Stupid Question Ahead: How does one install this repair panel?
P24p1
P24p1 is offline
PostPosted: Tue Dec 29, 2020 4:14 pm    Post subject: Stupid Question Ahead: How does one install this repair panel? Reply with quote
Is this crossmember repair panel:
https://store.concept1.ca/T2-Cross-Member-Front-73-79-%289556800%29-9556800/
Intended to be used as a sort of sleeve? I have one from PO that I have not installed, it's wider than the original and short enough to fit between the main frame rails and therefore slides right onto the original. This leads me to think that maybe this panel can be installed over the original without having to cut said original out first? I feel stupid asking this but I'm new to welding and restoring a VW bus and I can't find any info on why this cross member is different than, say, this one:
https://store.concept1.ca/T2-Cross-Member-Front-68-72-%289555800%29-9555800/
Thanks!
67ctbug
67ctbug is offline
PostPosted: Tue Dec 29, 2020 4:23 pm    Post subject: Re: Stupid Question Ahead: How does one install this repair panel? Reply with quote
Well for one they’re for different years. ‘68-‘72 vs ‘73-‘79. This may explain why you’re able to slip it over. I will suggest you don’t slip it over though, that’s a good way to make the bus rust out again.
'67 Beetle L41
'71 Westfalia (sold) Sad
'74 Westfalia
‘69 Plymouth
Go Cubs!
World Series Champions 2016
KentPS wrote:
...or the PO envied the terrorists' bus in "Back to the Future". Laughing
mukluk wrote:
He's fine, just waiting for the dragon in winklepickers to move out of his lane.
View user's profile Send private message Visit poster's website Facebook Twitter Instagram Gallery Classifieds Feedback
cmonSTART Premium Member
cmonSTART is offline
PostPosted: Tue Dec 29, 2020 4:48 pm    Post subject: Re: Stupid Question Ahead: How does one install this repair panel? Reply with quote
Personally I would look for a better panel. Klokkerholm are a last resort IMO and weird fits wouldn't surprise me.
'78 Bus 2.0FI
de K1IGS
busdaddy
busdaddy is offline
PostPosted: Tue Dec 29, 2020 4:50 pm    Post subject: Re: Stupid Question Ahead: How does one install this repair panel? Reply with quote
Odd that the lower one says 68-72, from here it looks to have the larger holes for the 73+ heater tubing.
That top one is for the lazy flipper, it goes hand in hand with the inner rockers with similar cutouts for quickly slipping over the rusty mess and making it look good enough to sell. If the upper part of your existing part is intact and you cut away most of what the new one covers it'll be better than nothing under there, but if you want it done right you'll have to drop the heater tubes and some of the cable tubes to get the full sized part in.
SGKent Premium Member
SGKent is offline
PostPosted: Tue Dec 29, 2020 5:07 pm    Post subject: Re: Stupid Question Ahead: How does one install this repair panel? Reply with quote
add the year of your bay to your avatar or sig line.
American Standard Snorkeling Terrier
Preserve YOUR Freedom of Speech ~ as best you can, avoid Amazon, Facebook, Twitter, and Google. Support businesses near you, and buy local whenever you can.
P24p1
P24p1 is offline
PostPosted: Tue Dec 29, 2020 5:21 pm    Post subject: Re: Stupid Question Ahead: How does one install this repair panel? Reply with quote
I've taken that one as a rough example, but the website has both versions for the 68-72 models, that is a "slip over" one and a full one. Mine is a 73-79 for my 73 so it's not the wrong year
P24p1
P24p1 is offline
PostPosted: Tue Dec 29, 2020 5:23 pm    Post subject: Re: Stupid Question Ahead: How does one install this repair panel? Reply with quote
Done!
Angie the 1973 1.7l Westfalia Rust Bucket
P24p1
P24p1 is offline
PostPosted: Tue Dec 29, 2020 5:28 pm    Post subject: Re: Stupid Question Ahead: How does one install this repair panel? Reply with quote
Sorry that was maybe not the best example, I've seen the same variant of panel for both variations of buses.
So what I'm taking away from what you're saying is that it does slip right over, awesome! I'll take the lazy flipper route Very Happy Hey, this is the same bus that's getting a Rustoleum paint job so it's good enough! In all seriousness though, the hole in the cross member is maybe a few inches across, I'd say 80% of the original panel is still intact, so I think this will do for now.
Abscate Premium Member
Abscate is offline
PostPosted: Tue Dec 29, 2020 5:45 pm    Post subject: Re: Stupid Question Ahead: How does one install this repair panel? Reply with quote
Rustoleum??
Cue the BeArs!!
Seriously , good luck with your restoration
.ssS!
