10degnorth Samba Member
Joined: March 07, 2018 Posts: 472 Location: Bend, Oregon
Posted: Wed Jan 20, 2021 3:34 pm Post subject: High-Poptop Long Term Project. |
Hello, some of you may know me, I've been around the forum for a couple years now. My aim is for this post to serve as an introduction to my project and may be a little bit long winded. Since I first saw images of the Carthago and Reimo high-poptops I was fascinated and knew that I eventually had to have one. Now, they aren't exactly the most common option, if memory serves there is somewhere between 25 and 30 of them total (I think I read that production number somewhere). I know of a couple shops that are wanting to produce a kit or a top of their own that has a similar goal, these include RMW ( https://www.thesamba.com/vw/forum/viewtopic.php?t=748227&highlight= ) and some small whisperings of an electric lift top at a shop in Bend, Or (I'm not sure they want me to go into details yet so I may add more on this later).
Now, I have always been the creative and DIY type. I bought my, then tin top, westfauxlia when I was a sophomore in high school and have been fixing it up for the last couple of years. I am currently going to college for product design and I am looking to take on a little bit of a long term personal project.
I would like to design and construct a fiberglass high-poptop from scratch. At this point in time a kit is not my goal, it would be a one off unless there was substantial interest in producing a run of the tops.
Goals for top:
-Standing height when down.
-Sleeping area when up.
-Storage over cab.
-Readily available hinges.
-Aesthetic matching the vanagon platform.
-Gas lift struts.
Maybe's:
-Full roof cutout.
I drew up 12 different roof designs, just refining ideas and settled on this. I like that it looks like a shorter Joker top as I've always liked how the jokers looked.
Here's a height comparison to the currently available Reimo top.
I am thinking about what hinges I'd use and am not currently partial to any, Baywindow Westy hinges are readily available. I'd rather not use rare parts like Vanagon Westy hinges. I have seen some designs of DIY hinges that replicate the Vanagon Westy hinges and that is definitely an option.
I recently got the opportunity to look inside a van that had had the whole roof cut out and then reinforced with a hightop. I really enjoyed how much space there was in there. However, I am trying to decide if that is really worth the trouble if the top pops up.
Here's some pictures of that job.
The issue with that approach and a popping high top is that the support bar would just be in the middle of the space so I am thinking about moving it rearward. That brings up the issue of if the support bar would be adequate for strengthening the roof if it is too far back.
Here is what I am talking about.
I've been doing a lot of research on DIY car and boat building. They build plugs out of wood and foam and build fiberglass molds off of those. This top would be substantially simpler than a purpose built race car so building a plug and mold shouldn't be too bad.
I am very much looking for feedback and ideas that the community may have. Thanks! _________________ 1984 Wolfsburg Vanagon (Current Project): https://www.thesamba.com/vw/forum/viewtopic.php?t=773912&highlight=
1988 Microsquirted, Wolfsburg Vanagon (Sold): https://www.thesamba.com/vw/forum/viewtopic.php?t=708000&highlight=
Microsquirt Conversion Guide (Work now Discontinued): https://docs.google.com/document/d/1laXykNPbRYS8MT...2imqd2pnx7 |
pjn_wyo Samba Member
Joined: April 22, 2019 Posts: 181 Location: Bellingham, WA
Posted: Wed Jan 20, 2021 4:50 pm Post subject: Re: High-Poptop Long Term Project. |
Were you able to salvage the Remio top you were working on fixing?
For an initial proof of concept you could cut that one in to two pieces and work on your hinge mechanism and lift struts and then iterate from there (including making your own top when you are happy with how things open and close)
I don't think it is worth the structural reinforcement and reengineering needed to cut out the roof forward of the b panel crossbar and rearward of the c panel crossbar. I would stick to something like the folding upper westy bunk or sliding adventurewagen bunk. The storage space in a high top is one of the best things about it and you loose that without the front a rear roof. |
Posted: Wed Jan 20, 2021 5:08 pm Post subject: Re: High-Poptop Long Term Project. |
pjn_wyo wrote: |
I did save the Reimo, I am planning on replacing my westy top with it sometime in May or June to get the experience of both having a high top and a poptop so I can make some more informed decisions on the design. I am hesitant to cut it up just because of how hard they can be to find, also, I have noticed that the poptops (the westy tops especially) are built much thicker than high tops since they move and I am not sure the Reimo would be able to sustain being lifted and closed very well, it really isn't very rigid.
