dave1 Samba Member
Joined: September 12, 2003 Posts: 376 Location: United Kingdom, London
Posted: Fri Jan 15, 2021 9:35 am Post subject: Correct coil for 52 split beetle |
Hi guys,
What is the correct coil for a 52 split deluxe beetle
Thanks |
johnshenry  Samba Member
Joined: September 21, 2001 Posts: 9242 Location: Dunstable, MA USA
Posted: Fri Jan 15, 2021 3:04 pm Post subject: Re: Correct coil for 52 split beetle |
Jan '52 manual shows the skinny star coil.
Shows the smooth top one for the Oct '52 Zwitter manual. _________________ John Henry
'57 Deluxe
'56 Single Cab |
dave1 Samba Member
Posted: Fri Jan 15, 2021 4:22 pm Post subject: Re: Correct coil for 52 split beetle |
Hi,
Thanks for details does the coil have an identification number
Thanks |
EverettB  Administrator
Joined: April 11, 2000 Posts: 64962 Location: Phoenix, AZ
splitjunkie Samba Member
Posted: Fri Jan 15, 2021 10:10 pm Post subject: Re: Correct coil for 52 split beetle |
johnshenry wrote: |
Shows the smooth top one for the Oct '52 Zwitter manual. |
Unfortunately they reused older pictures for the owners manuals unless there a good enough reason to take new pictures.
That same picture is used in the Sep 1951 manual so it is meaningless as a data point for what would be used on a Jan 1952 car. The same picture may have been used even earlier but I haven't checked.
This picture is from a Sep 1952 road and track and shows a split dash '52 that clearly shows a non star coil. The picture would have been taken at least several months earlier due to lead times to produce publications back then. This car was owned by Competition Motors, North Hollywood, CA. In the article it is stated that the car had 6000 miles on the clock.
It could have been replaced but given when it was taken, if it was replaced then VW was already supplying non star coils as spare parts probably middle of '52.
The OP also didn't specify what month '52. Zwitters definitely wouldn't have star coils but it appears based on the picture above that the switch was made at some point during pre zwitter '52 production _________________ Chris
virtanen Samba Member
Joined: January 08, 2006 Posts: 1359 Location: Finland
Doktor Brezel Samba Member
Posted: Sat Jan 16, 2021 12:00 pm Post subject: Re: Correct coil for 52 split beetle |
Where can I find the date stamp on a star coil? I have a star coil, but can't find the date. _________________ Jan '51 Split // 11C // Medium Brown |
Posted: Sat Jan 16, 2021 12:09 pm Post subject: Re: Correct coil for 52 split beetle |
Doktor Brezel wrote: |
Where can I find the date stamp on a star coil? I have a star coil, but can't find the date. |
Its on the mounting bracket on one side, near the hole. Sometimes you have look hard for and scrape or media blast a bit. _________________ John Henry
'57 Deluxe
'56 Single Cab |
Posted: Sat Jan 16, 2021 12:47 pm Post subject: Re: Correct coil for 52 split beetle |
johnshenry wrote: |
Its on the mounting bracket on one side, near the hole. Sometimes you have look hard for and scrape or media blast a bit. |
Thanks for the quick reply. I found a hexagon with 73 inside. That's not the date code is it?
btw Sorry for hijacking the thread.
Posted: Sat Jan 16, 2021 1:16 pm Post subject: Re: Correct coil for 52 split beetle |
No, will be a number and a letter like this:
7F is July 1950 _________________ John Henry
'57 Deluxe
'56 Single Cab |
Posted: Sat Jan 16, 2021 1:39 pm Post subject: Re: Correct coil for 52 split beetle |
Found it. It looked like a rust spot, but after sanding it down it started to look more like a date code. It's clear that mine is also from 1950 (F), but the month could be either 3 or 5. Thank you very much for your help! _________________ Jan '51 Split // 11C // Medium Brown |
