matthew henricks Samba Member
Joined: January 02, 2002 Posts: 1219 Location: So. Cal
Posted: Wed Jan 13, 2021 10:55 pm Post subject: 62-67 Gas Tanks. Lets talk details |
Years ago i replaced the tank on my 64 with an aftermarket one. Small "Kombi" cap. (I know....) I want to put back a large filler neck version but are they really all the same?
- Fit. Pretty sure they are all the same
- Filler neck. Pretty sure the same
- Bottom stamping. Did this change?
- top stamping. Did this change?
- Vent exit location. Pretty sure all the same.
I ask because in searching i have seen two different top stampings. One with equal pressed in ribs across the top and one with the left side stamping different.
What would a 64 European Delivery have had?
Images lifted from For sale adds. Happy to remove if asked. |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11056 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Thu Jan 14, 2021 10:39 am Post subject: Re: 62-67 Gas Tanks. Lets talk details |
IMO. the top is original the bottom is a replacement.
The one with the right rear corner at an angle is simply the later tank top (for right quarter panel filler location) with the older tank neck.
I remember at one time these were the replacement tanks once the original supply was exhausted.
Keep in mind that top tank style was in production through 1967 model years. Once the 68s were produced, VW had no need to keep pressing the old style. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
Posted: Fri Jan 15, 2021 9:32 pm Post subject: Re: 62-67 Gas Tanks. Lets talk details |
Did some more research and Volkswagnut is correct. The top one is original an the bottom a factory replacement. FWIW the tank that WW sells is the factory replacement.
Thank you. Off to find a new tank. |
rcooled Samba Member
Joined: September 20, 2008 Posts: 2508 Location: Santa Cruz, CA
Posted: Sat Jan 16, 2021 7:02 pm Post subject: Re: 62-67 Gas Tanks. Lets talk details |
matthew henricks wrote: |
Wolfsburg West sells a very nice repro tank...check it out:
https://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111201621C
I have one in my '63. Looks good, fits well, and uses the OEM cap too. _________________ '63 Ragtop (current)
'65 Ghia coupe (totaled)
'69.5 Ghia convertible and
'62, '63, '65, '69 Bugs (all long gone) |
