plforsyth Samba Member
Posted: Sat Jan 09, 2021 5:16 pm Post subject: Airbag light |
Hi all,
My airbag light is on all the time. My independent euro shop put the computer on it to reset and it keeps coming back. He said there was a lot of resistance across the circuit. Is this a bad airbag or clockspring problem? Please help trying to get this fixed! |
vwuguy Samba Member
Joined: November 01, 2005 Posts: 1053 Location: southwestern ontario, on and netherlands and bc
Posted: Sun Jan 10, 2021 5:25 pm Post subject: Re: Airbag light |
put tape on the dash problm solved _________________
Posted: Sat Apr 03, 2021 12:12 pm Post subject: Re: Airbag light |
Still searching for clues concerning Airbag light always on? I have had it to the shop and there is no problem with the airbag. The horn works, and all the other accessories on steering column. Just came back from a trip and cruise control worked fine. I have a new clock sensor without the ESP so I’m hesitant to replace the stock one and lose the ESP function. I even pulled apart the console under the radio to see if the heater core leaked on the airbag harness. It was all dry. Any clues would be much appreciated? What am I missing? |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22639 Location: NYC/Upstate/ROW
Posted: Sat Apr 03, 2021 1:25 pm Post subject: Re: Airbag light |
If your indie isn’t using a shop scanner to read the airbag controller codes to pinpoint th eproblem, you need a new shop to look at , so equipped _________________ .ssS! |
Posted: Sat Apr 03, 2021 4:19 pm Post subject: Re: Airbag light |
Thanks for your reply Abscate,
My Indie does have the scanner, however his wire or connector was crapping out on him. He was able to determine that the airbag was okay. Here in Chicagoland I have not found a mechanic that understands these vans! If anyone on the forum knows a good Eurovan mechanic in the Oak Park Illinois area, please speak up. They all seem to be on the East or West Coast or Denver area. I’m going to call my mechanic to see if he gotten a new cable so he can get a clear reading or I’ll just keep searching for another tech. I’ve not had good experiences with the VW dealers around here. |
Posted: Sun Apr 04, 2021 8:22 am Post subject: Re: Airbag light |
The airbasgs rarely , if ever fault, on any SRS system. It’s wiring , connectors , or disconnect protocol that trigger srs system lights 99.93% of the time
Often it’s when someone takes a seat out of a car, then finds out they need to reinstall it with the battery disconnected but key in a certain position to wake up the SRS controller correctly. _________________ .ssS! |
Posted: Sun Apr 04, 2021 8:47 am Post subject: Re: Airbag light |
Hi Abscante,
Again thanks for your reply. I thought as much concerning the airbag. Will keep up the hunt. The van runs like a top but I want to get to the bottom of this!
Cheers,
Paul F. |
Posted: Sun Apr 04, 2021 8:55 am Post subject: Re: Airbag light |
A decent scanner in the AUTEL series will run about $150, which is pretty cheap compared to one hour of paid labor and commute time to the mechanic to get codes read. It’s a bit of a bitter pill for a one car family but when you run an airline like me it pays off several times a year.
My girls all have cheap OBd scanners and all know to report check engine lights with a code report. _________________ .ssS! |
Posted: Sun Apr 04, 2021 1:37 pm Post subject: Re: Airbag light |
Hi Abscate,
Can you give me a model number for the AUTEL that would do the trick? I looked and there are many to choose from.
Thanks,
Paul F |
Posted: Sun Apr 04, 2021 5:14 pm Post subject: Re: Airbag light |
Mine is about 10 years old now so I’ll have to find the new model corresponding , give me a few _________________ .ssS! |
Posted: Thu Apr 08, 2021 2:52 pm Post subject: Re: Airbag light |
Hi Abscate,
Just wondering if you got the model number off your AUTEL scanner? Even though it’s ten years old, if I search on Amazon it will give me the updated model. Let me know as I’m anxious to solve this riddle!
Thanks,
Paul F |
almond Samba Member
Posted: Thu Apr 08, 2021 4:03 pm Post subject: Re: Airbag light |
Just FYI - when the airbag light is on the airbags won't go off in an accident. |
Posted: Thu Apr 08, 2021 5:29 pm Post subject: Re: Airbag light |
Nuts, thanks for the info! |
Posted: Thu Apr 08, 2021 5:43 pm Post subject: Re: Airbag light |
almond wrote: |
Is that a known for VAG products or speculative? I know at least one other brand that some SRS codes don’t inhibit air bag firing.
Unless the source code is public, which I doubt it is, the function of the SRS system under failure is known only by VW _________________ .ssS! |
almond Samba Member
Posted: Thu Apr 08, 2021 9:13 pm Post subject: Re: Airbag light |
Uhh ... speculative ... but the general case in the auto industry. How could a system thats detected a failure it cannot report accurately to a technician know when its appropriate to fire the explosives into human beings' faces and bodies? Who insures that airbag and car company?
What brand and which SRS codes, that you've seen, allow firing them under failure modes? How does the system know its in a fail safe state such that it can reason about firing under the correct conditions with partial component functionality?
[/quote] |
Posted: Fri Apr 09, 2021 2:25 am Post subject: Re: Airbag light |
There are many sensors in an SRS system , like seat belt latch sensors, seat weight sensors. I bet several of the codes do not inhibit bag firing , but without source code , that is speculative as well.
Obviously, if you think safety is important, an SRS code means “ get it fixed” and assume you DONT haVe an Air bag, _________________ .ssS! |
pinetreeporsche Samba Member
Joined: June 11, 2009 Posts: 752 Location: Falls Church, VA
MrPulldown Samba Member
Joined: September 08, 2020 Posts: 649 Location: Truckee
Posted: Tue Apr 27, 2021 10:50 am Post subject: Re: Airbag light |
You posted a link to your profile page. I am curious to see the thread you referenced. Can you please post link again. _________________ 2002 EVC |
Thoragaverung Samba Member
Joined: September 15, 2018 Posts: 81 Location: Saint Paul
Posted: Fri May 07, 2021 10:57 am Post subject: Re: Airbag light |
Every time I rehab an old car with a bad SRS/airbag I usually find, in order of frequency:
Bad clockspring
Bad seat belt buckle switch thingy
Wet or corroded airbag CPU/brain
I've fixed like 6 over the years. I figure, if you are relying on a 20 year old air bag to save you, you're probably SOL, but on the other hand you might as well load the dice in your own favor if you can. _________________ Happy to help, but my advice comes with no guarantees. Use at own risk. |