I agree with your sentiment on not cutting out the rest of the roof, I currently have a middle section cut out between the roof supports and it seems pretty adequate. I mostly just like throwing ideas around and the mental exercise of seeing if I can come up with a solution. I may cut out the roof skin and leave the C pillar support to build a lower profile roof and regain a little headroom. _________________ 1984 Wolfsburg Vanagon (Current Project): https://www.thesamba.com/vw/forum/viewtopic.php?t=773912&highlight=
DuncanS Samba Member
Posted: Sat Feb 13, 2021 3:59 pm Post subject: Re: High-Poptop Long Term Project. |
I highly applaud your thoughts and plans. I have been a long time boatbuilder both in wood and fiberglass and would like to pass some thoughts on to you for your consideration.
Although the Reimo and many other high tops are pretty flexible, they don't need to be and can be lightweight as well. The easiest way to do this is to add a core to the material the top is made of. Essentially, a fiberglass sandwich with either a foam or balsa wood core will separate the two skins and create a very rigid structure. By having two thin layers of fiberglass, it may even be lighter in weight than an uncored thicker layup. The added advantage with this type of construction is you wind up with insulation which will reduce condensation during cold weather use or even eliminate it. Wiring can be buried in the core to create a really clean interior. Another advantage to rigidity would be the ability to eliminate the H bar the Westy's have. A single strut forward with X bracing made of HDMW line will give you a stable top in the up position which won't wobble in the wind. Dyneema in 1/8" diameter can not be broken and is light, flexible and inexpensive.
Epoxy is easy to work with and a single layer over each side of foam will give you the stiffness you want. Either foam or balsa is available from boat builder's supply houses that are designed to conform to compound curves, so any shape you want is possible. A prototype made of lumber yard urethane sheet insulation can be easily fabricated using a hot glue gun to hold the pieces in position while your are trying all this. If possible with the space you have available, I suggest you get a junked T3 and cut the top off and mount it on sawhorses so you have a convenient height for working and experimentation. Once the prototype is stuck together, you can spray foam the corners to fill in any gaps. With a high speed angle grinder--Harbor freight 10k rpm for $19.95 with a 50 grit sanding disc--the foam can easily be rounded. Epoxy that can be dispensed with pumps makes getting the ratios correct easy and clean. This prototype will also be useful in helping you develop the skill necessary for the final version.
I urge you to continue using pencils and scratch paper to develop your thinking. The problem with computers is they are seductive and can lead you to think what you have is perfect because the lines are so crisp and accurate. Pencils will allow you to develop many, many more ideas before you discover THE ONE. As an architect, I see this problem all the time. The right solution doesn't come easily. It takes lots of thinking, exploring and testing. I will bet that you will go through 15 of more designs until you are happy with the direction you want to go in.
Lastly, I don't see any reason for the intrusive reinforcement shown in the back of one of the photos you posted. I'm about to cut the entire roof out of my tin top and eliminate the C pillar crossmember. By welding in a piece of rectangular steel tubing, 1 x 3" and laying it flat, it should provide all the stiffness necessary. It would run from the B to D pillars.
Good luck and keep us abreast of your thoughts. A great project. Glad to see you don't want to settle for just the standard cookie cutter solution already out there.
Duncan |
4Gears4Tires Samba Member
Posted: Sat Feb 13, 2021 4:58 pm Post subject: Re: High-Poptop Long Term Project. |
DuncanS wrote: |
I urge you to continue using pencils and scratch paper to develop your thinking. The problem with computers is they are seductive and can lead you to think what you have is perfect because the lines are so crisp and accurate. Pencils will allow you to develop many, many more ideas before you discover THE ONE. |
This is great advice for so many careers. As a user/system interface designer, I try to keep this in mind as much as possible. Something about sketching out ideas by hand really keeps the iteration fast and the ideas flowing. _________________ '87 Syncro
danfromsyr Samba Member
Posted: Sat Feb 13, 2021 4:59 pm Post subject: Re: High-Poptop Long Term Project. |
it will be heavier than you think it will be.
so be prepared not only to lift it but the structural needs of the lift & pivot points.
here's my brother's poptop hightop., though I don't have a pic of the top popped. but it's a modifed westy top so it'll just look like a westy canvas and such.
