oscarsnapkin Samba Member
Joined: October 22, 2013 Posts: 558 Location: Bucks County, PA
Posted: Fri Jan 22, 2021 4:08 pm Post subject: Is This Engine Case Rebuildable? Need Advice/Opinions |
This is the engine from my ‘73 Thing, but I figured I’d post it in the Beetle forum since there are a lot more users and it’s basically the same engine. It is the original AM code block, so I would like to be able to have it rebuilt to keep the car as original as possible. I bought the car this past November. The engine would turn (with a wrench) almost one complete revolution, but it would bind up and I did not want to force it so I left it at that. After removing the heads I could turn the engine fully, there was a frozen valve so I guess that was the cause of the engine binding. When I removed the oil pan, about a gallon of very clear water poured out (as shown in picture). The exhaust was filled with a milky mess of oil/water mixture. The case has tons of what I can assume is gooey metal dust, which you can see on the cam gears and oil pump. The distributor drive gear is torn up pretty bad, but there’s too much crud for it to be from that. I can only assume that the engine had been underwater at some point, also evidenced by the brakes being rusted solid to the drums. I am wondering what I should be looking for as far as this case being salvageable. I had read in another thread that water can destroy the magnesium in the case. Obviously I know the crank, cam and other internal parts are junk, I am only interested in the block. Any input would be appreciated. Thanks.
_________________ - 1977 CEI Sunroof Bus 2.0L F.I. Hydraulic Lifters
- 1973 Thing
"It’s so easy to laugh, it’s so easy to hate, it takes strength to be gentle and kind." |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Fri Jan 22, 2021 4:20 pm Post subject: Re: Is This Engine Case Rebuildable? Need Advice/Opinions |
Was it in a submarine? _________________ Glenn
Member #1009
#BlueSquare |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Fri Jan 22, 2021 4:26 pm Post subject: Re: Is This Engine Case Rebuildable? Need Advice/Opinions |
i would not even consider rebuilding an engine with that case.
perhaps the crank and rods are salvageable. everything else looks like junk. _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money |
evanfrucht Samba Member
Joined: July 24, 2016 Posts: 2180 Location: Laurel Canyon, CA
Posted: Fri Jan 22, 2021 4:46 pm Post subject: Re: Is This Engine Case Rebuildable? Need Advice/Opinions |
Well. If you want an optimistic answer...
It's possibly a fine case to use... HOWEVER
Your pictures are useless. There is so much mud caked on that thing we can't even SEE it. Water can destroy a magnesium case but a lot has to do with how long it was sitting. It's possible the old oil turned to sludge and settled into the bottom of case and/or coated the inside, before water was introduced. If you are lucky it somehow may not be corroded that badly.
You need to clean it very thoroughly. Hot water, soap, deisel fuel, mineral spirits, power washer, etc. Then ideally have it soda blasted.
Then check for cracks, assess corrosion, and take measurements to determine if it can be cut for bigger bearings or if its three lives are up already.
Mine didn't look much better before I cleaned it, it had been sitting outside too. It checked out fine with my machinist and only needed the first oversize. _________________ 1967 Bug ( the daily rod )
1964 Fury Wagon ( the pavement shredder )
67 Sunroof Samba Member
Joined: February 22, 2014 Posts: 1836 Location: Salisbury, MD
Posted: Fri Jan 22, 2021 4:47 pm Post subject: Re: Is This Engine Case Rebuildable? Need Advice/Opinions |
I would use it.....
....as a boat anchor. _________________ 1776cc, CB crank, CB 2241 cam, CB light lifters, CB H-beam rods, CB light flywheel, Mahle forged pistons, A1 Sidewinder exhaust, Dellorto drla 40’s, Hoover modded case, fully balanced, fully flowed, heads by www.type-emotorsports.com, Air ride suspension by https://www.airkewld.com/?Click=3989 |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15309 Location: Deep in the 405
Posted: Fri Jan 22, 2021 5:26 pm Post subject: Re: Is This Engine Case Rebuildable? Need Advice/Opinions |
All of it is junk. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
vwinnovator Samba Member
Joined: July 11, 2005 Posts: 1555 Location: Still doing it in the back of your VW
Posted: Fri Jan 22, 2021 5:34 pm Post subject: Re: Is This Engine Case Rebuildable? Need Advice/Opinions |
wash it and see |
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Fri Jan 22, 2021 5:46 pm Post subject: Re: Is This Engine Case Rebuildable? Need Advice/Opinions |
I don't think anyone can see well enough to tell if the case is junk or not. If it sat for a very long time with water in the case, then it's likely there is corrosion damage in the sump area, but it's so filthy that you can't tell. Clean it, inspect and measure it, and if nothing is very obviously wrong, start looking closer..
I would say the crank and rods need to be reground/ rebuilt, or they could just be trashed. Everything else is a loss for sure. _________________ modok wrote:
Joined: May 17, 2003 Posts: 4863 Location: Harmony, PA
Posted: Fri Jan 22, 2021 6:01 pm Post subject: Re: Is This Engine Case Rebuildable? Need Advice/Opinions |
Pressure wash the case, and see what you have. The case would be the main thing to save, and everything else could be replaced. You would need to open all the oil gallys and do a thorough cleaning of them as well. If you have a local shop that would have a non-ferrous hot wash tank, that would help with the cleaning after getting the initial grime off. The VW certificates no longer show the engine number, so worst case scenario, find another AM case within a month of when your car was made. |
modok Samba Member
Posted: Fri Jan 22, 2021 7:30 pm Post subject: Re: Is This Engine Case Rebuildable? Need Advice/Opinions |
Looking good so far.
