ToolBox Samba Member
Joined: January 27, 2004 Posts: 3439 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Thu Jan 21, 2021 10:17 am Post subject: Re: 1966 Wiring Diagram |
Jeler wrote: |
Toolbox
Thanks for the info, I think it's rather odd the blinker is grounded via the wiper switch, but trust the Germans to know what they are doing. Also thanks for the link to wires and their codes. Very informative!
Thanks again
Jeff |
The blinker ground has nothing to do with the brown wire in and out of the TS switch. It's only function is to control the cycling of the headlight relay. |
Split 66' Samba Member
Joined: October 07, 2010 Posts: 1255 Location: Bay Area, California
Posted: Thu Jan 21, 2021 12:11 pm Post subject: Re: 1966 Wiring Diagram |
Jeler wrote: |
Split 66' wrote: |
When you turn the key to start (engage starter motor), does the auto-flashing change at all?
No change at all
To test the brake light, you can touch the two brake light switch wires together, or get a jumper wire between the two.
I do believe the "Gremlin" has been discovered. It is hiding in the master cylinder switch. Jumped the two wires-flashing stopped! Yeah
Sounds like your harness is for a '67, if it has provisions for a dual circuit master cylinder, with dual brake light switches. |
This winter I am planning on installing a dual circuit master cylinder so hopefully that will remedy the switch problem
Thanks again Split 66 for hanging in there with me. I owe you a beer or two!
Jeff |
Always happy to help if I can.
Just to make sure you're done with this problem for good: when you jumper the two brake light switch wires together (equivalent of stepping on brake pedal), the auto-flashing now stops, but does the second filament on the brake light bulb light up (dual intensity)?
When you remove the brake light jumper (let the brake pedal up), does the auto-flashing problem start again? If so, it makes me think the rear running lights, are connected to the Emergency flasher somehow, maybe one wire in the wrong place?
Hope all is well, and I'm just overthinking this. _________________ "OG = Original German" -- TheSamba.com dictionary |
Jeler Samba Member
Posted: Thu Jan 21, 2021 3:22 pm Post subject: Re: 1966 Wiring Diagram |
Split 66
With the jumper wire on the master cylinder jumped both filaments in the left tail on, but on the right tail light only one filament lights up!
Also the license plate bulb does not light, that could be ground issue.
When I remove the jumper wire the flashing continues!
I’ll check all my connections up front again soon, but it might be a few days!
Thanks again
Jeff |
Posted: Thu Jan 21, 2021 10:34 pm Post subject: Re: 1966 Wiring Diagram |
No second-filament lighting on the right brake light, and no license plate light, are good observations, that should be useful the next time you get out there.
If you have the dual switch connections for the master cylinder, I'm wondering if you also have the reverse light connections, for the nosecone on the trans, and the clear/white '67 reverse lights. _________________ "OG = Original German" -- TheSamba.com dictionary |
Jeler Samba Member
Posted: Sat Jan 23, 2021 11:09 am Post subject: Re: 1966 Wiring Diagram |
Split 66
No wire included for back up light Switch!
I’m wondering now if I have the correct 2 wires connected for brake light, but doubt that would be it.
Checked if I had continuity on license plate light to fuse panel and I do,perhaps a grounding issue
Jeff |
BonTonRoulet Samba Member
Joined: September 29, 2020 Posts: 359 Location: Mississippi
Posted: Sat Jan 23, 2021 4:02 pm Post subject: Re: 1966 Wiring Diagram |
Jeler wrote: |
Split 66
Jeff |
Try swapping the connections to that taillight at the bulb holder, and/or make sure the bulb is in the holder correctly with regard to the upper/lower small tabs on the bulb holder and bulb itself. |
Posted: Sat Jan 23, 2021 4:45 pm Post subject: Re: 1966 Wiring Diagram |
The strangest symptoms can occur when the grounds are dirty (oxidized, corroded, fresh paint), or missing entirely. If you can get the License light going, perhaps that same ground problem is related to the right tail light. Also what BonTonRoulet said, the right tail light socket may have a problem with the wiring, and or grounding.