Abscate wrote: |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32625 Location: Reading Pennsylvania
Posted: Sun Feb 14, 2021 6:01 am Post subject: Re: High-Poptop Long Term Project. |
Dave, you are right about opening the roof aft of the C pillar..........except for the feeling of what it will be like with all that open space. If there is a permanent platform for the bed, then the flat section will be helpful and the C pillar brace can be straight across. However, the picture of the folding platform that is hinged up and out of the way seems to add significantly to the sense of interior room, even it it doesn't really do anything. Of course, the cube is lost by doing that for storage of bedding and so on, but that is something the OP and others will have to decide for themselves.
I want to go all the way back to the AC and remove the C brace because I plan to have a plexiglass sun roof that goes from behind the B pillar all the way back and don't want the visual interruption of the cross member. For me it's a function of creating as much feeling of openness as possible. The section of plexiglass between the B and C pillars will be able to slide back as I really like being able to stand while loading the car with bulky items--A washing machine going to the dump, or awkward pieces of 5 x 5 baltic birch plywood?
Duncan |
Posted: Mon Feb 15, 2021 9:34 pm Post subject: Re: High-Poptop Long Term Project. |
Responding here as I don't want to see this thread lost and if it's kept current, then maybe the OP will post his thoughts.
Weight--I wouldn't worry about this. The stock Westy unit weighs 80 pounds. If I couldn't build a composite unit for around 70 pounds, I should be shot. I built a 9 foot dinghy which weighs 60 pounds. ½" foam should be good enough separation between the two fiberglass skins to achieve the stiffness you want. !2 oz biaxial cloth, one layer each side would be my recommendation. Of course carbon will make it lighter, but at a significant cost increase. Vacuum bagging will also reduce the resin component and weight as compared to a open layup and cure.
I'm convinced that with a scissors lift hinges on the back and a couple of gas struts half way along opening it should be no problem and give you great foot room for the top bed. This is what I plan to do and have a pair of hinge down struts for the front corners that will securely clip into seats at the corners of the opening. Dyneema cross bracing front and back should keep it from flapping around in the breeze. No H bar.
Show us your latest sketches and thoughts.
Duncan |
Posted: Tue Feb 16, 2021 2:09 pm Post subject: Re: High-Poptop Long Term Project. |
Thank you all for all the great advice and recommendations!
I am going to try and respond to most comments and I intend to update this thread whenever I make progress. The next couple months I will have to focus on the design since I can't do much full scale prototyping in a dorm room and my work space is 60 miles away. However, come summer I plan to start working on a larger scale.
DuncanS wrote: |
Duncan |
Duncan, I appreciate your insight. From what I'd found online it seemed like a mold production process would be ideal, however, I now see the convenience of the sandwich construction. I must have missed that before. I like the idea of having the insulation built into the top like the old AW tops had, saves the trouble of adding insulation and a headliner post installation. I am no longer planning to cut the whole roof out, it seems unnecessary now that I have considered my needs, at the very most I may cut out he rounded skin in favor of a flatter platform up top.
Luckily for me I have a large work space back home so setting up a chopped T3 roof is not unreasonable if I can find one in Oregon.
I am learning to iterate in my designs. In the past I have been the type to just go for something and let it develop as I work, but I see the benefits to planning out a design ahead of time. Honestly, that's what most of design school has been so far, learning how to think visually and think before you start building. I didn't originally share all my sketches, but I will put what I have at the end of this post. Mostly I have explored the silhouette of the top from an aesthetic stand point.
4Gears4Tires wrote: |
I think I mentioned this earlier, but I am currently in school for Product Design, my goal is to get a masters in User Experience design. Drawing was never a huge part of my creative practice until now. I've been learning to think visually and learn to communicate ideas through sketches. It is definitely an acquired skill.
Here is a little collage of my silhouette sketches. Some of them resemble already available tops while some are more out there and weird. My main influences for this design are the Getawayvan and Joker hightops.
I am going to do a bit more research and reading into foam sandwich construction, after a quick search it seems ideal for this project and very doable with the space that I have available.
Thank you for all the input and help! _________________ 1984 Wolfsburg Vanagon (Current Project): https://www.thesamba.com/vw/forum/viewtopic.php?t=773912&highlight=
Posted: Tue Feb 16, 2021 2:30 pm Post subject: Re: High-Poptop Long Term Project. |
10degnorth wrote: |
Here is a little collage of my silhouette sketches. Some of them resemble already available tops while some are more out there and weird. My main influences for this design are the Getawayvan and Joker hightops. |
You could pick 3, draw them in a bit higher fidelity, add a to scale figure standing in the middle of the van, maybe sleeping too, and then start making a pros/cons for each one. Try to figure out why one is better than the other.
