel I cobbled together a mount that works for the 091 and required minimal frame horn cutting. The engine is slightly off to the passenger side and the transaxle is sightless to drivers side (split the difference). I also had to push the transaxle forward and use a flat price of .200” steel as the front mount with the type 1 nose cone and stock pan side mount, or the shift rod would be too far back and the shift coupler would hit the torsion housing splined center section. I will be adding more support and a front mid-mount or strap but these mounts solidly locate the engine/transaxle. This pic shows the rear 002 mount, I actually needed to turn it around a backwards to shift the engine to the passenger side and clear the frame horns.
The engine (test fit as part of the transaxle mount adjusting) just barely clears the rear of the fiberglass and engine cut out and the vertical fiberglass wall, but it does! I modified the bell housing mount plate by enlarging the holes for the frame horn bolts on the top by .300” so the engine isn’t particularly high off the ground but I will not cut the body. With an 002 bell housing it would not have cleared. The throttle body is a little tight and I will have to machine it down but it will clear.
I took a chance on a Polaris slingshot header and got lucky, it fits great (1320 V2) and also clears the body, probably need a heat shield there just in case.
In the last pic you can see the space for a horizontal radiator above the transaxle with a couple puller fans.
it's more fun loud and dirty
sailtexas186548
PostPosted: Sun Jan 10, 2021 8:48 pm    Post subject: Re: Manx II “2-Face” Ecotec IRS Bus 091 Reply with quote
I finished the bender modifications today
Here is a pic of the front mount for the transaxle (need to drill the bolt holes once I pull the engine/trans again.
After hogging the bell housing mounting plate to lower and shift the engine the holes were way to big. I drilled a couple holes that fit the frame horn bolts tight then ground them down until they fit snug. I will tack these into place then weld them up both sides and dress down flat. I want to remove all slop/slotted holes so the engine will go back in the exact same spot every time
calebmelvin
calebmelvin is offline
PostPosted: Sun Jan 10, 2021 9:06 pm    Post subject: Re: Manx II “2-Face” Ecotec IRS Bus 091 Reply with quote
Holy cow! That is amazing! You have to take some videos when it is up and running. I need to see it on the road.
Caleb
'68 Tagged Manx | My Wanted Ads
Letterman7
Letterman7 is offline
PostPosted: Mon Jan 11, 2021 3:17 pm    Post subject: Re: Manx II “2-Face” Ecotec IRS Bus 091 Reply with quote
Looks great! I want to see how you do the pedal by wire conversion. Usually, all the electronics have to play together.. waiting to see how you approach this.
sailtexas186548
PostPosted: Thu Jan 14, 2021 7:41 pm    Post subject: Re: Manx II “2-Face” Ecotec IRS Bus 091 Reply with quote
Not much physical progress in the last few days, but I did get a bunch of parts coming. Clutch, starter, 5 sticks of .095 DOM, some .100”, 125”, and .200” plates, radiator, exhaust parts, and some bolts I was missing.
Kennedy stage 3 single disc, will be running their “street race organic” disc, hopefully this PP isn’t too hard on my clutch leg since I am sticking with cable actuated
Radiator, summit brand for a Jeep Cherokee, only $75 hard to complain about that!
For the DBZ fans!
joescoolcustoms
joescoolcustoms is offline
PostPosted: Tue Jan 19, 2021 10:21 pm    Post subject: Re: Manx II “2-Face” Ecotec IRS Bus 091 Reply with quote
Nicely done, and fast!
I have done 3, 091/2.4 LE5 combos and have enjoyed them all. My next one is going to be a 2.0/091 combo in my personal buggy.
For NORRA 1000 in April we are building two buggies that have the Alpha Fab 2.4 LE5s and they are Dyno'ed to 210 Crank HP. Alpha Fab is one of our sponsors.
The last one I built this Summer went on a wheel Dyno and shot out 165 HP and 168 ft/# torque. The torque was basically flat (less than 10% variance) from 1600 rpm to 5500 rpm. The pull is unreal heading up hills.
I do run the 9 inch clutches instead of the 8 inch. The 8 inch with a stage 3 are not enough for a stock 2.4 with the VVT. With the torque they have, I am blowing through the clutch at mid range rpm in the higher gears.
Bad News Racing 2018 NORRA 1000 3rd in Class
Looks like it was painted with a live chicken,polished with a brick and buffed with a pine cone
sailtexas186548
PostPosted: Fri Jan 22, 2021 10:05 pm    Post subject: Re: Manx II “2-Face” Ecotec IRS Bus 091 Reply with quote
Lots of little things done this week, tightened up a bunch of things that were only finger tight in case they had to come back off, welded up the engine mount, drilled the front trans mount, picked up a bundle of DOM and some plate.
Mounted the engine/transaxle for the almost last time, but now without a jack underneath! I can pick up a front wheel pretty easily with the engine in the rear now Laughing
sailtexas186548
PostPosted: Sun Jan 24, 2021 8:39 pm    Post subject: Re: Manx II “2-Face” Ecotec IRS Bus 091 Reply with quote
About 80% done with the cage now, all tacked together at this point. I have fit the diagonal bar but it cannot be tacked In Until another joint is welded up. The only bars I still need to bend are the door/elbow bars.
