Yabbadubbadoo Samba Member
Posted: Tue Jan 19, 2021 4:41 am Post subject: Will it fit? Billet distributors and tinware. |
Do the large billet style distributors, like the MSD billet and Pertronix Flamethrower fit type 3 tinware? If not, what modifications would be necessary?
(Would like to see pics of any installations.) _________________ Sydney, Australia.
66 Type 3 Fastback |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22416 Location: Escondido CA
Posted: Tue Jan 19, 2021 7:26 am Post subject: Re: Will it fit? Billet distributors and tinware. |
I would say no. Tot the tin, but the clearance to the fan housing. Never done it, and am guessing. Other than that its the height of it. Will you be able to close the hatch? _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
VWporscheGT3 Samba Member
Joined: September 01, 2006 Posts: 2073 Location: Gardnerville, NV
Posted: Tue Jan 19, 2021 8:04 am Post subject: Re: Will it fit? Billet distributors and tinware. |
the big msd, cb performance, and pertronix ones will only fit if you are running an alternator kit... otherwise the generator is in the way. my buddy Elliot is running one on his car... and you have to clock the distributor gear to get it just so. _________________ Schnell, SCHNELL!
I like being wrong, Because, it is another opportunity to learn. If you stop learning from your mistakes than what is the point?
If you have any questions about Forged ICON 4032 VW pistons just shoot me a line. |
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4893 Location: Southern AB
Posted: Tue Jan 19, 2021 9:41 am Post subject: Re: Will it fit? Billet distributors and tinware. |
the other option is to run a locked out distributor and the CB black box.
the timing is programmable. you do have to run a manifold vacuum line from each carb intake for the map sensor. And you set the timing once on install, check it with the timing light, and adjust it with the program after that.
I'm running an early big cap distributor without the vac can and locked out with points and condenser, and a Winterburn CDI unit under the back seat
_________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap |
Posted: Tue Jan 19, 2021 10:35 am Post subject: Re: Will it fit? Billet distributors and tinware. |
VWporscheGT3 wrote: |
the big msd, cb performance, and pertronix ones will only fit if you are running an alternator kit... otherwise the generator is in the way. my buddy Elliot is running one on his car... and you have to clock the distributor gear to get it just so. |
I dont quite follow what you mean by clocking in the distributor gear. Are you talking about cracking open the engine and moving the installed position of the gear on the crankshaft or somehow adjusting the pinion on the distributor itself? Or is it just the orientation of the distributor as you drop it into the case? _________________ Sydney, Australia.
Jason37 Samba Member
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17962 Location: Eugene, OR
Posted: Tue Jan 19, 2021 11:10 am Post subject: Re: Will it fit? Billet distributors and tinware. |
Yabbadubbadoo wrote: |
I dont quite follow what you mean by clocking in the distributor gear. Are you talking about cracking open the engine and moving the installed position of the gear on the crankshaft or somehow adjusting the pinion on the distributor itself? Or is it just the orientation of the distributor as you drop it into the case? |
You can rotate the distributor a tooth as to where the rotor points for #1 cylinder when it drops into place.
Then you'll need to rotate the plug wires on the cap to match up.
It's done to get the vacuum canister & condenser etc to clear for adjusting timing. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Tue Jan 19, 2021 11:24 am Post subject: Re: Will it fit? Billet distributors and tinware. |
Mike Fisher wrote: |
It's done to get the vacuum canister & condenser etc to clear for adjusting timing. |
This _________________ Schnell, SCHNELL!
Posted: Tue Jan 19, 2021 6:36 pm Post subject: Re: Will it fit? Billet distributors and tinware. |
Thanks Mike, I saw a paragraph about this in Tom Wilsons book on Aircooled engines about the differences in rotor orientation between type 1 and type 3. It's all starting to make sense now. Cheers Paolo _________________ Sydney, Australia.
Posted: Tue Jan 19, 2021 8:27 pm Post subject: Re: Will it fit? Billet distributors and tinware. |
Seems like CSP is also selling the 123 system under their own name.
I have been looking into these distributors and been a little hesitant to pull the trigger because I also wanted to add a CDI unit.
I do like the idea of a programmable ignition without additional wiring to a separate "black box" but Im unsure if there would be compatibility issues of matching a 123 distributor with a cdi unit. Could be an expensive experiment if I mismatched components. _________________ Sydney, Australia.
Posted: Tue Jan 19, 2021 8:33 pm Post subject: Re: Will it fit? Billet distributors and tinware. |
W1K1 wrote: |
Your setup looks really well thought out and a solid mix of components.
I checked out the Winterburn CDI. It looks like a nice bit of kit.
Winterburn's website states it's compatible with 123 ignition. Do you think that would be a good option if I wanted the Bluetooth programming + CDI without the additional wiring of a Black box?
What coil do you use? _________________ Sydney, Australia.
