allamaabroad Samba Member
Joined: September 22, 2016 Posts: 372 Location: South Jordan, Utah
Posted: Mon Jan 04, 2021 6:52 pm Post subject: Clutch Recommendations |
Looking for a recommendation for a clutch disc for my new turbo 2176 motor (build thread soon to come) As far as I have seen, this motor should be very capable of 220+ hp, and it is meant to be a daily driver. I’ve already purchased a stage 2 pressure plate from Kennedy, and I now need to decide on a disc.
What do you recommend? _________________ Dennis - 1973 Super Beetle ('16-'21)
Debbie- 1970 Baywindow Bus ('21 - Present)
Tin top camper/adventure bus
2176 Turbo, CNC Panchitos, Wiseco Pistons, CB 2288, Ultralight Lifters, 1.4 Rockers, Blow Through IDF's w/ Custom Sidewinder Turbo
...all inside a bus
It's not a project unless it has rust |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 70431 Location: Long Island, New York, USA
buguy Samba Member
Joined: November 17, 2003 Posts: 4658 Location: Port Orange, FL
Posted: Mon Jan 04, 2021 7:14 pm Post subject: Re: Clutch Recommendations |
Don't have a lot of choice with that kind of power. You will be on the edge with a stage 2 and Daikin disk at that level. Mine started to slip around that power. I went with a stage 2 and a centerforce, and it held for the 15 miles i got on it. It held enough to break the axle.
I think if i were to do it again i would spring for something like a Kennedy dual disk. Pair that with a stage 1 pressure plate. |
Stripped66 Samba Member
Joined: May 31, 2005 Posts: 3328 Location: Charleston, SC
Posted: Mon Jan 04, 2021 7:19 pm Post subject: Re: Clutch Recommendations |
buguy wrote: |
I went with a stage 2 and a centerforce... |
I also daily-drove a Stage 2 with a Centerforce (Berg) disc for years. No complaints, I'd do it again. _________________
66brm wrote: |
Bodacious wrote: |
Why not just make a custom set of wires with a Y splice in them. Then you could just run one distributor. |
I don't think electrickery works that way |
esde Samba Member
Joined: October 20, 2007 Posts: 4535 Location: central rust belt
Posted: Mon Jan 04, 2021 7:33 pm Post subject: Re: Clutch Recommendations |
Glenn wrote: |
A Stage II will get old real fast if you drive in traffic. |
I have the "long" arm on the clutch shaft, and it's not bad at all. If you use the stock short arm it is a bit tighter. _________________ modok wrote:
clonebug Samba Member
Joined: January 29, 2005 Posts: 3381 Location: NW Washington
Posted: Mon Jan 04, 2021 8:29 pm Post subject: Re: Clutch Recommendations |
I have a Kennedy Stage II PP with a CB Super Disc tested and then shimmed .031" to get me to holding 250 ft. lbs. torque on my torque wrench. I would have tested higher but my torque wrench was maxed out.
I recommend testing anything you install. That way you know what you gain when you change.
Get an old input shaft and weld a 1/2 inch drive socket on it or a 15/16ths nut and then you can use a torque wrench to test.
I used a metric Wavy washer under each pad to get my .031" shim...It's worked well for three seasons now.
I drive it daily spring through fall and have at least 13,000 miles on the combo. I did add a 100mm arm...actually I extended a stock arm to 100mm since I couldn't find a long arm at the time.
I have no issues driving it on the street. It is a little stiffer than the Stage I but not like it would bother.
So far it's holding 220 plus crank hp. _________________
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
(Now with Water/Alcohol Injection)
Upgraded to MS-2 Extra direct fire wasted spark
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
buguy Samba Member
Posted: Mon Jan 04, 2021 8:56 pm Post subject: Re: Clutch Recommendations |
My new trans has a long arm so I'm looking forward to that. Art do you have any idea what your car weighs? Would weight impact clutch holding much? |
Posted: Mon Jan 04, 2021 10:09 pm Post subject: Re: Clutch Recommendations |
I already have an ACE copperhead disc, sounds like that's pretty much the same thing as the super disc/centerforce. Is that correct?
I was pretty happy with the copperhead on my 1915, I'd happily use it again if it will work nicely with the stage 2 on this motor. _________________ Dennis - 1973 Super Beetle ('16-'21)
...all inside a bus
Posted: Mon Jan 04, 2021 10:23 pm Post subject: Re: Clutch Recommendations |
Copperhead disc should give a lot more holding power than a CB Super Disc.
