Pepperbilly Samba Member
Joined: April 08, 2017 Posts: 977 Location: Seattle, Wa
Posted: Sun Jan 10, 2021 11:12 am Post subject: Gas tank anxiety |
Been trying to clean out my gas tank. So far I have used the pea gravel approach. To the point where after several rounds of gravel tumble and water flushing the rinse water runs clear. I don’t see any evidence of pinholes. Looking inside the tank there (especially on the lower half) there is still a brown crust with small areas of shiny metal exposed. I feel like I should treat further with muriatic acid BUT I am anxious about this. The acid step is aggressive and I don’t want eat holes. I feel I should just proceed with the OSPHO rinse and be done with it. I don’t think I am a fan of any tank inner coatings either. Before I make a mistake I am looking for advice now. You can’t replace these tanks.
Bill |
Hawker Samba Member
Posted: Sun Jan 10, 2021 2:51 pm Post subject: Re: Gas tank anxiety |
Greetings,
My advice would be to rinse the tank around with vinegar/acetic acid or correctly named Ethanoic acid.
This will dissolve any iron oxides that remain in the tank and will leave you with a clean and shiny tank. It will not attack the metal of the tank itself unlike stronger acids.
BR,
Rob |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21513 Location: Oklahoma City
Posted: Sun Jan 10, 2021 5:18 pm Post subject: Re: Gas tank anxiety |
STOP!
The sloshing around of gravel and things like chains...will work to loosen up crusty rust but it also "scratches" the surface of the steel. This creates stress lines that are more prone to rusting at the scratch.
Ok...a few things.....
Most commonly available CLEANING acids ...will not actually "hurt" steel...structurally. They can cause hydrogen embrittlement at the surface of the steel but since the gas tank is not a high carbon, high performance ...surface hardened steel....we dont care.
Exceptions are:
Nitric acid which reacts with the iron in the steel to produce iron nitrate. Nitric will dissolve steel.
Sulfuric acid can be used for surface pickling but it also is an oxidizing acid.
The two BEST acids for cleaning the gas tank are Muriatic/Hydrochloric acid and/or phosphoric acid.
The best gas tank cleaning method I have found:
NOTE: this assumes your tank is structurally sound...no pin holes or rust throughs.... and can be sealed up. Even if you need to weld it...clean it like this first.
This also assumes you o not have tar or varnish in the tank. Its worth having it boiled out to get rid of that if you cannot use something like solvent or MEK.
Buy a cheap 23 gallon or larger plastic laundry tub. Biggest one you can find. Buy 2-3 five pound boxes of cheap baking soda at walmart.
!!!!!!! Use goggles, gloves and a respirator with an OVP100 acid/VOC cartridge
This first method assumes you have large flakes of crusty rust.
1. Muriatic acid is ideal for removing the crusty thick rust. It literally dissolves rust down to the bare metal. It WILL remove all rust.
Plug up all of the holes with duct tape. Pour about 1 quart of acid in and slosh it around. Take your time. Let it soak for a while at all angles. Keep it over the tub so any leakage goes in the tub.
Pour the acid out into a container and repeat. DO NOT ADD WATER TO THE ACID!
2. When you are ready to neutralize the spent acid....fill the tub with about 15 gallons of water. Pour the acid into that slowly. Neutralize it with a mixture of baking soda and water mixed into a bucket. Keep adding slowly until it quits fizzing. Then dilute with more water. This can now go down the drain.
You will notice...when looking through the fuel sender hole...that after its very clean...it almost instantly flash rusts on the surface. THIS IS WHAT WE WANT!
3. Get any standard phosphoric acid product like Ospho....that does not have to be diluted. Pour about 16 oz in the tank and slosh around and then let it sit for a while. Make suer every surface is coated.
Pour it out in a container and repeat with fresh Ospho. Once its all coated and wet..... DO NOT RINSE IT.
Let it stand and dry with all ports uncovered for 24 hours.
The phosphoric acid will convert the surface flash rust ...into an inert layer of iron phosphate...that WILL NOT RUST...again once the tank is filled with fuel. There is no need for a sealer.
If its going to be a while until you use the tank....put some WD-40 into the tank to slosh it around and coat every surface. This tank can be put on the shelf and not likely to rust in your lifetime.
Alternately.......
If you do not like or want to deal with Muriatic/hydrochloric acid.....look around for a Phosphoric acid product that NEEDS to be diluted. My favorite used to be Jasco metal prep and prime...but they quit making it.
In its undiluted state....it will dissolve rust just like muriatic acid but is a bit slower...les violent and is not an oxidizing acid.
But.....once you use strong phosphoric acid to dissolve the rust....you need to rinse it well with water...but do not neutralize it. It will then take a day or so to flash rust.
Then....use properly diluted phosphoric acid/oshpo ...to convert the surface to the black iron phosphate for rust protection.
There is a little about this process here:
https://www.thesamba.com/vw/forum/viewtopic.php?t=645335&highlight
Ray |
Posted: Sun Jan 10, 2021 6:06 pm Post subject: Re: Gas tank anxiety |
Ray,
Well, I am done with pea gravel part anyway. Just wondering... if someone wanted to use a sealer could you not prepare the OUTSIDE of the tank and apply a coating say like MasterSeries? Do the reverse I guess.
Bill |
Posted: Sun Jan 10, 2021 6:49 pm Post subject: Re: Gas tank anxiety |
Pepperbilly wrote: |
Ray,
Bill |
Rust...contains its own "fuel"....oxygen. Master series...as fabulous as it is...has the same issue as phosphoric acid surface conversion. It can only soak into a surface that is so deep.