W1K1 Samba Member
Posted: Wed Jan 20, 2021 10:15 am Post subject: Re: Will it fit? Billet distributors and tinware. |
What coil do you use? |
Yes the 123 sounds like a good setup too, it's 3 times the price of a black box here, so if you already have a good mechanical distributor.... I ran the winterburn with my bosch 010 previously as well, with no problems. You can always send Fred an E-mail, he is really helpful, and sent a bunch of info on the Winterburn, and ignitions in general. I'm running a Pertronix flamethrower coil with mine. You do need to run spark plugs without resistors with the winterburn, I killed a few last year.
The 123 vacuum set up wouldn't work on my 1968cc , the dells don't have enough vacuum signal, so the map sensor works better for me, so I can still adjust for lean cruising. _________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
HenrikL Samba Member
Posted: Wed Jan 20, 2021 11:50 am Post subject: Re: Will it fit? Billet distributors and tinware. |
W1K1 wrote: |
Do the CB black box work with stock 32 PDSIT vacuum? Then it would be possible to run the stock distributor for stock look. |
W1K1 Samba Member
Posted: Wed Jan 20, 2021 1:27 pm Post subject: Re: Will it fit? Billet distributors and tinware. |
the black box uses manifold vacuum, so it will work with any carburator, you have to use the vacuum reference kit, or drill a small hole in your manifold and insert a tube, I just used brake line tubing and JB welded them in, simple job.
you then run it to the map sensor input on the black box. Mine is all hidden under the back seat
https://www.cbperformance.com/product-p/2040.htm _________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
Posted: Thu Jan 21, 2021 3:59 pm Post subject: Re: Will it fit? Billet distributors and tinware. |
W1K1 wrote: |
https://www.cbperformance.com/product-p/2040.htm |
You obviously gav your setup a lot of thought and time so im interested to know your thoughts on why you're running points and condenser as opposed to an electronic insert like pertronics. _________________ Sydney, Australia.
W1K1 Samba Member
Posted: Thu Jan 21, 2021 4:34 pm Post subject: Re: Will it fit? Billet distributors and tinware. |
Quote: |
You obviously gave your setup a lot of thought and time, so im interested to know your thoughts on why you're running points and condenser, as opposed to an electronic insert like pertronics. |
The points just become a switch with the CDI so they will last forever. I could run the Pertonix module, I did have the pertronix in the 019 I was running before. I just didn't want to waste a perfectly good rebuilt 019 to lock out for the black box, and the early big cap distributor spreads out that more powerful spark, just like the billet distributors. I think I have $100-120 bucks in buying, rebuilding, and spare parts for two of the big cap distributors, so I have a spare.
the thread for the big cap Bosch
https://www.thesamba.com/vw/forum/viewtopic.php?t=699155&highlight=big+cap+bosch _________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76760 Location: Sneaking up behind you
Posted: Thu Jan 21, 2021 4:38 pm Post subject: Re: Will it fit? Billet distributors and tinware. |
I've rebuild and locked a few Big Cap for use with control boxes.
Points only, no condenser needed, _________________ Glenn
Member #1009
#BlueSquare |
Clatter Samba Member
Joined: September 24, 2003 Posts: 7527 Location: Santa Cruz
Posted: Fri Jan 22, 2021 9:09 am Post subject: Re: Will it fit? Billet distributors and tinware. |
This is a great thread on the subject..
https://www.thesamba.com/vw/forum/viewtopic.php?t=732536&highlight=ignition
Doesn't answer your question if it fits type 3 tin,
but with a bit of modification, anything can be made to work, right?
Next motor i build, some room for an "MSD" will be part of the program.. _________________ Bus Motor Build
What’s That Noise?!? |
Posted: Sat Jan 23, 2021 8:00 pm Post subject: Re: Will it fit? Billet distributors and tinware. |
Glenn wrote: |
Points only, no condenser needed, |
Thanks Glenn if I head down this road I'll definitely be in touch. I am partial to the look of old school tuning parts and ideas. In some ways they suffer less from obsolescence than more modern aftermarket parts manufacturers even though they are technically obsolete.
Here's an example.
I bought a motor in pieces. It was ready for 94mm pistons and came with a bunch of parts. Needed sorting and putting back together but I have since pretty much changed everything about the build except the case.
It has in the box of parts what looks like an incomplete compufire ignition system.
I'd say I'm missing either an early incarnation of a CDI unit or maybe a rev limiter or some kind of programming box.
I have no idea what plugs into this plug.
I'd say this setup was done early 2000's but IMO its more obsolete now than a 40hp points distributor and bosch blue coil.
If anyone can identify exactly what box used this plug id really like to know. Its similar to a bunch of case sockets used in CDIs and rev limiters from Pertronix to MSD but not quite any of them.
Posted: Sat Jan 23, 2021 8:38 pm Post subject: Re: Will it fit? Billet distributors and tinware. |
That ignition you show looks like the Fairchild hall sensor setup to me.
It's missing the module/box that bolts to the firewall?
A black plastic box in a finned aluminum heat sink..
'79 CA only Bus, Aircooled Vanagon, and some early 1.9 Waterboxer too IIRC..?
Allied Signal/Fairchild - super reliable/bulletproof USA made.
Oddly enough, included as standard equipment on German motors.
One of the few electronic ignitions you can pull off a junkyard motor and run forever trouble-free.
Takes it's own harness, though.. _________________ Bus Motor Build