I also need to add gussets to the major joints, pan plates, and add some pan plate bolts and move them all up to 1/2”. Also looking into putting rocker bars under the pan that I could bolt the cage to through the pan/tub.
I ended up abandoning the steering column support bar, it was just not reasonably located to tie into the cage as the dash bar, I think it will be a better support in the new location anyways.
Last edited by sailtexas186548 on Fri Jan 29, 2021 4:08 pm; edited 1 time in total
sailtexas186548
PostPosted: Mon Jan 25, 2021 11:04 am    Post subject: Re: Manx II “2-Face” Ecotec IRS Bus 091 Reply with quote
Sorry I missed this before. The 2.4L LE5 Ecotec runs a “drive by wire” throttle stock, so I simply have to mount a stock GM pedal to my firewall and connect it to the wiring harness, no special programming tricks. It is actually easier than a mechanical throttle cable in my opinion.
joescoolcustoms
PostPosted: Mon Jan 25, 2021 11:29 am    Post subject: Re: Manx II “2-Face” Ecotec IRS Bus 091 Reply with quote
Having built one Ecotec Buggy with DBC, (Drive By Cable) and one Ecotec Buggy with DBW, (Drive By Wire), the DBW is SOOOOO Much Easier.
Mount it, plug and play.
I have already bought the pedal, Intake and Throttle Body for the next one to go DBW again.
Letterman7
PostPosted: Mon Jan 25, 2021 12:42 pm    Post subject: Re: Manx II “2-Face” Ecotec IRS Bus 091 Reply with quote
Did you or someone pare down the GM wire harness for all the conversions and reflashed the ECU? On my HHR with a 2.2 EcoTec, even a bulb out somewhere starts all sorts of warnings on the dash.
joescoolcustoms
PostPosted: Mon Jan 25, 2021 12:58 pm    Post subject: Re: Manx II “2-Face” Ecotec IRS Bus 091 Reply with quote
There are several companies, (4 I am aware of) that make a "Stand Alone" wire harness that eliminates all the other "Car" stuff and only takes Switched Power, Constant Power, and Ground to excite the ECU and run the engine. The harnesses will come with new connectors and a relay box for fans, fuel pump and so forth. Leads come off for Tach, oil pressure, water temp to run forward to the dash gauges.
sailtexas186548
PostPosted: Sat Jan 30, 2021 6:48 pm    Post subject: Re: Manx II “2-Face” Ecotec IRS Bus 091 Reply with quote
Drivers side elbow/door bar has been fit, it took some serious finesse to get it to drop in but I got it without scrapping the tube. the passenger side one should be a bit easier - I write down every step/length/angle when I make the first side as instructions for the other side.
calebmelvin
PostPosted: Sat Jan 30, 2021 8:47 pm    Post subject: Re: Manx II “2-Face” Ecotec IRS Bus 091 Reply with quote
That cage is looking nice!
Caleb
sailtexas186548
PostPosted: Sat Jan 30, 2021 9:26 pm    Post subject: Re: Manx II “2-Face” Ecotec IRS Bus 091 Reply with quote
Thanks! It’s not perfect but it’ll work
Fit the diagonals, just need to add some tacks and it’s ready to pull out and weld/gusset. Tomorrow I will build the engine cage, gotta search and get some ideas tonight the Ecotec motor mounts are Low and on the sides/rear, hard to get any meaningful support without going up and over the body and I’m NOT doing that
sailtexas186548
PostPosted: Sun Jan 31, 2021 9:41 pm    Post subject: Re: Manx II “2-Face” Ecotec IRS Bus 091 Reply with quote
Finished the engine cage but still need to add engine mounts And tie it into the cage through the rear firewall. I have about 1/2” maybe 5/8” clearance to the engine and oil pan, just need some skid plate material now.
I ended up adding some bars to the rear of the main cage in the package tray area so I have something more solid to tie the engine supports to.
sailtexas186548
PostPosted: Tue Feb 02, 2021 10:11 pm    Post subject: Re: Manx II “2-Face” Ecotec IRS Bus 091 Reply with quote
Made up the motor mounts tonight, passenger side needed an offset so I repurposed a couple inches of bottle jack handle.
Also made the backing plates and drilled/tacked in place so all cage parts inside minus gussets are fit.
I am going to tie the through “firewall” plates direct to the engine mounts to give some support to the cantilevered engine. I intend to leave the engine and rear cage/bumper independent so the engine and trans don’t see the loads from bottoming out. Still need to look at that concept since the bumper/cage might just bend up too easy and hit the engine anyways... perhaps tie it into the firewall plates and bypass the engine so the force will push up on The cage and therefor pull up on the engine. I will figure it out
joescoolcustoms
PostPosted: Wed Feb 03, 2021 4:36 am    Post subject: Re: Manx II “2-Face” Ecotec IRS Bus 091 Reply with quote
Very nice work! Keep after it!
sailtexas186548
PostPosted: Wed Feb 03, 2021 9:39 pm    Post subject: Re: Manx II “2-Face” Ecotec IRS Bus 091 Reply with quote
Fit the engine mount hangers, I could put my weight on the engine and move it 3/16” down, now it’s ROCK SOLID and the whole car moves when I bounce on it. Not gonna tie the engine cage/bumper in, I will weld it up and see how stiff it is, I think plenty for the driving this car will see
Page 2 of 7
