balljoint Samba Member
Posted: Thu Jan 14, 2021 10:19 am Post subject: On today's transmission adventures...... |
After being 90% sure it's not a shift plate, rod etc adj issue as it actually grinds going into 2nd and is not trying to go into reverse, I had a look through the filler hole and can make the 2nd gear synchro basically kiss 2nd gear when pushing it with a pick.
Now I know I'm only pushing one side and it's not 100% accurate to get a measurement as per bentley spec, but I think this way still shouldn't allow one side to kiss with everything being totally assembled and all.
Also you can see the synchro just remain up against the gear even with no pressure applied.
https://youtu.be/PtfosjUM1uI
So now Im thinking I need to get in this box but of course need you guys opinion first! _________________ It's an ongoing journey, never forget where you came from....
65 rhd Beetle
72 rhd kombi |
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4856 Location: sanger ca
Posted: Thu Jan 14, 2021 12:31 pm Post subject: Re: On today's transmission adventures...... |
Yes, that synchro is wasted _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
Posted: Fri Jan 15, 2021 5:13 pm Post subject: Re: On today's transmission adventures...... |
Fun times ahead!
Got to fab up a press to remove the main shaft and if I need to get anything else off as well after further inspection.
Will 10 ton be ok? _________________ It's an ongoing journey, never forget where you came from....
65 rhd Beetle
72 rhd kombi |
Posted: Fri Jan 15, 2021 6:19 pm Post subject: Re: On today's transmission adventures...... |
yes you need a decent press, also a fixture or cut case to set the forks _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
Posted: Wed Jan 20, 2021 10:04 am Post subject: Re: On today's transmission adventures...... |
So luckily I was able to get my hands on an early 6V case with the 4 bolt pinion retainer and 2 drain plugs.
My case is an AO 12V with 4 bolt pinion retainer and 2 drain plugs.
Will I be able to cut this 6V case and use it as a jig to set up the forks? Are the clearances/bolt up etc for the gear set the same between the two?
6V case
65 rhd Beetle
72 rhd kombi |
Posted: Wed Jan 20, 2021 10:27 am Post subject: Re: On today's transmission adventures...... |
balljoint wrote: |
6V case
Yes, that will work _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
Posted: Wed Jan 20, 2021 10:46 am Post subject: Re: On today's transmission adventures...... |
Great! Really slim pickings for these things where I am.
Thanks again man. _________________ It's an ongoing journey, never forget where you came from....
65 rhd Beetle
72 rhd kombi |
Posted: Tue Mar 16, 2021 7:21 pm Post subject: Re: On today's transmission adventures...... |
So finally got things rolling.
2nd synchro confirmed shot...measured up to 0.33mm.
Now I'm dealing with a non US swing axle tranny here and I'm guessing 68-69ish so I'm back and forth between 2 bentley manuals.
I noticed they state a larger synchro clearance up to 1.9mm in the 70-79 book and only up to 1.0mm in the older 66-69 book. Is it because of the different design of synchro?
Wear limit however is the same.
What also jumped out at me is the placement of this dished washer. I found it on the pinion shaft as pictured but to me it doesn't do squat there.
The old bentley doesn't have it pictured on either shaft but the newer bentley has a dished washer between the circlip and 4th gear thrust washer on the main shaft.....so I guess the guys who were in there put it on the wrong shaft?
Any tips on measuring up synchros? It's hard to get a proper reading with that side to side rock!
1-4, L-R _________________ It's an ongoing journey, never forget where you came from....
