Which MIG welder? |
Lincoln Weld-pak 140 |
33% |
[ 1 ] |
Hobart Handler 140 |
66% |
[ 2 ] |
Total Votes : 3 |
ncpi Samba Member
Posted: Fri Jan 01, 2021 9:54 am Post subject: Help me decide on a new welder |
I'm going to bite the bullet and get a new 110V MIG that can do either Gas or Flux-wire.
I have it down to either a Lincoln 140 Weld-pak or a Hobart Handler 140.
Comments appreciated too, especially if you have experience with both.
Thanks guys |
panel Samba Member
Joined: December 02, 2001 Posts: 1090 Location: Victoria B.C. Canada
Posted: Fri Jan 01, 2021 11:21 am Post subject: Re: Help me decide on a new welder |
I love my Lincoln Weld-pak 140. Mid size bottle on a cart. It's about the height of the welder when its all on the cart. Its just perfect ! _________________ My '65-Subaru EJ20 Turbo conversion |
esde Samba Member
Joined: October 20, 2007 Posts: 5966 Location: central rust belt
Posted: Fri Jan 01, 2021 1:46 pm Post subject: Re: Help me decide on a new welder |
Both are comparable in ability, but I'd say that the Hobart is a little better built. _________________ modok wrote:
scottyrocks Samba Member
Joined: August 19, 2016 Posts: 2661 Location: Long Island, NY
Posted: Fri Jan 01, 2021 6:05 pm Post subject: Re: Help me decide on a new welder |
I'd like to know, too, because my store carries the Lincoln, and it would be an easy purchase. _________________ “If you care for a thing long enough, it takes on a life of its own, doesn't it? Mending old things, preserving them, looking after them – on some level there's no rational grounds for it.”
– D. Tartt, 'The Goldfinch' |
infiniteLoop Samba Member
Joined: October 09, 2020 Posts: 265 Location: Empire State
Posted: Fri Jan 01, 2021 6:54 pm Post subject: Re: Help me decide on a new welder |
The Hobart has an additional voltage setting over the Lincoln. There's also the Hobart Handler 125. |
panel Samba Member
Posted: Fri Jan 01, 2021 9:33 pm Post subject: Re: Help me decide on a new welder |
infiniteLoop wrote: |
additional voltage setting |
Was wondering what you meant buy this ? _________________ My '65-Subaru EJ20 Turbo conversion |
Posted: Sat Jan 02, 2021 5:46 am Post subject: Re: Help me decide on a new welder |
The only All-Transformer welders that I'm aware of that are available new ,have a Voltage Tap switch and are not infinitely variable . This means that if you have let's say a 125 amp machine;
Setting one is 25 volts.
two is ,40 volts
three is 70 and
4 is 125.
At one time I was interested in a Hobart Ironman and talked to a Hobart sales rep about the welder. He said that the lower settings are bunched up and the higher you go the bigger difference the settings make. I would actually prefer a voltage tap machine but in my opinion they need about twice as many settings as they give you. For a 102 amp welder I would want at least 7 settings.
Before inverters dominated the market, the big selling point with welders was if they had Infinitely Variable Voltage Control or not.
The Lincoln 140C has it but as all Lincoln welders , you don't get a lot for your money at $1000 bucks. |
ncpi Samba Member
Posted: Sat Jan 02, 2021 6:43 am Post subject: Re: Help me decide on a new welder |
Good info guys... its tied at 50/50 right now.
I did learn a couple things I didn't realize.
1) that the Hobart has an extra voltage selection (5 vs 4)
2) the Hobart might be a bit more robust.
It seems Lowes and HD both carry the Lincoln brand...that would make it easier for getting tips and stuff when you need them.
Oh...the Hobart Handler 125 has a gas switch but doesn't come with the full gas set-up. If I really want gas then I might as well get the 140.
Please keep your input and votes coming! |
Posted: Sat Jan 02, 2021 9:59 am Post subject: Re: Help me decide on a new welder |
Have you seen this thread?
https://www.thesamba.com/vw/forum/viewtopic.php?t=157122
I have found it very helpful, as I am shopping for a welder right now, and have pages of notes to attempt to narrow my choice down.
I, too, want a 140-ish, 110v, gas welder, of which the Lincoln 140 is a finalist. _________________ “If you care for a thing long enough, it takes on a life of its own, doesn't it? Mending old things, preserving them, looking after them – on some level there's no rational grounds for it.”
c21darrel Samba Member
ncpi Samba Member
Posted: Sat Jan 02, 2021 2:23 pm Post subject: Re: Help me decide on a new welder |
scottyrocks wrote: |
I, too, want a 140-ish, 110v, gas welder, of which the Lincoln 140 is a finalist. |
Yes, I did and read the whole thing Good thread. Thanks! |
ncpi Samba Member
Posted: Sat Jan 02, 2021 2:25 pm Post subject: Re: Help me decide on a new welder |
c21darrel wrote: |
I have the Hobart 140. It was a craigslist buy, well worth the $375. I matched it to a Harbor Freight wheeled cart and picked up a gas bottle also from craigslist. About $500 and ready to go. Works best with gas. I only do small stuff, its been perfect for welding in patches in my double cab build. The more you weld the better you get. Im still better with the grinder. When you have a welder, you find more things to do with it, and become more popular with non welder owning friends.
Nice work! I guess in reality I probably can't go wrong with either the Lincoln or the Hobart. |
Posted: Sat Jan 02, 2021 3:20 pm Post subject: Re: Help me decide on a new welder |
ncpi wrote: |
c21darrel wrote: |
I think you know all you need to know. _________________ GhiaBuild
1967 DC build
Posted: Sat Jan 02, 2021 5:34 pm Post subject: Re: Help me decide on a new welder |
Quote: |
It seems Lowes and HD both carry the Lincoln brand...that would make it easier for getting tips and stuff when you need them. |
Farm Centers sell Hobart Welders. Consumables for a MIG welder last a long time. Your gun and liner will probably wear out and or break before a you need more contact tips/ nozzles. |
ncpi Samba Member
Posted: Sun Jan 03, 2021 8:16 am Post subject: Re: Help me decide on a new welder |
Bit the bullet! Purchased the Hobart from Northern Tool. Amazon's delivery was out in February.
The swingers for me... the extra Voltage setting, the wire feed "seems" better and the warranty is much better (5 yrs on transformer,/3 on the electronics/1 on the gun vs Lincoln is 1 yr/gun is 90 days). Plus its actually made in the good old USA. |