I've smashed my right tail light wiring with my battery once or twice through out the years, make sure nothing got dinged when the battery got installed.
If you can locate the second-filament wire, for the right rear bulb, by shorting the brake connections, and hunting for the signal, you should be able to determine if the problem is in the socket, or at the dash/turn signal.
How well do your running lights work?
Keep up the great work! _________________ "OG = Original German" -- TheSamba.com dictionary |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14257 Location: Casa de Oro, California
Posted: Sat Jan 23, 2021 6:53 pm Post subject: Re: 1966 Wiring Diagram |
Backup light harness is all its own and connects to the ignition power at the coil. |
Jeler Samba Member
Posted: Mon Jan 25, 2021 11:14 am Post subject: Re: 1966 Wiring Diagram |
Split 66
Took out the right rear taillight and cleaned up all contacts as well as where I have the ground attached to the outside of bulb housing with a hose clamp. Works great now, just like it should.
License plate light also had a bad ground basically thru the hinges. I ended up attaching the ground wire to the inside of the engine bay directly above the rear door frame.
All the parking lights work great, blinkers all work,headlights bright and dim both work. I also have both interior lights working.
But when I detach the jumper wire on the master cylinder the constant flashing/blinking with key on it continues! Grrrrrrrr
Thanks again
Jeff |
Jeler Samba Member
Posted: Mon Jan 25, 2021 11:17 am Post subject: Re: 1966 Wiring Diagram |
BonTonRoulet wrote: |
Thanks, I’ve got the wires and bulb configured correctly now |
Posted: Mon Jan 25, 2021 5:01 pm Post subject: Re: 1966 Wiring Diagram |
That is amazing that everything works correctly when the Brake pedal is down, but not up!
When the brake pedal is up, and your rear lights are auto-flashing, is it only one filament on the rear tail lights that are blinking?
If you were to disconnect the Emergency flasher (J1) ground, or K wire to the TS, do the tail lights still blink?
Jeler Samba Member
Posted: Tue Jan 26, 2021 11:22 am Post subject: Re: 1966 Wiring Diagram |
[quote="Split 66'"]That is amazing that everything works correctly when the Brake pedal is down, but not up!
Split 66
Just finished moving 10” of snow! Spring cannot come fast enough!
Brake pedal up auto flashing begins both filaments light up/flash!
My ground I believe is the screw holding the flasher in it,s mount. Is this what you meant?
I don,t see a K wire I have a KBL?
Sorry, just not following here on my end, sorry!
Jeff |
Jeler Samba Member
Posted: Tue Jan 26, 2021 11:49 am Post subject: Re: 1966 Wiring Diagram |
Split 66
Wow, did I not read your post thorough enough!
K wire from emergency flasher removed and it (gremlin) still flashing!
Thanks so much for your assistance! It’s driving me insane what the issue could be, unless it’s a bad 9 pin box!
Jeff |
Jeler Samba Member
Posted: Tue Jan 26, 2021 11:56 am Post subject: Re: 1966 Wiring Diagram |
FYI- I don’t have any wires hooked up in the engine bay yet!
Going to install the engine once I locate the wiring issue
Jeff |
Posted: Tue Jan 26, 2021 12:32 pm Post subject: Re: 1966 Wiring Diagram |
I'm starting to believe your 9 pin, or Turn Signal indicator, may be defective.
The next thing I would do, is to remove the Turn Signal control board from the metal housing on the steering column, and probe with your meter, HL and HR, which are the two rear tail light flasher wires. You should see the pulsing voltage going to HL and HR with your meter. If you can then probe to see what's creating this voltage, and what pin is it originating from, I think you'll finally have your answer.
I admire your tenacity, and have no doubt you'll get this fixed correctly. You're getting really close to finding the gremlin now.
