charleslabri Samba Member
Joined: December 08, 2019 Posts: 615 Location: Nashville/Yosemite
Vanagon Nut Samba Member
Joined: February 08, 2008 Posts: 10371 Location: Sunshine Coast B.C.
Posted: Wed Jan 06, 2021 6:52 pm Post subject: Re: solo clutch bleed |
Raise front, gravity bleed? _________________ 1981 Westy DIY 15º ABA
1988 West DIY 50º ABA
VE7TBN |
Howesight Samba Member
Joined: July 02, 2008 Posts: 3274 Location: Vancouver, B.C.
Posted: Wed Jan 06, 2021 7:01 pm Post subject: Re: solo clutch bleed |
Get the front end of the Van elevated. Fill the brake fluid reservoir. Place a clear plastic hose over the bleeder screw that is dipped into a container of clean brake fluid and crack open the bleeder. If you can get the catch-container in a position close to the bleeder, then you can watch and wait for the brake fluid to fill the clear plastic hose.
Once that happens, you can step on the clutch pedal quickly, but release the pedal very slowly. Now tighten the bleeder screw and check whether the air is bled. Repeat as needed.
Another variation on this is to use a standard pressure bleeder if you have one, although I assumed from your post that you don`t have one. _________________ '86 Syncro Westy SVX |
1988M5 Samba Member
Joined: January 23, 2016 Posts: 674 Location: Santa Cruz, CA
Posted: Wed Jan 06, 2021 7:39 pm Post subject: Re: solo clutch bleed |
I've had great success by backward bleeding. Get yourself a brand new oiler can and a piece of clear tubing to connect the cans output to the slaves bleeder. Crack the bleeder and pump fluid into the slave pushing fluid backwards and ending up in the front master cylinders' reservoir. Make room for this fluid by sucking some out to make room for the new fluid coming in by this method. Keep the oiler can flat to gravity and use the clear tube to insure your pumping perfect fluid and no air bubbles.
BK _________________ 1991 tin top GL
Some BMWs. |
GoEverywhere Samba Member
Joined: December 13, 2020 Posts: 516 Location: Portland, OR
Posted: Wed Jan 06, 2021 7:53 pm Post subject: Re: solo clutch bleed |
Its redneck, but I used a push broom.
Pumped up the pedal, wedged the broom on the pedal and the back of the driver's seat. Then went back and opened the bleeder. Repeat a few times. Worked great, if a little awkward. |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4777 Location: Bemidji, MN
Posted: Wed Jan 06, 2021 7:56 pm Post subject: Re: solo clutch bleed |
MightyVac pump on the bleed nipple. _________________ -dan
www.thefixitworkshop.com |
1988M5 Samba Member
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17122 Location: Retired South Florida
Posted: Wed Jan 06, 2021 8:24 pm Post subject: Re: solo clutch bleed |
Not my idea. Connect a snug hose between the l/r wheel cylinder bleed and the clutch slave bleed. Open both valves and pump the brake pedal. This will back bleed the clutch, no fluid loss. After you feel you’ve pumped brake enough, close both bleeders and you are back in business. _________________ ☮️ |
1988M5 Samba Member
Posted: Wed Jan 06, 2021 8:47 pm Post subject: Re: solo clutch bleed |
MarkWard wrote: |
Not my idea. Connect a snug hose between the l/r wheel cylinder bleed and the clutch slave bleed. Open both valves and pump the brake pedal. This will back bleed the clutch, no fluid loss. After you feel you’ve pumped brake enough, close both bleeders and you are back in business. |
That's the most eye opening shade tree/Nairobi technique I've heard in decades.
Bravo sir.
Some BMWs. |
buspor63 Samba Member
Joined: February 17, 2005 Posts: 1179 Location: Knoxville,TN Where America stops for gas
Posted: Wed Jan 06, 2021 9:00 pm Post subject: Re: solo clutch bleed |
GoEverywhere wrote: |
I second this technique, I've used it many times before. _________________ Imagine that, theres not an "h" in either Westfalia or Syncro? |
CanStan Samba Member
Joined: October 16, 2005 Posts: 1037 Location: Calgary, AB
Posted: Thu Jan 07, 2021 9:45 am Post subject: Re: solo clutch bleed |
I picked up a similar $15 Amazon special a few weeks ago. I really wasn't expecting much for the money, but I was sick or borrowing a professional unit from a buddy every time I needed it.
I have to say, I was pleasantly surprised. The quality was good for the price. It's easy to use, and small enough to store out of the way. I didn't need another garage item in my way that only gets used once a year. I suppose the only downfall is you have to have a compressor, but even the smallest compressor will work just fine. |
Posted: Thu Jan 07, 2021 3:05 pm Post subject: Re: solo clutch bleed |
i use a wide mouth quart mason jar as i like the clear glass to look at what is coming out and being able to suck a fair bit of fluid out. used Mason lids with 2 nipples JB Welded thru. i've put full, low micron vacuum on mason jars and while not approved/suggested/safe/sane/sanctified, it's never had an issue. certainly not in the MityVac range.
i've got the O-fficial MityVac plastic jar too but it is translucent only, not clear. handy devices to have around, i use mine quite frequently. _________________ -dan
fxr Samba Member
Joined: December 07, 2014 Posts: 2322 Location: Bay area CA
Posted: Thu Jan 07, 2021 4:11 pm Post subject: Re: solo clutch bleed |
MarkWard wrote: |
Awesome! Makes perfect sense, especially if you can fill that hose with fluid before final attachment. _________________ Jim Crowther
Vespa GTS 300 |
Sodo Samba Member
Joined: July 06, 2007 Posts: 9605 Location: Western WA
Posted: Thu Jan 07, 2021 7:12 pm Post subject: Re: solo clutch bleed |
buspor63 wrote: |
I second this technique, I've used it many times before. |
I third this technique
There's another thread called: One man clutch bleed? _________________
....KTMs, GasGas, SPOT mtb |
