barfsurfer Samba Member
Joined: August 05, 2019 Posts: 50 Location: Santa Ana, California
Posted: Sat Jan 16, 2021 6:57 pm Post subject: TIL: Don't park bus on a slope after filling the gas! |
Just had to share the totally random thing that happened to me today. After filling up the gas in my '66 Kombi, we drove over to a nearby tennis court and parked. The parking lot had a slight slope to it, so the bus was slightly tilted to the passenger side. Seriously... not a big slope, just barely noticeable.
When we got back to the bus, fuel was dripping all over the asphalt! Gas was just drooling out of the fuel filler neck. Quite a mess. Fuel was pooled in the tray where the fuel tank resides, and it was all over the frame and wiring. Got everything dried off and waited a while, and then drove home with sweetie clutching the fire extinguisher and looking for smoke out of the rear view mirror the whole time.
Has this ever happened to anyone? It's a pretty rare turn of events - the parking lot was super close to the gas station, probably less than a mile. I had no idea that the tank got THAT full and that it would be that sensitive to a slightly non-level parking spot. _________________ '66 Velvet Green Kombi |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7047 Location: Lawrenceville, Ga
Posted: Sat Jan 16, 2021 7:12 pm Post subject: Re: TIL: Don't park bus on a slope after filling the gas! |
barfsurfer wrote: |
Has this ever happened to anyone? It's a pretty rare turn of events - the parking lot was super close to the gas station, probably less than a mile. I had no idea that the tank got THAT full and that it would be that sensitive to a slightly non-level parking spot. |
yes, this has happened to all of us. Just don't top it off that high.
I even got a ticket once in Germany..... for the "remediation". _________________ regards
Uli
EverettB Administrator
Joined: April 11, 2000 Posts: 69809 Location: Phoenix Metro
campingbox Samba Member
Joined: November 14, 2000 Posts: 10196 Location: Petaluma, CA
Posted: Sun Jan 17, 2021 2:41 am Post subject: Re: TIL: Don't park bus on a slope after filling the gas! |
Gas expands when it gets warm, this is what makes it work to push your pistons towards the center of your engine. It can also expand in the tank and will run out the vent hole.
There is a drain tube at the bottom of that little shelf that routes the excess gas safely down below the vehicle. It sounds like yours is clogged, this is not uncommon. Try running a cut off clutch cable through the hole to free up the crud inside there. |
iubhounds Samba Member
Joined: July 22, 2003 Posts: 339 Location: Southern Indiana
Posted: Sun Jan 17, 2021 7:45 am Post subject: Re: TIL: Don't park bus on a slope after filling the gas! |
I wish this thread was two weeks older. I had this happen in my single cab just a few weeks ago parked in front of my friends bicycle shop. The only diffrence, I had been trying to fix a very small leak that did not leak out the vent hole but out of the plate where a long vent hose was attached. Since it was a custom made aluminum tank, I thought I had an isolated case and it was the tank that was made. I did not know it was normal since I had never experienced it after years of owning buses.
I bought a new stock VW gas tank and had it installed last week. Since that time I have filled the tank to the max for the first time ever BUT I have not parked any place where the single cab is leaning to the left or right. Photos of my previous attempt to fixing that leak are posted in my gallery and other threads here on Samba.
Normal huh? Anyone want to buy a custom made 15gal aluminum gas tank that fits in the treasures chest of a 59 single cab? I will post photos and a sales on on the classifieds later today, Sunday January 17th. _________________ 1960 VW Single Cab |
Dewayne Samba Member
Joined: October 05, 2003 Posts: 332 Location: Oklahoma
Posted: Sun Jan 17, 2021 8:59 am Post subject: Re: TIL: Don't park bus on a slope after filling the gas! |
About 5 yrs ago, I had taken my College Drawing class to a local park to draw and on the way back to campus I topped off my gas tank. When I got back on campus I had to park in a place I hadn't parked before. Some colleagues and I went to lunch at that time. About 30 minutes later my phone blew up.... Something was wrong with my truck! I headed back to campus to find the Tulsa Fire Dept., Tulsa Police and Campus Police surrounding my truck and crawling around under it. It took a lot of explaining and moving off the the incline to another parking spot to completely convince them that the gas dripping from under was not a big bad leak. I'm just glad they didn't decide to 'foam' it before I got there!
