gas tank question
space
space is offline
PostPosted: Mon Jan 04, 2021 9:41 am    Post subject: gas tank question Reply with quote
Has anyone replaced the stock gas tank with a different one?
I would like to get more than 240 miles between fill ups
Ive read through many past forum posts and there does not seem to be a definitive answer
I was thinking that a larger capacity tank can be used in lieu of the stock
My thoughts are:
1 The overflow tanks could be eliminated
2 A larger cap tank could be used (wouldnt need the the depression in the center)
3 Would make the fuel line arrangement cleaner and easier to replace (fill, vent, supply and return)
Any thoughts on this?
T
jlrftype7
jlrftype7 is offline
PostPosted: Mon Jan 04, 2021 10:26 am    Post subject: Re: gas tank question Reply with quote
The easiest path is to put an AUX tank in line with your existing one, don't mess with the Evap system other than to work a vent on the new AUX tank, and plumb to the stock system. Support it between the frame rails, keep it away from cables and piping. The saddle design works for the Vanagon since you can run the existing cables and etc between the tanks with that large depression in the middle. So, a similar design further back that Tees into the stock tank seems pretty easy.
There was the person who made a custom tank to fit above the Transaxle in that empty space there. I'm guess you read that post already
'67 Type 3 Fastback, my 2nd car- also long gone
'69 Semi-Auto Stick Shift Beetle, my wife's first car= yep. still long gone....
84 Tin Top - Hilga....Auto
space
space is offline
PostPosted: Mon Jan 04, 2021 10:32 am    Post subject: Re: gas tank question Reply with quote
Thanks for the insight
I did read about the custom tank
Would prefer an off the shelf tank as I would feel more comfortable with its design and integrity
T
MarkWard
MarkWard is offline
PostPosted: Mon Jan 04, 2021 10:36 am    Post subject: Re: gas tank question Reply with quote
There is a larger capacity fuel tank out there. It might be from the south African market. The one I saw required cutting the rear chassis brace to make room and then an alternate section for the longer tank straps you will also need.
I wasn't impressed.
1982 Vanagon Camper with ALH TDI.
In Car https://youtu.be/5hbfdUJR88Q
space
space is offline
PostPosted: Mon Jan 04, 2021 10:39 am    Post subject: Re: gas tank question Reply with quote
I wasn't impressed.
I dont think they are easy to find either
From what ive read they are +$500 as well
jlrftype7
PostPosted: Mon Jan 04, 2021 11:29 am    Post subject: Re: gas tank question Reply with quote
I wasn't impressed.
What about a Racing Fuel Cell type arrangement?
space
space is offline
PostPosted: Mon Jan 04, 2021 11:33 am    Post subject: Re: gas tank question Reply with quote
jlrftype7 wrote:
I wasn't impressed.
Ive been looking at those
That might be the best option
BTW I see ur in Chicago I'm in the sw burbs
T
jlrftype7
PostPosted: Mon Jan 04, 2021 12:00 pm    Post subject: Re: gas tank question Reply with quote
space wrote:
jlrftype7 wrote:
I wasn't impressed.
T
Hey, local and what not..... Cool
Russpauly
Russpauly is offline
PostPosted: Mon Jan 04, 2021 1:36 pm    Post subject: Re: gas tank question Reply with quote
Shocked I'd like to get more that 200 between fill ups! Crying or Very sad
1988 Wolfsburg Edition - TinTop
2.1L Watercooled
The Space man Van
valvecovergasket
valvecovergasket is offline
PostPosted: Mon Jan 04, 2021 2:08 pm    Post subject: Re: gas tank question Reply with quote
hmmm
Smile
easier than reworking the entire fuel tank location/mounting? perhaps... Razz
MegaSquirt resource - SpitfireEFI.com
'83 tdi westy - swap thread
jlrftype7
PostPosted: Mon Jan 04, 2021 2:20 pm    Post subject: Re: gas tank question Reply with quote
valvecovergasket wrote:
hmmm
Smile
HAH........ Applause Applause
danfromsyr
danfromsyr is offline
PostPosted: Mon Jan 04, 2021 2:21 pm    Post subject: Re: gas tank question Reply with quote
so you want off the shelf add on accessory aux tank for the vanagon.
http://www.foreignautosupply.com/parts-accessories/54-syncro-auxiliary-fuel-tank/#.X_OFjthKiUk
I don't know why they say this is 'syncro only' other than needing a little more creativity for the 2wd filler to share between 2 tanks.
but then you also want it cheap.
yeah ok buddy.,
240mi range is just fine.. stop for another coffee. and you'll need a restroom too.
I run a 9gal tank mounted on the spare tire clamshell. but that's not off the shelf
though I didn't have any other modification aside from relocating the spare tire.
wasn't it furry little otter who remade the oem tank?
and shagginwaggen has a DIY custom saddle tank..
bobbyblack Premium Member
bobbyblack is offline
PostPosted: Mon Jan 04, 2021 2:47 pm    Post subject: Re: gas tank question Reply with quote
SyncroJael's extra tank springs to mind.. Off the shelf? Nope.. Nice tho
'87 Westy 'Flossie','86 Westy R1R1,'83.5 Vanagon L 'ZoomBus','74 Karmann Ghia, '63 Notch
space
space is offline
PostPosted: Mon Jan 04, 2021 2:56 pm    Post subject: Re: gas tank question Reply with quote
yeah ok buddy.,
Having run out of gas on 41 in the everglades where the the stations are few and FAR between would have been a nice to have a 300 mile range
Also, I would rather spend time driving than filling up every 3.5 hours Laughing
Is that tank mounted outside the frame rails?
Seems to hang pretty low as well
Do you know the dimensions?
DuncanS
DuncanS is offline
PostPosted: Mon Jan 04, 2021 2:58 pm    Post subject: Re: gas tank question Reply with quote
You didn't say whether you are syncro or 2WD. If 2WD, just add a Syncro tank over the tranny and you will get over a 500 mile range.
https://www.ebay.com/itm/Genuine-Volkswagen-Fuel-T...872399283?
space
space is offline
PostPosted: Mon Jan 04, 2021 3:09 pm    Post subject: Re: gas tank question Reply with quote
2wd Duncan
Thanks for the link
danfromsyr
PostPosted: Mon Jan 04, 2021 3:35 pm    Post subject: Re: gas tank question Reply with quote
do note that to add a Syncro tank to a 2wd you will need to lower the engine & transmission by 2inches.
it's ok since you have to remove the trans to install the tank anyways.
and add in the tank mounting panel & straps
and the syncro filler. pipe & inlet box.
iirc the pipe is getting harder to come by.
get gas more often
especially when you know it's going to be a stretch till the next pump
or strap a carry can on the roof like everyone out west does.
danfromsyr
PostPosted: Mon Jan 04, 2021 3:43 pm    Post subject: Re: gas tank question Reply with quote
adding to this conversation fwiw it's not off the shelf either. there's DIY installation requirements.
the greasecar round tank will fit in the clamshell, resting on a rubber pads and strapped to the clamshell.
https://www.greasecar.com/product-page/22-tirewell-tank-11-5-gal
old_man
old_man is offline
PostPosted: Mon Jan 04, 2021 3:51 pm    Post subject: Re: gas tank question Reply with quote
I offer a cheap and simple solution. It does require that you pull over though.
space
space is offline
PostPosted: Mon Jan 04, 2021 4:03 pm    Post subject: Re: gas tank question Reply with quote
Thanks for the link Dan