UX is a great field, I really enjoy it. If you have any questions, feel free to send me a message. _________________ '87 Syncro
owokie Samba Member
Posted: Tue Feb 16, 2021 2:42 pm Post subject: Re: High-Poptop Long Term Project. |
10degnorth wrote: |
Thank you for all the input and help! |
Ever consider going the other way with it, ie. flip the top and hinge/bed section 180 degrees when viewed from the side like some of the bays? That'd be more unique, potentially give the people in the lower bed a higher ceiling, and use dead space over the cab effectively. The rearmost section could still house luggage or solar and be both more accessible and also out of the air blast zone. |
Posted: Tue Feb 16, 2021 3:21 pm Post subject: Re: High-Poptop Long Term Project. |
owokie wrote: |
10degnorth wrote: |
I hadn't, but now that you have me thinking about it...
Hinging at the front rather than the back would allow for less wasted space, you're right. I am going to do some more sketches keeping that idea in mind. _________________ 1984 Wolfsburg Vanagon (Current Project): https://www.thesamba.com/vw/forum/viewtopic.php?t=773912&highlight=
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17153 Location: Retired South Florida
Posted: Tue Feb 16, 2021 3:44 pm Post subject: Re: High-Poptop Long Term Project. |
You need to fabricate a plug first, then lay up a mold, and then you’d lay up your part. Basically 3 tops to get one.
You have this top already. You could coat it with mold release and PVA and pull a mold of it. Then lay up at top and modify it for your proof of concept. You could likely sell tops from your mold to cover your costs. A local fiberglass shop could do the production of roofs as they sell.
In the mean time you work on your proof of concept, cutting trimming finishing etc. You could then do the final body work and utilize as a basic one off or pull another mold.
The other option would be to glue blocks of foam together and sculpt your new top. Then lay up cloth and finish the outer surface. You’d the scrape the foam out from under.
What you are thinking regardless is a ton plus of work for one person. I hate fiberglass work. I do it only when necessary. _________________ ☮️ |
Posted: Tue Feb 16, 2021 4:10 pm Post subject: Re: High-Poptop Long Term Project. |
MarkWard wrote: |
What you are thinking regardless is a ton plus of work for one person. I hate fiberglass work. I do it only when necessary. |
I understand the process of building a top. DuncanS suggested foam core construction which may be easier for a one off.
From what I've read, for foam core construction you build a plug, lay foam or balsa wood over it and then lay up the outside in fiberglass. Once that is done you separate the part from the plug and lay up the inside. The exterior layer of fiberglass holds the foam in shape so that you can lay up the inside. The hard part with that construction is under sizing the plug to account for the thickness of the top. At least that is my understanding.
This article seems like a good overview of the process.
https://boatbuildercentral.com/support-tutorials/Tutorials/foam-sandwich-how-to.pdf
Most marine applications use pretty thick semi rigid foam. However, from a little bit of research I think that I can and use something thinner. At the moment I am thinking of using 1/2 inch thick 3lb or 5lb density vinyl foam for the core. This should bend well enough fort sharper corners while also providing an airgap as insulation.
https://www.fibreglast.com/product/Vinyl_Foam_3_lb_Density/Foam _________________ 1984 Wolfsburg Vanagon (Current Project): https://www.thesamba.com/vw/forum/viewtopic.php?t=773912&highlight=
Posted: Tue Feb 16, 2021 4:26 pm Post subject: Re: High-Poptop Long Term Project. |
These are some one off defroster ducts I made.
I sculped the duct from foam. Laid up glass. Once dry, I dug the foam out and trimmed the excess. These are considered on offs. If they were visible, I would have then needed to do the body work on the outside and sand and finish.
For a top, you really only need to finish the outside surface. The inside could be covered in insulation and headliner material.
More than one way to skin a cat. _________________ ☮️ |
Posted: Tue Feb 16, 2021 4:53 pm Post subject: Re: High-Poptop Long Term Project. |
You seem to have access to computer equipment that many of us don’t have. It would be possible to make a model out of foam. Then scan it and scale it up. The file could then be used to operate a CNC type machine that could shape
a giant block of foam. That could be done quickly. You’d have to do some searching to find businesses that could do that.
Those 2 ducts took a day start to finish. You can imagine the man hours that would go into sculpting an entire top. _________________ ☮️ |