65 rhd Beetle
72 rhd kombi |
67 Sunroof Samba Member
Joined: February 22, 2014 Posts: 1836 Location: Salisbury, MD
Posted: Tue Mar 16, 2021 7:30 pm Post subject: Re: On today's transmission adventures...... |
What is the synchro and why is it shot? (Is it in the picture)
Newb questions!!! _________________ 1776cc, CB crank, CB 2241 cam, CB light lifters, CB H-beam rods, CB light flywheel, Mahle forged pistons, A1 Sidewinder exhaust, Dellorto drla 40’s, Hoover modded case, fully balanced, fully flowed, heads by www.type-emotorsports.com, Air ride suspension by https://www.airkewld.com/?Click=3989 |
GARRICK.CLARK Samba Member
Joined: June 30, 2012 Posts: 1267 Location: Lancashire UK
Posted: Wed Mar 17, 2021 3:29 am Post subject: Re: On today's transmission adventures...... |
Take a look at the corrosion where the side plate gaskets go. Use a good sealant |
Ohio Tom Samba Member
Joined: February 09, 2006 Posts: 1660 Location: Marshallville Ohio
Posted: Wed Mar 17, 2021 6:49 am Post subject: Re: On today's transmission adventures...... |
Yeah, that washer doesn't belong there. |
Posted: Wed Mar 17, 2021 9:24 am Post subject: Re: On today's transmission adventures...... |
New pinion bearing, 2 113 311 269b synchros, 2 113311295d synchros, mainshaft bearing, check/change 3-4 slider, 3rd hub on 4th and 4th hub modified and on 3rd. _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
Posted: Wed Mar 17, 2021 12:29 pm Post subject: Re: On today's transmission adventures...... |
No problem using the later 120* synchros on these early gears? _________________ It's an ongoing journey, never forget where you came from....
65 rhd Beetle
72 rhd kombi |
Posted: Wed Mar 17, 2021 1:44 pm Post subject: Re: On today's transmission adventures...... |
The 1-2 gears in your pic appear late _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
Posted: Wed Mar 17, 2021 3:07 pm Post subject: Re: On today's transmission adventures...... |
From the 66-69 bentley the 1st and 2nd synchro described is exactly like mine.
1st has a narrow shift plate groove and 3 oil grooves between them.
2nd has wider shift plate groove and 2 oil grooves between them.
Both have same inner diameter and can be exchanged so the manual says don't mix them up
Weddle has the following which long enterprises recommend for 1st AND 2nd for late (66-6 swing axle, and I was going for this.
Can the later 113 311 269B you recommend be used instead of the 113 311 269A? _________________ It's an ongoing journey, never forget where you came from....
65 rhd Beetle
72 rhd kombi |
Posted: Wed Mar 17, 2021 3:21 pm Post subject: Re: On today's transmission adventures...... |
269a is a first gear synchro, 269b is a second synchro that will replace the 269a. Most builders, myself included, use 269b for first and second gear so as to not have to stock exess invatory. What you need is what I posted. _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
Posted: Wed Mar 17, 2021 3:52 pm Post subject: Re: On today's transmission adventures...... |
Great!
As for 3rd hub on 4th and 4th hub modified and on 3rd,
I guess would be for use of the better condition dogs on 4th in 3rd position right?
3rd has space to press off but how the hell do you get off 4th?
And how do you modify 4th hub? _________________ It's an ongoing journey, never forget where you came from....
65 rhd Beetle
72 rhd kombi |
Posted: Wed Mar 17, 2021 6:42 pm Post subject: Re: On today's transmission adventures...... |
balljoint wrote: |
Great!
And how do you modify 4th hub? |
They press off exactly the same.
If you look at the engagement teeth on 4th hub you will see 3 sets of 3 teeth that are worn(if it is a 70-72 set 3 sets of 5 teeth) these teeth get removed. The hub on 3rd will most likely not be worn(I cant see it from here) _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
Posted: Thu Mar 18, 2021 2:38 pm Post subject: Re: On today's transmission adventures...... |
Actually both my 3rd and 4th has some wear on the drive side of the flanks
3rd also has some minor pitting here and there as can be seen.
What do you suggest?
Pressing off that 4th on those edges got me anxious already! _________________ It's an ongoing journey, never forget where you came from....
65 rhd Beetle
72 rhd kombi |
Posted: Thu Mar 18, 2021 2:49 pm Post subject: Re: On today's transmission adventures...... |
3-4 slider is new...well just about 80miles on it.
The hub has no id marks on it, the slider has a line and a notch as can be seen to the right of the orange mark.
What direction does each face.? Need to make sure, as clearly the guys who were in there wasn't too sure of what they were doing. _________________ It's an ongoing journey, never forget where you came from....
65 rhd Beetle
72 rhd kombi |