This is why Master series also tells you that for crusty rust...bead blasting, grinding, sanding or sand blasting is ideal. You need to remove it or get it down to just a handful of thousandths thick. While it can and will seal up rust so that no oxygen is available from the outside....this is only great for something solid.
The gas tank is a different deal. You need to remove ...or reduce and neutralize the rust. Once you do that inside....you need no sealer inside.
On the outside....sure...master series would be killer! Ray |
Posted: Thu Jan 14, 2021 12:52 pm Post subject: Re: Gas tank anxiety |
Ray,
I am finished with the first step doing two flushes with muriatic acid. I stopped there... no OSPHO yet. What I am seeng is a very clean and rust free upper tank, the exposed metal looks in fine condition. The bottom say 1/4 of the tank has a brownish crud layer still. Does not look like rust. Where clean metal is exposed thru this layer the metal is pristine. It looks like a layer left behind by the old gas that was still remaining in this 1/4 tank area. Now, where to go from here? The tank has no pin holes or rust thrus.
Bill |
Posted: Thu Jan 14, 2021 8:21 pm Post subject: Re: Gas tank anxiety |
Ray,
Bill |
In the bottom...the brownish crud layer is "usually" a mixture of fuel varnish and some rust and even grit...lead and additives.
Be careful because that reddish brown silt and staining usually contains tons of TEL (tetraethyl lead).
What I used to clean that out of mine....are these...3M roloc abrasive discs
https://www.3m.com/3M/en_US/company-us/all-3m-prod...amp;rt=rud
You clamp them onto this
https://www.empireabrasives.com/2-roloc-roll-on-di...pmEALw_wcB
And I added a rod about 2 feet long to use on a drill.
Then add a stripper....like sodium hydroxide....a caustic as this point....to eat the varnish.
You could use heavy duty drain opener...and maybe just a little paint thinner. Then reach this through the sending unit hole and power this stuff.
You can buy cheap versions of these pads at Harbor freight. You can buy the good ones and the holder at NAPA and Grainger.
Ray |
Posted: Fri Jan 15, 2021 11:44 am Post subject: Re: Gas tank anxiety |
Before I try any more abrasive methods it has been suggested to try diesel. Had some extra diesel so what the heck, i’ll give it a try. Will let you know how that came out.
Bill |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34003 Location: Conejo Valley, CA
Posted: Fri Jan 15, 2021 11:58 am Post subject: Re: Gas tank anxiety |
Bill |
Its not abrasive I am suggesting. The green 3M roloc pads are effectively scotch brite. You need at least a light abrasive to get through the varnish.
You could simply use a scrubber pad and sand...but the key is scrubbing with a solvent to dissolve the varnish. Diesel may work for some but is not ideal....in my experience.
Ray |
Posted: Sat Jan 16, 2021 6:54 pm Post subject: Re: Gas tank anxiety |
Hey everyone,
Wanted to let you know how the diesel worked. I love it when a project moves forward! I soaked the tank overnite with diesel. When I emptied the diesel some brown sediment came with it... not much though. The tank was still not as clean as I wanted. I flushed further with some acetone two times. Still not what I wanted. Decided I needed the two muriatic acid steps again. After the muriatic soaks I had complete success! The tank looks brand new inside... no brown stuff anywhere. I proceeded with the OSPHO rinse and I am a happy camper. Will coat the inside with some ATF fluid since it will not be holding any gas for a while.
Bill |
Posted: Sat Jan 16, 2021 7:40 pm Post subject: Re: Gas tank anxiety |
Hey everyone,
Bill |
Cool!....so the diesel removed enough varnish to let the acid get to the actual rust.
Glad it was that simple and no further scrubbing necessary!
ATF is a good thing for this. Pour in a pint, slosh around to fully coat and drain very well. Ray |
Posted: Wed Mar 03, 2021 12:41 pm Post subject: Re: Gas tank anxiety |
I went ahead and prepared my tank for painting. Used MasterSeries silver. Tank was in nice shape with no holes. I think I’m just gonna leave it in MasterSeries silver and not finish paint it in black. Once it’s in the car you don’t see it. It came out nice!
Bill
Posted: Wed Mar 03, 2021 3:42 pm Post subject: Re: Gas tank anxiety |
Man...I just love that paint. Its not cheap...but worth every penny. That stuff is tough as nails and very good chemistry.
By the way...there is another product I highly recommend. Its not a rust killer like Master series silver....but it is a protective coating for painting CLEAN parts. Its like ceramic when its dry.
If you have ever looked inside of an old steam engine or oil field pump jack or pump jack engine gearbox from way back when...and even now days....you see that the inside of the cast iron gearboxes and cases are painted with an absolutely bulletproof enamel coating that lasts for decades. Oils and solvents wont touch it.
It is especially used in engine castings that have been bead, shot or sand blasted. It fills and seals the pores....encapsulates any debris that is also left and makes oil flow off smoother. Its good to about 385* F constant.
Its usually red....sometimes comes in green. I am looking for some in black. Its called "Glyptal paint". It is an alkyd enamel.
Eastwood carries it or you can buy it from the manufacturer.
https://www.eastwood.com/glyptal-red-brush-on-1-qt.html
It is not cheap...but it is killer. The red is Glyptal 1201.
The black is Glyptal 1209. They say its "similar" to 1201. I hope to find out how similar or different.
https://www.electro-wind.com/glyptal-1209-black-en...n-can.html
Wait...here is the main site.
http://www.glyptal.com/glyptal_products.html
I will have to look at the whole line.
Ray |