_________________ "My ex-wife had a hint of a beard and she looked like a manly-girl... that made no difference..."
Drive 'em if ya got 'em, and don't brag if you didn't do the work yourself...
'64 SO34
'60 SO23 |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13270 Location: Tejas!
Tom snowden Samba Member
Joined: October 29, 2015 Posts: 55 Location: San Jose
Posted: Sun Jan 17, 2021 10:59 am Post subject: Re: TIL: Don't park bus on a slope after filling the gas! |
Yup! Happened to me just have to lean toward the driver side or a flat spot. I feel better that I’m not alone. |
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4572 Location: St Charles, MO
Posted: Sun Jan 17, 2021 12:38 pm Post subject: Re: TIL: Don't park bus on a slope after filling the gas! |
Man! Does this bring back memories!
Most of us have had this happen to us in one way or another. That was your turn to learn the lesson.
Cold gasoline stored in an underground gas station storage tank pumped into your warm Transporter on a warm or (even worse) hot day and then parked on even a slight slope will cause this misadventure as the gas warms and expands up your filler neck and is forced to ooze out your vented cap. Either put miles immediately after the fill-up to use/burn off the gas, or do not completely fill the tank.
I bet that won't happen to you again now that you know better! Welcome to the club!
Bill Bowman _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
d-rick Samba Member
Joined: May 14, 2006 Posts: 889 Location: Columbia,MO
Posted: Sun Jan 17, 2021 4:30 pm Post subject: Re: TIL: Don't park bus on a slope after filling the gas! |
This happened to me in my 13 window last year when we were out in Colorado. We had lunch at Bristol brewing Co(home of mass transit ale) then filled up with gas on our way back to Manitou Springs ,where I parked on Manitou Ave in front of a restaurant. My wife and I went for a walk around town and when we came back the bus was surrounded by MSFD..I quickly explained my dumb mistake and drove off _________________ 1959 mango-trailerbus
1962 single cab *1/2
1966 13 window
1967 panel/camper
1968 cig-panel *1/2
1968 passenger bus *1/2
1969 beetle
1969 dormobile
1978 sage green Westy
1990 DoKa
2002 Golf TDI |
VWAdam Samba Member
Joined: February 14, 2002 Posts: 3331 Location: Birmingham, Alabama
Posted: Sun Jan 17, 2021 4:51 pm Post subject: Re: TIL: Don't park bus on a slope after filling the gas! |
I had it happen back in the summer. I was actually parked on the street outside of a VW parts place. Another customer came in telling me I was pouring gas all over the place. I immediately realized and said that I'd just filled it up a couple of miles away and shouldn't have parked there. The guy kept saying there's no way I was going to be driving home with such a bad gas leak and insisted I didn't know what I was talking about, saying something about me being too young and inexperienced
Funny because when I moved it across the street into a flat parking lot it stopped. _________________ All he needed was a wheel in his hand and four on the road.
'59 Euro Beetle ragtop
'63 Standard Microbus
Come to my show! www.volksjam.com
Looking for badge/sticker/frame from Western Motors in Great Falls, Montana |
Busted-bolt Samba Member
Joined: April 14, 2018 Posts: 514 Location: minnesoota
Been there done that ..except I did something thats a big no-no. It all began when after toping off the tank than drove it about 5 miles and parked it .Then I noticed a small fuel drip from the drain tube behind the the right hand rear wheel .Yes the bus was in a perking lot tilted to the right a bit and I thought it would be a good idea to vent the tank by cracking the cap a bit. That crap came shooting out and soaked my hand before i turned it back to lock position. Oops _________________ Vw collection 60 combi ,61 panel ,62 deluxe micro,82 diesel Westfalia,88 Vanagon synchro,98 Jetta tdi,11 Jetta tdi mt ,11 Jetta tdi dsg.
I do all my own work,body,engine and transmission.
