Generator stand gasket
fast86gn
fast86gn is offline
PostPosted: Thu Jan 14, 2021 3:33 pm    Post subject: Generator stand gasket Reply with quote
I forgot to order a gasket for the generator stand. Can I use a thin layer of rtv sealant or should I wait and order the gasket? Thanks
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Thu Jan 14, 2021 3:35 pm    Post subject: Re: Generator stand gasket Reply with quote
Don't use silicone, if it get in the oil it can block a oil passage and cause engine failure.
Glenn
Cast Iron and Aluminum distributors rebuilt since 2000.
fast86gn
fast86gn is offline
PostPosted: Thu Jan 14, 2021 3:36 pm    Post subject: Re: Generator stand gasket Reply with quote
Thank you
jsturtlebuggy
jsturtlebuggy is offline
PostPosted: Thu Jan 14, 2021 3:59 pm    Post subject: Re: Generator stand gasket Reply with quote
Are you using the metal baffle between stand and case?
If so, you don’t use any gaskets, just some sealant, not silicone.
Joseph
Fair Oaks/Orangevale, CA
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960
Mr. 010
Glenn is offline
PostPosted: Thu Jan 14, 2021 4:37 pm    Post subject: Re: Generator stand gasket Reply with quote
Sorry but you still use a paper gasket above and below the metal baffle.
Glenn
jsturtlebuggy
PostPosted: Thu Jan 14, 2021 7:09 pm    Post subject: Re: Generator stand gasket Reply with quote
Don’t be sorry , you are just looking at old picture. The metal baffle changed from a flat to a raised ridge around the outside and that is used as the seal.
It the same idea with stock dual port intake gaskets.
VW did this change as the paper gaskets break over time from normal engine vibrations.
I have been building VW engine since around 1973 and remember seeing the factory bulletin when this change happened.
Joseph
Elrod Motorsports
Mr. 010
Glenn is offline
PostPosted: Thu Jan 14, 2021 7:35 pm    Post subject: Re: Generator stand gasket Reply with quote
Then why are the gaskets till included?
Glenn
jsturtlebuggy
PostPosted: Thu Jan 14, 2021 8:50 pm    Post subject: Re: Generator stand gasket Reply with quote
Gasket kits have included many items not always used on later engines. For many years there was seals included for the long rocker studs used only early 40hp and 1500cc heads long after they stop being used.
I would bet if your friend Russ (RIP) was still alive and told you the same thing you would believe him.
Do you still use the paper gaskets for the cylinders base? There in the kits too.
Joseph
Elrod Motorsports
Mr. 010
Glenn is offline
PostPosted: Fri Jan 15, 2021 6:59 am    Post subject: Re: Generator stand gasket Reply with quote
I build an engine or two a year and never had a leak from there so i'll continue to do what works... for me.
Glenn
vwracerdave
vwracerdave is offline
PostPosted: Fri Jan 15, 2021 7:59 am    Post subject: Re: Generator stand gasket Reply with quote
Yes you can use RTV. Different people have different opinions.
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos
jsturtlebuggy
PostPosted: Fri Jan 15, 2021 10:02 am    Post subject: Re: Generator stand gasket Reply with quote
You do what you want Glenn, from my experience of building many engines that at the time period being used as daily drivers you did every thing you could to stop oil leaks. After you seen so many generator stands leaking from broken gaskets, when the new improved baffle plate came out you stopped worrying about having and oil leak start there.
And if look you may find others out there that agree with me and remember why the new improved baffle came with the sealing ridge around the edge just like stock dual port intake gaskets.
Joseph
Elrod Motorsports
Mr. 010
Glenn is offline
PostPosted: Fri Jan 15, 2021 10:04 am    Post subject: Re: Generator stand gasket Reply with quote
My engines don't leak.. .and I sleep well at night.
Whatever works for you.
Glenn
oprn
oprn is offline
PostPosted: Fri Jan 15, 2021 3:26 pm    Post subject: Re: Generator stand gasket Reply with quote
Actually for the first time in several engine builds I did use the paper gaskets that go between the cylinders and the case. I needed .003" to make a .040" deck height so on they went!
I never finish anything, I have a black belt in partial arts!
Mr. 010
Glenn is offline
PostPosted: Fri Jan 15, 2021 3:41 pm    Post subject: Re: Generator stand gasket Reply with quote
Many feel that paper intake gaskets are better at sealing than the OE metal one on stock engines.
Glenn
jsturtlebuggy
PostPosted: Fri Jan 15, 2021 4:57 pm    Post subject: Re: Generator stand gasket Reply with quote
I can say the same thing about the metal gaskets that many like to use them.
It is really hard to outsmart VW engineers and what they came up with to use.
Joseph
Elrod Motorsports
MrGoodtunes
MrGoodtunes is offline
PostPosted: Fri Jan 15, 2021 8:11 pm    Post subject: Re: Generator stand gasket Reply with quote
Install'd a new alternator stand just today. Used the metal gasket with ridge, sandwitch'd between paper gaskets. Not worried about oil leaks, but how will I ever know firing order!!
EVfun
EVfun is offline
PostPosted: Fri Jan 15, 2021 11:24 pm    Post subject: Re: Generator stand gasket Reply with quote
You could stamp 4 3 2 1 on it. Think
Wildthings wrote:
jsturtlebuggy
PostPosted: Sun Jan 17, 2021 2:20 am    Post subject: Re: Generator stand gasket Reply with quote
Mr Goodtunes, with using a H5 engine you have more chances of oil leaking from cracks in case other then worry of your generator/alternator stand.
Air cooled.net, JBugs,and Kustom1 Warehouse in there online catalogs all say you do not need gaskets with oil baffle/defector that has the raised edge, just good sealant
Joseph
Elrod Motorsports
clonebug
clonebug is offline
PostPosted: Mon Jan 18, 2021 9:53 pm    Post subject: Re: Generator stand gasket Reply with quote
The Mexican Alt stand has an o-ring seal on the bottom....it's a nice upgrade and quite reasonable since most originals have fillers that are rusted out.
vwracerdave wrote:
Take a good long look in the mirror and report back on what you see.
Paul.H wrote:
That one line on that chart is probably better info than you can get from this place in a month
(Now with Water/Alcohol Injection)
Upgraded to MS-2 Extra direct fire wasted spark
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936
SBD
SBD is offline
PostPosted: Thu Jan 21, 2021 9:54 pm    Post subject: Re: Generator stand gasket Reply with quote
Ask Zundfolge. Very Happy
"Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
mark tucker wrote:
I wouldent waste $ or thyme on building a small motor. build it big so it dosent have to work hard.remember it's only as fast as your foot alows it to be unless you build a small turd then it just stinks as it squishes up through your toes when you step on it.
