gitchesum Samba Member
Joined: November 10, 2003 Posts: 513 Location: North Cali
Posted: Tue Jan 26, 2021 12:21 pm Post subject: American Eagles |
Can't seem to find the proper lug nut for these. Shouldered shank has to go thru the wheel. The hole is too small for any available shanked 14mm lug nut. I either turn down a shanked lug nut to fit, or drill the hole larger in the wheel. The first option isn't safe, the second option leave the wheels unusable for a VW, w/o using a custom lug to fit . These wheels were meant to go on a VW, not a 356. I did find some billet nuts, but they require a much longer stud...Oh boy.
Anybody using these on 356 drums ?
_________________ Looking for SP Kadron manifolds...please !!
57 SC
61 rag w/356B brakes
61 356B
Honda XLR 250, 69 Z50, Yamaha 100 Enduro...and others.
GMC SLT 4x4 Dmax
Kubota L3710, not enuf attachments.
And various VW's that come and go... |
74 Thing Samba Member
Posted: Tue Jan 26, 2021 12:56 pm Post subject: Re: American Eagles |
Yes, you’re right. I posted this in the 356 forum, as they use a 14mm stud.
Thanks for taking the time sir. _________________ Looking for SP Kadron manifolds...please !!
57 SC
61 356B
GMC SLT 4x4 Dmax
badsix Samba Member
Joined: November 22, 2007 Posts: 228 Location: coos bay or.
Posted: Tue Jan 26, 2021 2:07 pm Post subject: Re: American Eagles |
i'm doing this right now on a 356A using American eagle five spokes. like you i thought about reaming the wheel out and so on. what i'm finally doing is to change the wheel studs in the drum to a Doorman 610-395 there easy to press out and in. this will give you the right knurl, length and a 1/2 x 20 thread. lug nuts are easy to find in this size. i don't have the part number right now if you measure the lug nut hole then search for 1/2 x20 with an o/d of what you want. you'll need washers also. when you measure for length don't get them to long you don't want them to bottom out on the drum before they tighten down on the wheel. if it goes 3/4 the way or so into the wheel your ok.
Jay D. |
Posted: Tue Jan 26, 2021 2:46 pm Post subject: Re: American Eagles |
Thank you Jay for all the research and taking the time to post this. I just put new brakes on, and now realize I should have posted this earlier before I put it back together. I’ll look into all that and post back what I ended up doing. Thanks again sir. _________________ Looking for SP Kadron manifolds...please !!
57 SC
61 356B
GMC SLT 4x4 Dmax
Posted: Mon Feb 15, 2021 9:26 pm Post subject: Re: American Eagles |
Done and fronts installed.
Decided to not modify my drums, and instead reamed out the lug holes on the wheels. Then found the correct lug nuts, realizing the washers that came with those wouldn't work. Found some washers with the correct id/od and used those. Done deal. Plus I'll also be able to use these now on my bug....if the front tires fit ;(
57 SC
61 356B
GMC SLT 4x4 Dmax
