Tbob Samba Member
Joined: May 26, 2007 Posts: 417 Location: Pensacola, Fl.
Posted: Wed Jan 20, 2021 7:25 pm Post subject: Re: 1700 t4 will not run with valves "properly adusted" |
Really doesn't matter that the drive gear is in the "wrong" place. What does matter is that the rotor transfers the spark to the distributor cap and ultimately the spark plugs at the right time. So if you clocked the distributor drive gear to give you more clearance for a non stock vacuum can, as long as it can be timed correctly, you are good. And if your timing light shows spark on number one at 8 degrees before TDC, I think it's ok.
However, since number one has spark but isn't running, this is a puzzle. You are setting your valves at around .006 ? I bet you are, but I just had to ask, as I can't think of anything else that would do what you are experiencing except a camshaft that isn't right, either miss timed or mis manufactured. Or, here's a Longshot, are we sure that pertronex is working properly? I have had a lot of trouble with aftermarket electronics. If you don't have a points distributor to try, I may have a spare 009 distributor I think I can put my hands on. It's all wrong advance curve wise, but if it runs on all 4 with a properly timed 009, then it isn't the camshaft. That's the only other thing I can think of. Like I said, its a longshot, but if you want to borrow it, P.M. me. We are in the same city. _________________ 1969 Deluxe, owned since 1973
1973 Westfalia, owned since 1983
1980 Westfalia, watercooled conversion
1985 Westfalia, stock!
1986 Westfakia, Audi I-4 conversion
A couple of trucks and a couple of Jeeps |
bsairhead Samba Member
Joined: October 08, 2008 Posts: 3580 Location: viroqua wi.
Posted: Wed Jan 20, 2021 7:33 pm Post subject: Re: 1700 t4 will not run with valves "properly adusted" |
Jeff Geisen wrote: |
BS, airhead.
You’ve been misled. |
Tell me how padre, the post I responded to said the distributor drive and the cam orientation are related, they are not. You say that the distributor drive must be in a set position, it does not. Yes it is nice to have the distributor drive indexed but unless your scared to move the plug wires once round it makes no difference. |
74 Westy Samba Member
Joined: January 20, 2021 Posts: 18 Location: Pensacola, FL
Posted: Wed Jan 20, 2021 7:35 pm Post subject: Re: 1700 t4 will not run with valves "properly adusted" |
One thing that crossed my mind was that the guy at european motorworks said that when #1 is at tdc #3 would have a lot of lash, but thats not the case here, #3 rockers are both tight like its in overlap |
Posted: Wed Jan 20, 2021 7:44 pm Post subject: Re: 1700 t4 will not run with valves "properly adusted" |
I did actually install my 009 but i got the same result. The only way this thing will run on all 4 is if i lash the valves starting on #1 with the rotor pointing at #3 meaning that each cylinder has bookoo lash at tdc. |
Posted: Wed Jan 20, 2021 7:46 pm Post subject: Re: 1700 t4 will not run with valves "properly adusted" |
74 Westy wrote: |
Lets verify tdc. Rotor point to #1 plug wire next wire clockwise is 4,3,2 |
Posted: Wed Jan 20, 2021 7:47 pm Post subject: Re: 1700 t4 will not run with valves "properly adusted" |
74 Westy wrote: |
The #3 rockers should be loaded on #3 when the crank is at TDCC for #1. Turn the crank 15° or so to either side of TDCC for #1 and one or the other of the valves on #3 should have lash. |
airschooled Air-Schooled
Posted: Wed Jan 20, 2021 7:49 pm Post subject: Re: 1700 t4 will not run with valves "properly adusted" |
You can go down the distributor drive oil hole with a remote inspection camera to see if your dots are aligned. Are you feeling lucky that you got your slot and dots aligned on the cam/gear itself? _________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
Posted: Wed Jan 20, 2021 7:52 pm Post subject: Re: 1700 t4 will not run with valves "properly adusted" |
I know the dots on the crank and cam are aligned, the dot and the slot on the cam, not so sure. I did not know that was a thing at the time and i eyeballed it based off how the lobes and dot on the stock cam lined up. |
Posted: Wed Jan 20, 2021 7:59 pm Post subject: Re: 1700 t4 will not run with valves "properly adusted" |
I turned the fan about 90 degrees before #1 tdc before #3 intake loosened up and about 30 degrees after before the exhaust loosened up. |