Clean it |
Rome Samba Member
Joined: June 02, 2004 Posts: 9654 Location: Pearl River, NY
Posted: Fri Jan 22, 2021 8:40 pm Post subject: Re: Is This Engine Case Rebuildable? Need Advice/Opinions |
Yes, clean the case, especially the sump area on the bottom inside surface. That will reveal if the oil sump drain plate/screen opening has been eroded too far so that any of the six sump plate attachment studs may be exposed. With so much water pouring out, it's likely the case is too pockmarked/eroded but you really have to clean and check first.
The crank might be saveable. Don't let the rust on the crank cheeks discourage you- once you have the crank out and the rods off, you can easily clean off the cheek rust with a metal wire bristle brush (powered or hand). If you don't see heavy grooves in either the main or the rod bearing journals due to the engine catching debris, and if no rust has developed on the journals, then you are likely to reuse it after a journal polishing, or grinding undersize. How are the crankshaft dowels that hold the flywheel? If they are loose in their drilled holes, or the holes are egged, then it's not worth saving the crank since that would require drilling new holes, or drilling the existing ones (and the FW holes) oversize and fitting oversized dowels.
Rods can be cleaned, then sandblasted and checked for straightness (that they are not bent) and the big ends resized/honed. |
jpaull Samba Member
Joined: February 22, 2005 Posts: 3466 Location: Paradise, Ca
Posted: Sat Jan 23, 2021 10:20 am Post subject: Re: Is This Engine Case Rebuildable? Need Advice/Opinions |
So far, all I see is a case that is dirty that needs a line bore. Sump area looks pretty good from what is shown.
Its like when people see a car that is covered in dirt and super light surface rust and they think its worthless junk, when in fact it just might need a cleaning. Some of the best cases are the ones covered in crap. _________________ [email protected] MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), 42x37 heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
Transmission by MCMScott:
Rhino case, Klinkenberg 4.12, Superdiff, 002 mainshaft with 091 first idler. Weddle 1.48 Third & 1.14 Fourth. |
esde Samba Member
Posted: Sat Jan 23, 2021 10:38 am Post subject: Re: Is This Engine Case Rebuildable? Need Advice/Opinions |
jpaull wrote: |
Some of the best cases are the ones covered in crap. |
This is so, so true. I bought a bunch of stuff from a retired VW guy in Far Rockaway, which is right on Jamaica Bay in Long Island. The real score were 4 AS21 cases that were all standard, and had been on the shelf for many years. The two greasy ones were perfect, and the two that had been cleaned before storage, had terrible corrosion in some spots due to the salt air. One was trashed; the condensation had collected in the oil pickup tube, and rotted the case where it connects to the coil pump. By the time I knocked of the corrosion there wasn't enough to weld it back up..
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4858 Location: sanger ca
Posted: Sat Jan 23, 2021 10:40 am Post subject: Re: Is This Engine Case Rebuildable? Need Advice/Opinions |
I agree with Jeff and a few others, you cannot determine the condition of that case by those pics, it is way too dirty to get even the slightest visual let alone any measurements. _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
Dale M. Samba Member
Posted: Sat Jan 23, 2021 3:15 pm Post subject: Re: Is This Engine Case Rebuildable? Need Advice/Opinions |
That pic says probably not....
Glenn Mr. 010
Posted: Sat Jan 23, 2021 3:29 pm Post subject: Re: Is This Engine Case Rebuildable? Need Advice/Opinions |
Dale M. wrote: |
Dale |
That's not the OP's engine. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Sat Jan 23, 2021 6:33 pm Post subject: Re: Is This Engine Case Rebuildable? Need Advice/Opinions |
Glenn wrote: |
Dale M. wrote: |
Dale |
That's not the OP's engine. |
Oops...
flat4Imp Samba Member
Joined: October 14, 2010 Posts: 48 Location: Pennsburg, PA 18073
Posted: Mon Jan 25, 2021 11:06 am Post subject: Re: Is This Engine Case Rebuildable? Need Advice/Opinions |
I think that definitely answer's my question in your other thread about it being a flood car. My main concern once you get it de-greased/washed would be cracks if it froze with that much water in it. _________________ "Often immitated, never duplicated." |
Posted: Mon Jan 25, 2021 1:44 pm Post subject: Re: Is This Engine Case Rebuildable? Need Advice/Opinions |
So I had some time to look at it a little closer to today. It’s junk. The bores (not sure what the correct term is) for the lifters are corroded. I didn’t notice until I pulled one of the lifters out. You can also see some corrosion next to the cam bearing. It seems as if all the damage is toward the rear of the engine, as if the car was parked on an incline and the water pooled in the back of the case. Total bummer. It’s a very low number case ‘000459’ so I was really hoping to be able to save it. Thanks for the replies. If anyone has an AM case I’m in the market...
- 1973 Thing
