Who.Me? Samba Member
Joined: July 14, 2014 Posts: 2190 Location: UK (South)
Posted: Fri Jan 22, 2021 2:50 am Post subject: Anyone good with electronics? - odd issue with digital voltmeter |
Putting this in the off-topic section because I've seen that there are some folks on here who have a better understanding of electronics than I. I'm hoping they might be able to explain why I get a false reading on a digital panel voltmeter in a project circuit that I've built...
One of my other hobbies is collecting watches that use an obsolete type of electronic movement regulated by a tuning fork. (ESA 9162-based movements, in case you're interested.)
Over the years, I've learned to service them myself by re-using parts scavenged from 'faulty' watches that I've picked up cheap.
To ensure accurate timekeeping, the movements need testing at a range of voltages from 1.0 to just under 2.0V. I've been using a variable voltage power supply that outputs 0-3V. I built it several years ago based on this design http://www.pocketwatchrepair.com/catt/pwr-supply.php
The power supply runs from a 12V 'wall wart' power supply and outputs 0-3V.
It uses an LM317 and an LM7805 voltage divider.
The only change that I've made to the design is to have only one set of output terminals (I don't needed the others my application) and to connect a 0-50micro-Ampere ammeter and a 0-30V digital voltmeter to read the current and voltage directly at those terminals.
The ammeter always reads correctly but despite trying several voltmeters, I've never found a voltmeter that works on this supply. They all add 5.1V or thereabouts to the actual output voltage. If I measure the output voltage with my multimeter, it shows 0-3V output, but the built-in voltmeter shows 5.1V - 8.1V.
I've tried a variety of three and four-wire voltmeters powered by the 12V supply to the tester and they all add 5.1V to the actual output voltage.
If I test the voltmeters independently of the circuit, they read voltage correctly (e.g. they read the voltage of an old AA battery on my desk as 1.2V). Connected back in to the circuit, they show the voltage as 6.2V.
Why? The only thing I can think is that the voltmeter is only reading the output from the LM317 voltage regulator (the LM7805 is a 5V fixed-voltage regulator), but I don't understand why. The multimeter clearly shows the actual output is the combined effect of both regulators.
Is there anything I can do to fix that, other than just subtract 5.1V from the displayed voltage on the voltmeter.
I'd rather omit my multimeter from the testing process because the connectors have a habit of pinging off the power supply terminals just when I don't need them to.
The voltmeters I've been trying are powered by the 12V _________________ Andy
Looking for info on my truck's history. Are you from Campbell California or nearby. Do you recognise it? ... http://www.thesamba.com/vw/forum/viewtopic.php?t=636786 |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22568 Location: NYC/Upstate/ROW
Posted: Fri Jan 22, 2021 12:41 pm Post subject: Re: Anyone good with electronics? - odd issue with digital voltmeter |
If the impedance of the voltmeter is a lower than that of the circuit driver you could well be measuring the 5V added to the output, which will not be present on load. I think I made this same mistake back in the 1980s, when they failed you in the lab and made you do it again weekends.
A cheap voltmeter will have a low input impedance so that the voltage sensitive circuit can be less sensitive and thus cheaper.
The fix is no Fluke, or perhaps the opposite. _________________ .ssS! |
Posted: Sat Jan 23, 2021 3:08 pm Post subject: Re: Anyone good with electronics? - odd issue with digital voltmeter |
Abscate wrote: |
The fix is no Fluke, or perhaps the opposite. |
Isn't impedance a parameter of AC circuits (the issue that leads to Power Factor problems)? _________________ Andy
Posted: Sat Jan 23, 2021 3:16 pm Post subject: Re: Anyone good with electronics? - odd issue with digital voltmeter |
It’s a measure of load , but you usually use it to talk generally about circuits which can be DC or AC. You could say load here since I think it’s just a dc device
‘Sorry to obfuscate, Abscate. _________________ .ssS! |
Posted: Thu Jan 28, 2021 2:54 am Post subject: Re: Anyone good with electronics? - odd issue with digital voltmeter |
Thanks Abscate. Your reply has led me to read around voltmeters and resistance.
I found information here... https://www.allaboutcircuits.com/textbook/direct-current/chpt-8/voltmeter-impact-measured-circuit/ ... that corroborated what you've said.
I figured that means I'd need to increase the resistance at the voltmeter to get it to record correctly, but was concerned that would have an affect on voltage and current at the output terminals.
Then I found this post on Quora...https://www.quora.com/Why-does-an-ideal-voltmeter-have-infinite-resistance. If I understand it correctly, it says that current will follow the path of least resistance, so putting a voltmeter of infinite resistance in parallel across the output terminals will have no effect on the current or voltage at those terminals as the current will bypass the voltmeter? (The voltmeter will show the potential difference across the terminals but not influence current or voltage?)
So:- do I just need to add resistors in series with the voltmeter (with the voltmeter connected in parallel across the output terminals) to get it to read correctly? If so, how do I calculate how much resistance to add (the total value of resistors)?
Or alternatively; if I buy a different voltmeter, how do I identify whether it has sufficient resistance already to read correctly? _________________ Andy
Posted: Thu Jan 28, 2021 5:51 am Post subject: Re: Anyone good with electronics? - odd issue with digital voltmeter |
You want to look for the input impedance spec on your voltmeter.
Here’s my Fluke manual
Snip
When measuring voltage, the Meter acts approximately like a 10 MΩ (10,000,000 Ω) impedance in parallel with the circuit. This loading effect can cause measurement errors in high-impedance circuits. In most cases, the error is negligible (0.1% or less) if the circuit impedance is
10 kΩ (10,000 Ω) or less.
For better accuracy when m
Unsnip
How accurate a measurement do you want in your power supply? _________________ .ssS! |
Posted: Thu Jan 28, 2021 9:00 am Post subject: Re: Anyone good with electronics? - odd issue with digital voltmeter |
Abscate wrote: |
Snip
Unsnip
How accurate a measurement do you want in your power supply? |
Thanks. I need 0.01V across a range from 1 to 2.5V and micro-ampere accuracy. _________________ Andy
mark tucker Samba Member
Posted: Thu Jan 28, 2021 4:22 pm Post subject: Re: Anyone good with electronics? - odd issue with digital voltmeter |
I have shot atleast 4 of the digitail meaters across the room.....my memory dont seem to work the same at those new meaters do....( cheep harbrefright meaters) |