Posted: Wed Jan 20, 2021 8:04 pm Post subject: Re: 1700 t4 will not run with valves "properly adusted" |
Will i be able to see if the dot and slot on the cam are aligned through the distributor drive gear hole with a camera? |
Posted: Wed Jan 20, 2021 9:44 pm Post subject: Re: 1700 t4 will not run with valves "properly adusted" |
74 Westy wrote: |
That does not sound right. |
SGKent Samba Member
Posted: Wed Jan 20, 2021 10:13 pm Post subject: Re: 1700 t4 will not run with valves "properly adusted" |
bing, yahoo, 4search, duckduckgo etc "printable degree wheel." Print one to match the size of the fan. Then rotate the engine to TDC on #1 when the distributor is pointing to #1, and tape it to the fan so that you can tape a metal pointer - piece of wire etc., at TDC. Then as Robbie suggested determine the valve timing on #1 and see how close it is to the published specs. That will answer the question for sure. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Wed Jan 20, 2021 11:23 pm Post subject: Re: 1700 t4 will not run with valves "properly adusted" |
74 Westy wrote: |
Are you using the stock plastic or metal timing scale? You can not use the parting line for the engine case as per Type 1 engines. |
Posted: Wed Jan 20, 2021 11:48 pm Post subject: Re: 1700 t4 will not run with valves "properly adusted" |
I don't think you can put the cam gear on the cam in the wrong position. I am pretty sure the holes in the cam and gear are not evenly spaced and will mate in only one position.
One of the problems with not having the distributor drive meshed correctly with the brass gear is that it makes trouble shooting running problems that much harder. Most engines I work on for others have their ignitions out of time for one reason or another and are often way off, having the drive installed wrong and the spark plug wires rotated just adds to peoples' problems with getting these engines to run right. |
goodliving25 Samba Member
Joined: January 26, 2015 Posts: 24 Location: South Carolina
Posted: Thu Jan 21, 2021 3:02 am Post subject: Re: 1700 t4 will not run with valves "properly adusted" |
I had a Pertronix only fire on 2 cylinders before. It would only fire on 1 and 3. If you have another dist. drop it in and see if that fixes it. |
Jeff Geisen Samba Chaplain
Joined: December 21, 2004 Posts: 1883 Location: N.W. Georgia
Posted: Thu Jan 21, 2021 4:36 am Post subject: Re: 1700 t4 will not run with valves "properly adusted" |
Pertronix ignitions that skip firing certain cylinders have always had a magnet rod missing from the collar that slides onto the dizzy drive shaft from my experience. _________________ I Corinthians 4: 1 thru 5
‘63 ragtop - ‘68 single cab |
SGKent Samba Member
Posted: Thu Jan 21, 2021 8:15 am Post subject: Re: 1700 t4 will not run with valves "properly adusted" |
Wildthings wrote: |
I just checked that a couple months ago. It is correct, the holes only align one way. They are not evenly spaced. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Thu Jan 21, 2021 8:38 am Post subject: Re: 1700 t4 will not run with valves "properly adusted" |
I looked up the specs for my cam.
Intake opens 32 BT close 56 AB Exhaust opens 67 BB closes 21 AT
My actual findings were similar but not exactly the same, am i looking for when the valve visibly starts moving or when the valve is all the way open ? |
Posted: Thu Jan 21, 2021 10:43 am Post subject: Re: 1700 t4 will not run with valves "properly adusted" |
I did a little experiment. I reinstalled the 009 exactly to factory specs, started the engine with the valves correctly adjusted per the manual and it started and ran on just 2&4 again. So i decided to do the 180 backwards adjustment on just 1&3 and leave 2&4 alone. It starts and runs on all 4 like this albeit poorly. I decided to check the compression in this config. 1&3 read 150-160 2&4 read 120. Not sure if this makes any sense. Next up trying to make it run backwatds on two cylinders 😂 |
SGKent Samba Member
Posted: Thu Jan 21, 2021 11:33 am Post subject: Re: 1700 t4 will not run with valves "properly adusted" |
Brian wrote: |
Thank you Dale for just uploading this picture. The firing order is always 1-4-3-2 so when you're at the TDC mark on your pulley and both valves are closed at #1 then you can make your plugs fire in the proper order.
