mikeandkirsti Samba Member
Posted: Thu Jan 21, 2021 7:23 am Post subject: Re: KDF Speedo Pod? |
August 1943 would have had a bakelite standard ignition lock. Within the past ten years or so similar dashes covered in the same oily crud have appeared and sold for thousands. What makes it interesting it is quite often the same seller or lives in the same town. Also similar other items are posted by the same guy with again the same oily crud. How many oily cruddy gauge clusters from 1943 can one guy have? This guy has had maybe 5-6. He NEVER says it is original in the ebay listing, only that it it fits a Kübel. I would never buy this unseen for this money, all this stuff is available as repro. Like Martin said, not too long you could buy a Kübel for this money, I paid about 2K for my first Kübel in 1993, numbers matching engine and drivable ready to enjoy. I vote for fake alert.
Martin Southwell wrote: |
These photos should help you make up your mind! Note that there is even a KDF key.
johnshenry Samba Member
Joined: September 21, 2001 Posts: 9359 Location: Northwood, NH USA
Posted: Thu Jan 21, 2021 9:48 am Post subject: Re: KDF Speedo Pod? |
Well that shows that the green light is on the left, not the right, and shows the cogwheel logo. Thanks Martin. _________________ John Henry
'57 Deluxe
'56 Single Cab |
originalo Samba Member
Joined: February 14, 2007 Posts: 358 Location: Germany
Posted: Thu Jan 21, 2021 9:56 am Post subject: Re: KDF Speedo Pod? |
johnshenry wrote: |
For this pod pic, I also wonder if it was actually in a VW factory, or at the place that made the pods (the Circle K logo that is on them). |
The circled K logo belongs to the German electromechanical component manufacturer KOSTAL, who is still located in Lüdenscheid/Germany. Still on the international markets with electrical connectors etc.
Did also supply split bug dash starter buttons and semaphore switches, oval era light switches etc. |
Posted: Thu Jan 21, 2021 10:00 am Post subject: Re: KDF Speedo Pod? |
Blue Baron wrote: |
I don't think a Kubel would have had a 100km speedometer. |
To my understanding Type 82 Kübelwagens normally had a speedo through 100 km/h and only civil bugs KdF-Wagen type 60 had an individual speedo until 120 km/h.
Here a foto of such an ultrarare original KdF-Wagen speedo. Indicator is also totally different compared with Kübel. The pod is KdF, knobs are originals, too.
Blue Baron VW Aficionado
Joined: June 16, 2006 Posts: 23760 Location: Southeast USA
Posted: Thu Jan 21, 2021 11:13 am Post subject: Re: KDF Speedo Pod? |
Thanks for the clarification.
interesting stuff! _________________ We are striving for perfection, to make our cars run forever, if possible.
Heinz Nordhoff |
sweden Samba Member
Posted: Fri Feb 11, 2022 5:58 am Post subject: Kdf pod |
_________________ Me and my sons cars Typ1 -49 -50 -51 -52 -52 -53 -53 -54 -55 -55 -56 -56 -57 -58 cab -64 cab
T3 TriStar airride with Audi 1,8T engine and Porsche 996 gearbox. |
Posted: Fri Feb 11, 2022 8:38 am Post subject: Re: KDF Speedo Pod? |
This one does look messed with. Screws on the back of the switch shafts indicate that it had been taken apart and tapped at one point (should be peened over rivet ends, like the switches on Sweden's pod.) The bus bar between the headlight switch and ignition switch looks homemade, and something was going on with the wiper switch, the upper rivets on the backside look drilled (should be flat) there is solder on them and the cross bar seems to be missing. If someone paid nearly 6KE for that, they got screwed.
Sweden, what is up with that ignition switch in you last pic? The keyhole. _________________ John Henry
'57 Deluxe
'56 Single Cab |
sweden Samba Member
Posted: Sun Feb 13, 2022 2:38 am Post subject: Re: KDF Speedo Pod? |
This pod is restored by Jacek and is to a Kubelwagen type 82 thats why the keyhole is different.