VWAdam Samba Member
Posted: Sun Jan 17, 2021 4:53 pm Post subject: Re: TIL: Don't park bus on a slope after filling the gas! |
Busted-bolt wrote: |
Been there done that ..except I did something thats a big no-no. It all began when after toping off the tank and noticed a small fuel drip from the drain tube behind the the right hand rear wheel and yeah the bus was in a perking lot tilted to the right a bit and I thought it would be a good idea to vent the tank by cracking the cap a bit. That crap came shooting out and soaked my hand before i turned it back to lock position. Oops |
I did that with my '67, my first split Bus when I was 19. I worked at a restaurant and a gas station connected to our parking lot. Someone ran in telling me my Bus was leaking and I went out and opened the cap. So then here I was the rest of the night cooking up BBQ and smelling like gasoline. _________________ All he needed was a wheel in his hand and four on the road.
Manfred58sc Samba Member
Posted: Sun Jan 17, 2021 6:14 pm Post subject: Re: TIL: Don't park bus on a slope after filling the gas! |
Broke-ass hippies only put in $5 at a time-never happened to them! _________________ Fat chick owner/operator |
Dustin B Samba Member
Joined: March 29, 2007 Posts: 1017 Location: hesperia, Ca USA
Posted: Mon Jan 18, 2021 12:13 am Post subject: Re: TIL: Don't park bus on a slope after filling the gas! |
I've had it happen to me a few times. I was talking to a few friends about it and one of them told me my gas cap wasn't venting. It was an aftermarket newer cap. My friend said to drill a small vent hole in the cap or get an original vw cap. I drilled a hole in the cap I had and never had a leaking problem again. I now have an og cap. Still no leaks and I top off every time at the pumps. _________________ Wanted Victoria motors licence plate frame.
62 og paint L469 type 1
61 og paint L31 DD panel type 2
64 heilite viscount tent trailer
71 sears clamshell trailer
I <3 Brazilian busses
Original paint and patina extravaganza http://www.thesamba.com/vw/forum/viewtopic.php?t=187156 |
Split 66' Samba Member
Joined: October 07, 2010 Posts: 1255 Location: Bay Area, California
Posted: Mon Jan 18, 2021 12:34 am Post subject: Re: TIL: Don't park bus on a slope after filling the gas! |
Most recent time this happened to me, was last week.
Parked with a full tank, and the passenger side jut a bit lower than the driver side. _________________ "OG = Original German" -- TheSamba.com dictionary |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22640 Location: NYC/Upstate/ROW
Posted: Mon Jan 18, 2021 8:07 am Post subject: Re: TIL: Don't park bus on a slope after filling the gas! |
Thermal expansivity of gasoline is very low , of order 0.0006 per F
Spillage is overfilling , not thermal Expansion of liquid. On an evap
Equippedcar it is possible that vapours can drive liquid to spill via the evap
System if there are faults in that system. _________________ .ssS! |
Posted: Mon Jan 18, 2021 9:49 am Post subject: Re: TIL: Don't park bus on a slope after filling the gas! |
Abscate wrote: |
Charles’ law says 10.6 gallons of gas pumped out of the ground at 50 degrees and will now be 11.1 gallons at 80 degrees.
That’s over half a gallon spilling on the ground. |
Posted: Mon Jan 18, 2021 1:23 pm Post subject: Re: TIL: Don't park bus on a slope after filling the gas! |
campingbox wrote: |
Abscate wrote: |
i am thinking the fact that gases compress and expand, and liquids do not plays into this as well?
there is always an air bubble a the top, if the car is tilted towards the gas cap, that air is on the opposite side. If that air expands it displaces the liquid, which goes up the path of least resistance... there is your mess. _________________ regards
Uli
FarmerBill Samba Member
Joined: July 25, 2017 Posts: 766 Location: New England
Posted: Mon Jan 18, 2021 3:03 pm Post subject: Re: TIL: Don't park bus on a slope after filling the gas! |
When gasoline is sold by the tanker full, often they will take a temperature reading and adjust the price accordingly. With many petroleum distillates a gallon isn’t always a gallon. I used to buy kerosine from a gas station that had an above ground storage tank. The colder it got the better the deal, just couldn’t store the full cans inside or they started puking out the vent. |