P24p1
P24p1 is offline
PostPosted: Tue Dec 29, 2020 5:51 pm    Post subject: Re: Stupid Question Ahead: How does one install this repair panel? Reply with quote
Abscate wrote:
Rustoleum??
Cue the BeArs!!
Thank you! Very Happy The paint job is actually going very well believe it or not!
Joey
Joey is offline
PostPosted: Tue Dec 29, 2020 7:06 pm    Post subject: Re: Stupid Question Ahead: How does one install this repair panel? Reply with quote
If you slip that new crossmember over the old one moisture will get trapped between the two and they will both rust out in a very short time.
Joey
‘60 Kombi - '74 Bus - '79 Panel - '56 Beetle - '65 Beetle
P24p1
P24p1 is offline
PostPosted: Tue Dec 29, 2020 7:57 pm    Post subject: Re: Stupid Question Ahead: How does one install this repair panel? Reply with quote
There actually isn't any visible rust, it's all black. Maybe a rust paint or undercoat? I'm not sure. I do agree with you fully so what I think I'll do is at least cut out the "diseased" part and then slip it over, also maybe shoot some Rustoleum or Fluid Film up in it while I'm at it to deal with any potential moisture. Like I said, the majority of the panel is fine so hopefully it will last. If anything I could cut the repair panel to only cover the part that rusted out, that might be smart too. (?)
SamboSamba22 Premium Member
SamboSamba22 is offline
PostPosted: Wed Dec 30, 2020 10:29 am    Post subject: Re: Stupid Question Ahead: How does one install this repair panel? Reply with quote
Abscate wrote:
Rustoleum??
Cue the BeArs!!
Dammit, I miss Tim.
The Bus Barn Ltd. Co.
Oct. ’67 Double Cab (’68 Crew Cab)
[url=http://www.vw-mplate.com/mplate-44412.png]Click to view image[/URL]
March '69 Delivery (Panel Bus)
[url=http://www.vw-mplate.com/mplate-44414.png]Click to view image[/URL]
Alan Brase
Alan Brase is offline
PostPosted: Sun Jan 03, 2021 1:50 pm    Post subject: Re: Stupid Question Ahead: How does one install this repair panel? Reply with quote
SamboSamba22 wrote:
Abscate wrote:
Rustoleum??
Cue the BeArs!!
Dammit, I miss Tim.
Remind me, who is TIM? and what became of him?
Al Brase
Projects: 67 sunroof bug, 67 Porsche 912 Targa, 70 Westy
Dec 1955 Single Cab pickup WANT 15" BUS RIMS dated 8/55, thru 12/55
To New owners: 1969 doublecab, 1971 Dormobile
Vanagons:
80 P27 Westy JUL 1979, 3rd oldest known US
83 1.6TD Vanagon, 87 Wolfie Westy daily driver, swap meet home
Slip356
Slip356 is offline
PostPosted: Mon Jan 04, 2021 6:32 am    Post subject: Re: Stupid Question Ahead: How does one install this repair panel? Reply with quote
P24p1 to bring out the haters here is my experience.
About 15 yrs ago I purchased a rust free 78 Canadian Westy from a woman who owned it for 20 plus years. It had been ZBart type rust proofed.
It was really clean, however when I got home, after driving it from north Of Seattle to N WI with my wife, & camped all the way back I put it up on a lift only to find the inner drivers side dog leg was rusted through. That was all the rust I could find. Nothing showed exterior wise.
Thought, oh shit, ‘ I’ll get a new dogleg installed, someday.’ Cleaned up the visible rust, soaked it with Ospho and heavily sprayed it with 3M undercoating including inside the dogleg through the rust hole. Once per year when doing annual maintenance I check it and spray other areas where original rust proofing has come off exposing factory paint.
This temp repair has lasted for 15 yrs. and shows no evidence of changing.
Yes, I will get a new dogleg installed, someday.
Alan Brase
PostPosted: Mon Jan 04, 2021 12:22 pm    Post subject: Re: Stupid Question Ahead: How does one install this repair panel? Reply with quote
INNER? I'd just patch it. I would say very few have the skill to make a good patch that does not stir up more trouble especially at the rear where it attaches to the bulkhead/B pillar.
I'm pretty sure after the factory welds the whole thing together, they dip the whole car in phosphoric acid wash. Then paint it. then seam seal it.
Ospho use was a good plan in your case.
Al Brase
Vanagons:
P24p1
P24p1 is offline
PostPosted: Fri Jan 29, 2021 1:39 pm    Post subject: Re: Stupid Question Ahead: How does one install this repair panel? Reply with quote
Well you know what they say, temporary repairs are permanent repairs! I indeed plan on the old "apply rust preventer on the reg" for many parts of my bus