Jeler Samba Member
Posted: Tue Jan 26, 2021 2:20 pm Post subject: Re: 1966 Wiring Diagram |
Split 66
Thanks for the comments and suggestions again!
Not an electrical wizard (as if you didn't figure that out yet), so probing
around the turn signal for me is iffy, esp if I have to then trace a wire down.
But I'll give it a try. I did take a digital (cheap) and touched a few wires in there and got a flash-flash. Not sure if it was hl or hr, since they are not marked.
I'll trudge around and see if I can find a culprit
Many, many thanks
Jeff |
Posted: Tue Jan 26, 2021 4:15 pm Post subject: Re: 1966 Wiring Diagram |
To probe for DC voltage on HR and HL in the TS control board, you'll want to put one probe on either HL, or HR to start, and the other probe on bare metal, like under the horn button in the steering column, or where the speed cable comes through the parcel tray on your dash. A painted surface will impede if not kill the ground signal, bare metal is best.
You'll want to have the key on, Brake pedal up, with the auto-flashing on the rear tail lights blinking. When you measure the rear tail light - HL across ground, and then HR across ground (to bare metal), you should see the voltage pulsing and supplying the auto-blinking at HL and HR, with 0-12V rapidly cycling on the meter. That same signal should be at both HL and HR, as both are lighting up. The goal is to then see where that pulsing voltage is coming from. The arrow in the pic below is where I'm guessing the auto-flashing voltage is coming from, and getting into the tail lights, but it's only a guess. The red square is where the 0-12v has to be coming from, one of those three posts. If you can locate the origin of the mystery voltage, you'll know if it's a TS, or 9pin problem.
You can then move the probes to the TS board points: 54S1 to ground, and 54B1 to ground, to see if the voltage is there too. _________________ "OG = Original German" -- TheSamba.com dictionary |
Posted: Tue Jan 26, 2021 6:05 pm Post subject: Re: 1966 Wiring Diagram |
I just went out and looked at the wiring to the 9 pin flasher box, new and recently purchased from WW, in my '66 (September 65 build) standard Microbus and there is no wire connection to terminal KBL on the 9 pin box and everything works fine. '66 was an odd year with regard to the hazard lights/flashing dash knob. You're sure your flashing knob isn't pulled up and out to turn the flashers on? I found with mine, after removing the knob and switch from the dash, I had to blast the switch out with starting fluid after removing the knob and stem, and then exercise it *sharply* several times with the knob and stem back in place to finally get it's attention and start working again after a lonnnnngggg slumber since being put in service some 55 years ago and probably rarely used in it's lifetime. So long in fact I was ready to throw it in the trash after cleaning it to no resolve but the next day it came back to life.
I also seem to remember now that I am thinking about it from several months ago, seems there was a very very small O ring or other type of insulator.....perhaps it's design was to be an insulator or maybe just something to keep trash out of the switch itself...... around the threads of the emergency flasher knob stem, at the top of the threads and base of the knob stem, where it screws into the switch. I'm not one to bet, but wouldn't it be something if that wasn't your culprit? |
Jeler Samba Member
Posted: Wed Jan 27, 2021 11:33 am Post subject: Re: 1966 Wiring Diagram |
Split 66' wrote: |
You can then move the probes to the TS board points: 54S1 to ground, and 54B1 to ground, to see if the voltage is there too. |
Split 66
Pulsing achieved at both HL & HR points!
The mystery voltage appears to be coming from the 54F pin on the 9 pin!
I’m also receiving a pulse at both TS board points 54S1 & 54B1 to ground. Hopefully I had located both points on TS board correctly!
Thanks again
Jeler Samba Member
Posted: Wed Jan 27, 2021 11:46 am Post subject: Re: 1966 Wiring Diagram |
BonTon
Thanks that is interesting! On my 9 pin I have a blue-grin wire connected that goes to speedometer lights!
I did un hook my emergency switch and the flashing still occurs!
Now that I have out I’ll clean it up with some starter fluid. Interesting about the “O” ring, but makes sense!
Thanks so much
Jeff |