I would try that disc with the Stage I if you already have it...it might be all you need....But since you have a Stage II on the way you might as well run the Copper Disc.
I'm turboed with a 1679 and 220 crank hp.....you should be itching to turn it up and surpass me in a few months of driving.
I know Chip and Mario were having clutch issues way back when...Mario was fighting it at 236 whp and Chip was way up there too and having slippage issues. _________________
Paul.H wrote: |
Posted: Mon Jan 04, 2021 10:24 pm Post subject: Re: Clutch Recommendations |
buguy wrote: |
My Buggy weighs 1660 with me in it.....I would say tire would have a bunch to do with it.
Put an 11 inch wide tire in the back of your bug........  _________________
Paul.H wrote: |
neil68 Samba Member
Joined: March 17, 2007 Posts: 3400 Location: Calgary, Canada
Posted: Mon Jan 04, 2021 11:25 pm Post subject: Re: Clutch Recommendations |
KEP Stage 2 with Centerforce dual-friction disc and 100mm clutch lever. 204 WHP in my street-strip Beetle. _________________ Neil.
Der Kleiner Rennwagens
68 Beetle 2332 cc, 204 WHP
12.5 seconds @ 107 mph
Dynojet Test: https://www.youtube.com/watch?v=M9B_H3eklAo |
buguy Samba Member
Posted: Tue Jan 05, 2021 4:34 am Post subject: Re: Clutch Recommendations |
clonebug wrote: |
buguy wrote: |
Put an 11 inch wide tire in the back of your bug........  |
I wish i could! It needs it! But i have to say, i don't think that is really much lighter than mine. I was expecting you to say more like 1400#. My 65 is only 1600# stock. Ive never weighed it myself. A little more with the turbo, electronics, and W/A intercooler....and my 160#. But i also have no chrome, bumpers, one piece windows, and glass fenders. |
madmike Samba Member
Joined: July 11, 2005 Posts: 3716 Location: Atlanta,Michigan
Posted: Tue Jan 05, 2021 4:40 am Post subject: Re: Clutch Recommendations |
with a stage 1  _________________ 65 Baja (sold)
68 VolksRod Coupe(sold)
Porsche/Laser 917(sold)
'Black Ice'Drag Buggy 1915 'Turbo'
Mid-Engine Dragster 2332 w/IDA's(gone)
'White Out' 76 Drag/Street bug 2276 'Turbo' 11:85 @113 MPH
70 MicroBus 2110 w/40 IDF's
I build my own Motor's & transmission's |
Posted: Tue Jan 05, 2021 6:28 am Post subject: Re: Clutch Recommendations |
1660 lbs is with me in it... Not many cars move without a driver..
The roll bar added 110 lbs. It used to be 1540 lbs with me in it. _________________
Paul.H wrote: |
Glenn  Mr. 010
volksworld Samba Member
Joined: November 26, 2011 Posts: 2209 Location: formerly NY currently NC
Posted: Tue Jan 05, 2021 9:12 am Post subject: Re: Clutch Recommendations |
well they added 3 more rivets in hopes of it not exploding... |
Posted: Tue Jan 05, 2021 11:08 am Post subject: Re: Clutch Recommendations |
look real close guys ,, Made in USA
have same one in my turbo bug for the last 5 YEARS  _________________ 65 Baja (sold)
Casting Timmy Samba Member
Joined: August 04, 2012 Posts: 1170 Location: Kansas City, Kansas
Posted: Tue Jan 05, 2021 11:16 am Post subject: Re: Clutch Recommendations |
a lighter disc can be controlled better by the synchros in the transaxle....another factor of how much disc/ plate to run is how much transaxle you have.
I've recommended some people disc or plate down a little if they aren't going to do much with their transaxle, clutches are easier to replace than the transaxle. _________________ T1 IRS Rebuild Book on Lulu.com
http://www.lulu.com/shop/tim-marshall/t1-irs-transaxle-book/paperback/product-24055997.html
As seen in Volks America Issue 14 Page 11 (Full page review) |
74 Thing Samba Member
Posted: Tue Jan 05, 2021 12:05 pm Post subject: Re: Clutch Recommendations |
Casting Timmy wrote: |
I've recommended some people disc or plate down a little if they aren't going to do much with their transaxle, clutches are easier to replace than the transaxle. |
That is what Scott always says, a lighter clutch disc saves synchros compared to a heavy copper disc. |
Posted: Tue Jan 05, 2021 12:17 pm Post subject: Re: Clutch Recommendations |
shhh I was trying to drum up some business for u guys  _________________ 65 Baja (sold)
